Question about Kenmore 73952 Gas Dryer
Dryer heats up but cloths stay damp
Kenmore Elite Oasis ST heats up but cloths remain damp after cycle. Not s using Touch/STEAMCARE/Refresh setting
    Scholar:
  • 91 Answers
Disconect dryer from electric outlet first before doing anything to it!!
check ur outside exhaust vent on the house, might be full of lint, if is ok then check the duct on the back of your dryer, might be full or lint, take an leaf blower an blow all the lint off the air duct, an also if you are handy, remove the 12 or 14 screws of the back of the dryer , take the back panel off, and on your left side u will see the air port where the hot air comes off the dryer take the aditional 4 screws an clean it
then put it back together
if you still have the problem then u have bad coils
what happens an air restriction will cause the dryer not to work properly, it will overheat an shut off. but am more sure u need coils specially if u never got em replace, maintance doesn't hurt at all......
good luck leave some feedback thanks!
Posted on Feb 02, 2010
How to replace a heating element on a Kenmore Elite Oasis ST dryer
Sounds like you need to replace the timer one the dryer not the element but to make sure I would do a little trouble shooting to rule out the element or heating coil turn on dryer cycle like normal for about 30 seconds then open the door to feel for heat if you do feel heat its your cycle/timer knob if you don't feel heat then it's the coil or element witch are the same also first always check your lint trap and ducts going outside the dryer make sure you have proper airflow through ducts vents. clogged vents ducts ect. Cause over heating of element coil causing a safety fuse to shut down heating coil/element but will not stop cycle also moisture censors detect moisture causing cycle to continue on hope this helps.
Sep 04, 2014 | Kenmore Elite Oasis 6808 Electric Dryer
Dryer is set to run 40 mins when it shouts off at 0 on the dryer is has only run 20 mins according to my stove timer
Dryer has a moisture sensor that detects the clothes are dry so it shuts off earlier. If the clothes are still damp then the dryer vent may be plugged and causing the unit to run hot or not able to fully evacuate the air from the machine. Clean the vent and make sure it's completely free and try again. If it short cycles again and clothes still damp you may have a sensor controller issue.
Jun 16, 2014 | Kenmore HE3 Steam 7.2 cu. ft. Super...
LOW HEAT NEVER HAVE DRY CLOTHS AFTER A FULL CYCLE
Check to see that there is no lint buildup in the vent and internal duct work. Any restriction will cause a slow dry process.
Mar 30, 2012 | Kenmore Elite Oasis ST 7806 Dryer
Sears kenmore elite oasis dryer 110 67032600 check lint screen flashes doesn t heat
Check the vent on the back. This is indicating a air flow issue. If the vent is clear ohm the heater out check it for continuity.
You can watch a video that explains how to complete this repair on your sears Kenmore Elite clothes dryer at the link below.
Sear Kenmore Dryer Video
Mar 11, 2011 | Kenmore Elite Oasis ST 6807 Dryer
My Kenmore Elite Gas Dryer in Refresh mode the cloth comes out wet.
I think the refresh mode is a no heat tumble only setting... just to fluff your clothing...
if they were wet they will not dry on that setting...
heatman101
Aug 27, 2010 | Kenmore Elite Oasis 7808 Gas Dryer
What does ''L2'' stand for shown on Kenmore Elite Oasis st?
you can call sears parts service and they can tell you what code means
Aug 19, 2009 | Kenmore Elite Oasis ST 7806 Dryer
Just inherited a kenmore elite oasis dryer model 110 77092600 Where can I get a user manual? Could be online. I called Sears and they want $18 to order one!!! Kenmore charges also.
searspartsdirect.com - and enter your model #.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Jun 22, 2009 | Kenmore Elite Oasis ST 7806 Dryer
Kenmore Elite dryer heats but does not dry
Make sure that your vent tube is not kinked or crushed behind the dryer and it all this is ok then you need to change your cycling thermostat. is it gas or electric
Mar 12, 2009 | Kenmore Dryers
Kenmore 73952 Gas Dryer Logo
121 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal DeAngelo
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
