Question about RCA F25281 TV
RCA f25281 > had power surge from Souther California Edison, now tv has a distorted shrunk screen. What parts would I need to fix it and how much in labor? Thanks!
  • alora loomis Feb 02, 2010
    top bottom and sides all shrunk. do you know where I can get parts? husband is so-so at being handy, Do you think I should have a professional fix it? if so, approximately how much do you think it might run (parts and labor)? Or do you think I would be better off buying a new one, because the repair might be too much...
    Thank you for your time and help!! I really appreciate it and this site!! ( I have a more things that blew... like a vcr, dvd and refrig... so you might see some more post from me)
    Thank you for your help!! I really appreciate it!!
  • 1,476 Answers
Could you explain better how the picture is distorted and shrunk? Top and bottom? Left and right side? or all edges? Usually a power surge affects the power supply and causes the unit to not turn on. If you are sure this was a power surge I would look at the voltages in the power supply to be certain they are all present and correct. If they are I would next look at the video IC and Vertical IC for proper waveforms. I think between these three areas you will find the problem. Should be less than a $100 fix. Let me know how this works out for you or if you need more info contact me.
hardrocko
Posted on Feb 02, 2010
  • RCA Master
  • 5,138 Answers
Fast switching diode NTE577 and capacitor C4001 680uf 200v
Parts +Labor you are looking at around $75.00 to $85.00
!RCA TV MODEL#f25281 won't power on Few signal ticks and nothing
Horizontal output transistor short.
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Aug 30, 2014 | RCA Televison & Video
Rca lcd tv power surge lighting
The power supply is a likely place to find what's causing the problem
Jul 11, 2013 | RCA Televison & Video
The coaxial cable connection on the back of tv is missing need to know part number
Its a generic part called a F fitting and would require the tuner to be removed to replace.
If the set has a audio/video input you may be able to route signal that way and bypass the fitting---it would require a box with both audio and video outputs .
Dec 21, 2012 | RCA F25281 TV
I have a RCA Scenium HDLP50W151YX1 that has distorted Color (Bad Picture)
I am parting out my tv it was playing good when I shut it off we got a wall hanger we don't need this tv let me know what part you need I'll sale them cheap 2705898074 call me if you want
Oct 02, 2012 | RCA HDLP50W151 50" Rear Projection HDTV
Rca tv model R52WH73 at first I had a convergence problem and now the tv will not power up at all. have any ideas?
Please do us a favor and rate this by cliking the thumps up icon located here >>>>>>
Projection TV sets have two very common problems. One is convergence ( 3D/Warped video) the other is CRT fluid ( Dull Video). Below are more details for both items. Also, complete repair kits with instructions and repair support are avail from site such as www.TvRepairKits.com
Common Problem #1) Convergence has gone out
Projection TV sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the video to look normal. When its out of alignment the video will look 3D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the TV menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
This is a very common failure on these projection sets and a fairly simple DIY fix. All projection sets including Samsung, RCA, Sony, Philip Magnavox, Panasonic, Pioneer, Akai, GE, JVC, Toshiba, and others at some point will have the same problem.
Common Symptoms include....
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
  • TV shuts off after powering on. Power light will blink. TV may also make a chirping noise.
Here are some pics of convergence problems.
69189a5.pngSOLUTION #1
For more more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Common Problem #2) CRT Fluid is Cloudy
Projection TV tubes have a liquid coolant that is used to keep them from overheating. After many years the coolant in the blue and green tubes will become cloudy and cause the screen to look dull, red/orange, etc. You may even see halos around images.
Picture of a set that needs the fluid changed.
TV set after fluid change
69189a5.pngSOLUTION
You can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
May 30, 2011 | RCA R52WH73 Projection Television
The center of picture is blurring and color distortion on top
  • Screen looks 3D
69189a5.pngSOLUTION
May 27, 2011 | Hitachi 43UWX10B 43" Rear Projection...
My color is not clear. It is a HD 2001 RCA TV with a built in Direct Receiver. The color are very blue and it has a shadow of the image displayed.
  • Screen looks 3D
69189a5.pngSOLUTION
Please do us a favor and rate this solution after reading
May 20, 2011 | RCA P55000 55" Rear Projection Television
RCA tv model P529374 from 2002 has a picture that looks concaved or warped and the letters have shadows. What causes this problem
  • Screen looks 3D
69189a5.pngSOLUTION
Dec 09, 2010 | RCA P52937 52" Rear Projection Television
Rca d52w20 convergence is not working. The auto and the manual adjustments won't work to fix it. The repair guy said $400.00 to $500.00 to fix. That seems affually high. Is this somrthing I can do myself?
You can fix it yourself for less than 45.00 by getting a simple repair kit from www.TvRepairKits.com
  • Screen looks 3D
Aug 21, 2009 | Televison & Video
Distorted picture on RCA LCD TV
I have the same tv. Had repair man come to my home in late april. Said it is the power convergence board. $225 for parts and labor I was told. Bad thing is part was supposed to arrive mid-may,then mid-june and now mid-july. He say's part is on back order. I'm actually going to contact RCA soon to find out if this is true. This seems to be a common problem with this particular T.V
Mar 07, 2008 | RCA P52937 52" Rear Projection Television
Televison & Video Logo
35 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
