Fan problem at Toshiba Equium L300 laptop Problem on the laptop been descriabed as overheated after few hours of work and shut down. I work with this laptop second day now and is not overheated, but notice one thing: the fan is not working all the time. Its stop time to time. Is it right? It should work only when is hot to cool the CPU down or should work all the time? If it should work all the time what can be wrong? Fan it self or something else? What exacly have to be replaced? Cheers,
  • mctros Feb 02, 2010
    Thanks, also why this laptop been overheated and shut down in the middle of something (slow down first)?
It is normal for the fan to turn on and off and it will usually stay on for awhile if your laptop is running hot. Here are some things you can do to prevent it from overheating. First, check your vent fan and blow it out with canned compressed air. Second, install self-adhesive rubber feet at each bottom corner of your notebook for increased air circulation. Third, buy and use a Bytec Cooling pad (click on the link below to view)
http://www.newegg.com/product/product.aspx?Item=N82E16834999336&nm_mc=AFC-C8Junction&cm_mmc=AFC-C8Junction-_-RSSDailyDeals-_-na-_-na
And finally, press these buttons together, "control, alt, and delete" This will bring up your windows task manager. Go through your processes and end the tasks that you are not using. Sometimes you will have many programs running that you are not even using anymore and don't even know they are running untill you see them in your task manager. These programs drain your CPU and cause your computer to work harder then it should causing it to overheat.
Posted on Feb 02, 2010
Laptop goes on some few minutes after being shut down.
you cannot blame windows xp because according to me it is such OS that it removes many problems of windows 7 and vista.windows 7 and vista makes your pc much slow and many features dont work but windows xp is free from these errors.actually you hear the sound but nothing appears on the screen.this is because your cpu fan is running which takes somes time to stop.may be some problem of the hardware especially the mainboard.go to any repair shop and just get it checked.
Apr 02, 2012 | Toshiba Satellite Pro L300 Notebook
Toshiba Satellite L300 shuts down when ac power plugged in
How about this step, try to turn off the laptop itself. Remove the cables and battery just like what you did before, then press and hold the power button for 10 seconds. Then, reinsert the cables and battery on the laptop and then turn on the computer itself. If the laptop restarts, shuts down or freezes with the AC power cables, two things that you should seriously consider. It might be the power cable itself, AC cable port or the circuitry going to the motherboard. And since you have cleaned out the fan and heat sink, you have isolated that problem. Have you plug-in another power cable on your laptop? If yes, then check if it works. Otherwise, the main issue is that the AC port is loose or the circuitry of AC adapter going to the motherboard is not not working. You can re-open the unit and check the circuitry from the AC port going to the motherboard. You may check the circuitry from AC port to the power supply if it is ok. If symptom persist, please contact your local dealer...
Jul 03, 2010 | Toshiba Satellite Pro L300 Notebook
My Equium A200-1V0 fan stopped working
The User's Guide is available on this page on the Toshiba website, under the User's Manual tab.
I have also compiled a tip for dealing with overheating issues on Laptops as that is a common issue.
You may please refer to this link for reviewing the same.
May 10, 2010 | Toshiba Satellite A100-S8111TD Notebook
My laptop shut down after powering out with no warning and will not restart.... Toshiba L550 screen stays black but when I hit the enter key it beeps........any suggestions
“My Toshiba laptop suddenly shuts down by itself without any warning. Sometimes it works fine for hours, sometimes it shuts down in 10-15 minutes.” This complaint we hear from our customers over and over again. About 15-20% of all Toshiba laptops we get for repair, suffer from an overheating problem. Yep, OVERHEATING!
This is one of the most common problems with Toshiba laptops we deal with.
Indications of laptop overheating problem:
  1. The keyboard and the bottom of your laptop are very hot when the laptop is working.
  2. The CPU fans are working all the time at maximum rotation speed and operate much louder than before.
  3. The laptop suddenly shuts down by itself without warning. When it just started, the laptop was shutting down after 1-2 hours and how it shuts down after 5-10 minutes of operation.
  4. The laptop works fine when it runs idle, but shuts down as soon as you start using any memory demanding applications (DVD player, image editing software, video editing software, etc.).
Solution:
If the CPU heatsink is not clogged with dust and lint completely, you can use canned air and just blow it inside the laptop through the openings on the bottom and on the sides. It’s nice as a precaution measure, but it might not work if your laptop already has a problem and the heatsink is completely clogged.
  1. Open the laptop case, so you can access the CPU fan and the heatsink. In some cases you can access the heatsink through the latch on the bottom of the laptop. Sometimes (for example Toshiba Satellite A70/A75) you have to open the laptop case all the way down.
  2. Carefully disconnect the fan cables on the system board and remove the fan. If the fan makes unusual sound when it spins (grinding sound), I would recommend to replace the fan.
  3. Clean the fan and the heatsink with compressed air.
  4. I would also recommend removing old thermal grease from the CPU and applying new grease for better heat conductivity.
May 04, 2010 | Toshiba Computers & Internet
Hi, just thought I'd let you know that when I got my Toshiba Equium 200-1V0 it was supplied with the User's Manual A210 Series. The manual is just basic and does not go into full depth of how to clean out heat sink etc. The problem you described regarding the shutting down is most probably that the heat sink is clogged up with dust and needs to be cleaned. Toshiba has a lot of laptops (different models) with this problem. I had the same problem with Toshiba A200-1V0 and have now got the same problem with the Toshiba A300D-20R which is only 6 months old! On the A200-1V0 I managed to hoover the bottom of the laptop where the fan is and it worked fine, but with the A300D-20R it has not worked, but fortunately it's still under guarantee so I will be sending it back to Toshiba to do it. Here is a link to download the Manuals. You will find the Manual for A200-1V0. Hope this helps. http://uk.computers.toshiba-europe.com/innovation/download_manuals.jsp?service=UK
Mar 17, 2010 | Toshiba Satellite A100-S8111TD Notebook
My laptop gets heat and shutdown
Solution:
  1. Open the laptop case, so you can access the CPU fan and the heatsink. In some cases you can access the heatsink through the latch on the bottom of the laptop. Sometimes you have to open the laptop case all the way down.
Feb 27, 2010 | Compaq Evo N610C Notebook
My Toshiba Equium starts up ok but when I start using it it shuts down (as if power has been removed) any thoughts
If the Toshiba shuts down and then cannot boot up straight away until it has cooled down, then you could have an overheating problem.
This is caused by a faulty fan and/or dust blocking the heatsink/fan assembly.
When the CPU overheats it goes into a thermal shutdown, and if you continue to ignore this problem, then the CPU will eventually fail.
Check the fan to see if it spins freely, if not then replace the fan, if the fan and heatsink/vents are clogged with dust then loosen and remove/vacuum the dust.
Dec 14, 2009 | Toshiba Computers & Internet
Problem with Toshiba Equium Laptop which is switching itself off. even when connected to mains supply Is this a problem with the switch or power supply? Hope you can help thanks
If the laptop shuts down and won't boot up straight away, then the problem could be an overheating CPU problem. It could be a faulty fan and/or the fan and heatsink assembly is clogged with dust.
Check the fan and if it has stopped spinning then replace it and if the fan and heatsink is clogged with dust, loosen the dust and remove it.
Sep 28, 2009 | Toshiba Equium 3300M PC Desktop
I can load vga after formatting
Try Using Downloading and using the driver from this site :
http://www.laptopdrivers.net/toshiba-equium-l300-laptop-download-windows-vista-to-xp-drivers/
Or Directlink to the VGA Driver for it.
http://uploading.com/files/WS9G50H6/Toshiba-Equium-L300-Intel-Graphics-VGA-display-20080519181914-Driver-For-XP_-_ww...zip.html
But before using this one, just make sure you remove ..or rollback the previous one.
Jul 11, 2009 | Toshiba Satellite Pro L300 Notebook
Toshiba equium m40x won't power up
whats happening is that the cpu is overheating and shutting down the computer due to your fan not spinning, if you wish to test this remove the bottom panel and remove the fan and its cooling tubes should all be one part (quite easy 3 or 4 bolts) and blow on the cpu or put a pedistal fan facing it or any other form of cooling that wont damage it, and try to start it if it boots for a while it is the fan and you will need to replace it, i had this exact problem yesterday
May 18, 2009 | Toshiba A70-S256 Notebook
jasbo
jasbo
