Samsung WS32A11 (K55A chassis).Fault: Blown H.O.T.(FLJ6920).Replaced with a 2SC5144 equivalent.Now have large current flow.Have substituted L.O.P.T.-no change. HT ok with Dummy load.Suspect deflection yolk but can't prove.Have substituted another yolk from a totally different tv (philips) and get partial raster with normal current consumption. I now have two of these sets with the same symptom.Have made one query to spares agent only to be told that yolk is sold including picture tube !! ($1200) yet the yolk can easily be removed from tube neck ? Any ideas anyone ? Am I missing something in my faultfinding proceedure.
  • 1 more comment
  • mikebongard Feb 20, 2008
    This is not a projection TV-just an ordinary wide screen type.
    I'M A FIRST TIME USER OF FIXYA AND I DONT THINK I SHOULD HAVE TICKED THE "ACCEPT"BOX HERE AS IT HASN'T HELPED ME YET.
    What do you mean by "check on best buys-they will fix it easily" ?
    I want to repair the set myself-I'm just after advice hopefully.
  • mikebongard Mar 03, 2008
    I'm still waiting.Anyone out there with experience on this model ?
    Sergeant:
    Champion:
  • 281 Answers
Check on Best Buy they will fix it easely
Posted on Feb 20, 2008
2.8 oz of onion straws is how much in cups?
How much Chopped, or Sliced Onions are in a Pound?
www.howmuchisin.com/produce_converters/onion
  1. Cached
  2. Similar
How many onions do you need to purchase to measure 2 cups for a recipe? ... (2 cups), sometimes as a weight (4 ounces) and still others the onion is given ... Ancient Egyptians worshipped the onion; they believed its spherical shape and concentric rings symbolized ... ¼, ½, ¾, 1, 1 ½, 2, 2 ½, 3, 3 ½, 4, 4 ½, 5, 6, 7, 8, 9, 10.
French fried onions : Substitutes, Ingredients, Equivalents ...
www.gourmetsleuth.com/ingredients/detail/french-fried-onions
  1. Cached
  2. Similar
French's is the producer of canned "french fried onion rings" They date back to 1933 but ... 6oz can french fried onion rings = 3 cups / 2.8-oz can = 1 3/8 cups.
Onions, raw, chopped cup measurements and equivalents in grams (g ...
www.cookitsimply.com > Measurements > Onions
  1. Cached
  2. Similar
Onions, raw, chopped cup measurements and equivalents in grams (g) and ounces (oz) ... raw, chopped. equivalent values ... 1/8 cup, 20 g, 0.7 oz. 1/4 cup, 40 g ...
How much is a small/medium/large onion? - Seasoned Advice
cooking.stackexchange.com/questions/.../how-much-is-a-small-medium-large-onion
  1. Cached
  2. Similar
Mar 26, 2011 - Medium onion = 8 ounces, or about 1 cup chopped ... I've often seen large onions that were as big or bigger than "jumbo" according to this data ...
Nov 24, 2016 | Coffee Makers & Espresso Machines
Tip
?JCB FAULT CODES LIST
P0087 (flashing code 227) shared sump low pressure fault (for pump without pressure supply)
The main fault symptoms
• Engine severe vibration.
• idling unstable
• Output Fall
• exhaust smoke
• It may be too large output
P0088 (flashing code 118) shared the tank pressure is abnormally high (first or second stage)
• idle instability
• Output Fall
• channeling gas engine failure
• exhaust smoke
P0089 (flashing code 151) shared the tank pressure failure (for pump pressure supply is too large)
• idle instability
• Output Fall
• exhaust smoke
P0090 (flashing code 247) SCV drive system open, + B short circuit or shorted to ground
• Depending on the open / short situations, there may be an engine stall and / or launch
Machine channeling gas.
• exhaust smoke
• Output is too large
P0107 (flashing code 71) atmospheric pressure sensor circuit input low (open or shorted to ground)
Due to spare the equivalent altitude 2000 m (6562 ft)
• exhaust smoke at high altitude.
• insufficient output at low altitude
P0108 (flashing code 71) atmospheric pressure sensor circuit input high (+ 5V shorted)
• The high altitude exhaust smoke
• lack of low altitude output
P0112 (flashing code 22) intake air temperature sensor fault (low voltage fault, earth fault, short circuit)
• When cold starting, may exhaust white smoke.
More here http://truckmanual.weebly.com/jcb-fault-codes.html
on Dec 20, 2016 | Cars & Trucks
2.8 oz. of dry onion straws is how much in cups?
quarter cup plus a bit
  1. Cached
  2. Similar
  1. Cached
  2. Similar
  1. Cached
  2. Similar
  1. Cached
  2. Similar
Hammond e100 Organ amplifier is their a recommended substitute solid stae amp available
Because there are other functions located in the amp chassis in the e100, there really isn't an aftermarket substitute. I think you're on the right track by rebuilding and retuning the current amp. Due to age, I'd just do it all at one time and be done with it.
Jul 10, 2016 | AMP Music
"k55A" dc jack replacement
Hello Kenneth,
The dc jack replacement cable connects from the white connector to system board and the connector where you connect the adapter lay on the edge of board usuallyc6c10d03-2117-4a84-8cc2-a16171601653.jpg
I like to use a litte bit of super glue to keep it held in place on the board.
Gotta remove some components to access it .
Mar 12, 2014 | ASUS Notebook K55A-DB51 15.6inch Core...
Respected sir i want to know the equivalent of d1878 transistor
That is a Sanyo type of line output transistor, sometimes used in power supplies of PT03 style.
Equivalents include the very popular BU508DFY BU808DFI etc or 2SC5885, 2SC5387 etc
I would choose a BU808DFI as a substitute. Slightly higher current and power rating.
Dec 13, 2010 | Televison & Video
Can anybody help me with a user or service manualthat i can downl
Samsung HLN series possibly. Look for chassis # on back label and research it by that, (such as K55A, P55A)
Apr 04, 2010 | Televison & Video
C5707 available at?
from an old post (at Dell):
The TIP3055 handles about 70V and 10 Amps and is an NPN, so I decided to purchase four 2N3055 TO220.
from another one:
was able to successfully directly substitute MJE3055 NPN transistors for those on the original board
They are "equivalent", but (much) bigger: you must do some bending for them to fit inside the chassis
Ro
Sep 09, 2008 | Dell E172FP 17" LCD Flat Panel Monitor
Televison & Video Logo
388 people viewed this question
Top Televison & Video Experts
