Question about HP Designjet 110plus nr InkJet Printer
The "!" light is flashing; two of the print heads are flashing; I send a drawing to be printed; and nothing happens.
  • 742 Answers
The flashing lights signal an error. If the printer started printing, please check for jammed paper. If it has not started to print, please remove the ink cartridges and then put them on again. They might just failed to be charged by the printer unit.
Posted on Feb 02, 2010
I have never had a problem with this printer until now. I have installed new black & white as well as colored ink, but the power & paper lights flash, and both of the ink-out lights stay on. The...
Sad to hear that mate. I've still got mine and it works like a dream. I can leave it for years without printing anything and after a few head cleans it still prints like new.
Try and get another one because its that good and replacement ink costs
Sep 21, 2010 | Epson Stylus 880 InkJet Color Printer
I have an error and my printer will not print. The resume/yellow light flashes 5 times. I've unpluged/turned off and on my printer. nothing clears this error. Please help!
In Canon's list of light codes it says
Five flashes: No Print Head installed or Print Head is defective
Install a Print Head. If the problem remains, contact a Canon service representative but it could also be poorly-seated ink cartridge Pushe it down a bit and should work
Hope it helped you
Jul 16, 2010 | Canon Office Equipment & Supplies
Light kee flashing orange/green and says computer is busy when there is nothing in print queue
FLASHING ORANGE LIGHT ERROR MESSAGES
Try counting the number of orange flashes.
* two flashes means you’re out of paper or the paper is not feeding correctly.
* three flashes means there is a paper Jam or the output tray is closed.
* four flashes means the ink tank is empty
* five flashes means the print head is not installed correctly or not installed or is defective (before buying a new print head always try the cleaning instructions at the end of this post first.)
* six flashes means the inner cover is open or not closed properly.
* seven flashes means you counted wrong.....
* eight flashes means the waste ink absorber is almost full or full.
* nine flashes mean that a digital camera or video that is connected is not compatible with the printer. If a specific amount of time lapses without getting a response from the digital camera or video camcorder this will happen.
* ten flashes means it can not print to both sides of the page
* eleven flashes means the automatic print head alignment failed. (this can be caused by low ink levels, ink tanks not being installed correctly, the print heads being clogged. It can also be caused by the paper output slot being exposed to a strong light source (Press the resume /cancel button and move the printer to a darker location and try to align the print head again.
* check to make sure the lock lever is correctly positioned (down)
If the above does not work, align the print head manually by opening the printer properties dialog box and clicking the maintenance tab and then select the print heal alignment button on the left side, second row down.
Mar 29, 2010 | Canon BubbleJet i320 Printer
My is not working & shows an error code B200.
Mar 25, 2010 | Canon Office Equipment & Supplies
PLSE HELP IM TRYING TO PRINT BUT NOTHINGS HAPPENING, IT IS ALL SET UP
test the printer first, so that we can isolate the issue. print a nozzle check to eliminate the possibility that the nozzles are clogged by dried inks. if nozzle check prints blank page or it printedr but w/ gaps or breaks, do head cleaning
Check the Print Head Nozzles: 1. Load a few sheets of plain paper in the sheet feeder. 2. Turn off the Epson Stylus CX4400 Series. 3. Hold down the cx4400_ug.1.79.1.jpg Stop button as you press the cx4400_ug.1.79.2.jpg On button to turn the Epson Stylus CX4400 Series back on. Hold down both buttons until the cx4400_ug.1.79.3.jpg On light begins to flash, then release the buttons. cx4400_ug.1.79.4.jpg 4. Check the nozzle check pattern that prints to see if there are gaps in the lines. cx4400_ug.1.79.5.jpg 5. If there are no gaps, the print head is clean and you can continue printing. If there are gaps or the pattern is faint, clean the print head. Clean the Print Head Nozzles: 1. Load a few sheets of plain paper in the sheet feeder. 2. Hold down the cx4400_ug.1.80.1.jpg Stop button for at least 4 seconds to start the cleaning cycle, which lasts around 1 minute. cx4400_ug.1.80.2.jpg The cx4400_ug.1.80.3.jpg On light flashes throughout the cleaning cycle and stays on green when the cycle is finished. Caution:
Never turn off the Epson Stylus CX4400 Series during a cleaning cycle or you may damage it. 3. Run a nozzle check to confirm that the print head is clean. You may need to clean the print head up to 2 times. You can also turn the Epson Stylus CX4400 Series off and wait at least 6 hours. Then try printing again.
Feb 15, 2010 | Epson Stylus DX4450 All-In-One InkJet...
HP LaserJet 4 Printer stopped printing
Try putting a piece of paper in tray 1
Feb 26, 2009 | HP LaserJet 4 plus Printer
Operators Error - won't respond to anything
i have the same problem and im clueless as how to fix it :(
Dec 19, 2007 | Canon PIXMA iP5000 InkJet Photo Printer
HP Designjet 110plus nr InkJet Printer Logo
318 people viewed this question
Seeker5211
Seeker5211
