Question about ViewSonic VP920b 19" LCD Monitor
Power button on view sonic monitor does not power up the monitor; is it repairable
  • 742 Answers
Please check the power cable if it is not loose. Also check the power switch if it is working. The power switch button for your monitor could have been damaged. But yes, it is replaceable.
Posted on Feb 02, 2010
PROBLEM IS VIEW SONIC MONITOR WERE OSD LOCK
osd lock is on screen configuration menu (on screen display) to clear an osd lock in your view sonic you can try this step
1.disconnect power cord
2.press and hold button 1
3.plug again your power cord
4. press your power button while still holding button 1
hope it help you
May 12, 2011 | ViewSonic E70f 17" CRT Monitor
I have 2 View Sonic 32" LCD monitors that are used as televisions. One of the monitors randomly turns off, and takes a couple of attempts to power back up. The other recently just quite powering up,...
You may have power supply problem due to bad caps, open it up and look at the power supply module for bulging top or leaking. To have it repair will more likely to be over $100 plus parts if you can find the shop to repair them.
See what usually fails in monitors and TV: http://s807.photobucket.com/home/budm/allalbums
Mar 26, 2010 | Computers & Internet
Need a power supply for View Sonic VX922. Where
Here is a link for your View Sonic power supply:
http://www.shopzilla.com/laptop-power-adapters/viewsonic-power-supply/9177/products
It should have a replacement for you.
Jan 30, 2010 | ViewSonic VX922 19" Monitor Flat Panel
View Sonic Monitor
This model has a know issue with the power supply. Check out our repair guide at: www.ccl-la.com click the monitor repair link and then go to page 2, its listed under the Wetinghouse LCM-22W3 monitor, they use the same power supply - DAC-19M009. If you can solder then you should be able to do the repair yourself. If you don't want to do the repair we do offer a repair service for $35 plus return shipping.
I hope this helps, If so please rate our solution.
Buddy
Corporate Computer
www.ccl-la.com
Dec 28, 2009 | ViewSonic VX2235WM Monitor
View Sonic VA720 monitor goes out after power goes
replace the logic board, not the power supply board. you can find logic board on ebay as low as $29...
Nov 15, 2009 | ViewSonic VA720 17" LCD Flat Panel Monitor
My view sonic monitor does not work properly
sounds like the power supply inside of the monitor is going bad. did you replace the cable from tv to the wall?
Oct 16, 2009 | ViewSonic VX922 19" Monitor Flat Panel
View sonic monitor gets contrast/brightness blue box in middle of screen
Its an issue with the OSD menu button or the circuit, tap the button a couple of times, it may resolve the issue as it may free up the jammed button. Else its a circuit issue, also check any loose connections. It may need a repair.
Regards,
Shrey
Oct 09, 2009 | Computers & Internet
View Sonic VX910 LCD Monitor - Power Supply Board
I have been repairing them through ebay due to the fact that they are not available to buy right now.
They've been out of stock for what seems like forever !!
bammbammfran
Oct 20, 2008 | ViewSonic VX910 19" LCD Monitor
Sound on the View Sonic Monitor
Yes, they are on the front of the screen. There should be a volume up and down button right on the front (usually to the left of the power). If there isn't a separate up and down, try the Menu or 1 and 2 buttons.
Aug 18, 2008 | ViewSonic 19.0" VG910B 1280X1024 TFT LCD...
In my 15" view sonic
If you don´t have any mechanical problem with the push botons, try individually :
Power Off the monitor and press the "menu" switch, over 20 sec after the power in turned on!
v15307086
Jun 07, 2008 | Gateway FPD2275W LCD Monitor
ViewSonic VP920b 19" LCD Monitor Logo
117 people viewed this question
Top ViewSonic Computers & Internet Experts
mukhtar21 shaikh
mukhtar21 shaikh
Are you a ViewSonic Computer and Internet Expert? Answer questions, earn points and help others
