Question about Lexmark Z2420 Printer
Why do i have to use a usb to be alble to print
T computer says documents pending but willnot print
Posted on Jul 23, 2010
    Brigadier General:
  • 10,406 Answers
The printer has to receive "data" and "commands" from your computer. The USB interface is used to transmit what the printer needs to receive. Other possible data-transfer interfaces, e.g., wireless, or parallel, may not be installed in your printer.
Posted on Feb 02, 2010
John Deere 4230 new starter replace battery also and still will not start
Ignition switch, connections at switch, or small post on the starter solenoid, or wire broken between the two. Or possible bad "new starter solenoid". It's been a problem for other starters. May be a bad batch of solenoids. You may be alble to veryify the solinoid by a jumper from the positive battery terminal or cable to the small post solinoid terminal. If it activeates the starter, you know the solinoid and starter are ok and the problem is the wire or connection to the starter switch. If you had problems before, It may be a bad ignition switch and the internal starter switch. Did you test the old starter? you may not have needed to replace.
Mar 27, 2015 | John Deere Garden
Dodge charger phone list
Take it to dodge they will have to reset the firmware
Mar 06, 2014 | Cars & Trucks
Showing all three colors in the picture red,green,blue how do you correct this?
This symptom is what is called convergence. These sets have a common problem with convergence. This may be a simple problem however you must first determine if you have the fl231 fuse problem. First question that you need to ask is"in the customer setup menu do you have the "convergence option" if you do you might be alble to restore it with automatic option. If you do not have the option then i suspect you have the fl231 fuse problem and you need to read this : http://www.fixya.com/support/r1062030-fl231_problem_convergence_not_in let me know if this help and if i can be of any more help
Feb 22, 2011 | RCA HD52W59 HDTV Projection Television
Red light stays on and speaker does not work
faulty power supply unit, b and w should changed to fix this problem, contact point of sale or b and w service desk. you will not be alble to do anything until this is fixed.
Jan 24, 2011 | B&W Bowers and Wilkins Zeppelin iPod Music...
Right front passenger window will not go up on Ford Expedition 2005. Driver window OK.
Is this with both controls or just onesided? Open door panel and check for loose connections. You'll need a screw driver to check the tension on the motor,as you can adjust the armiture and may be alble to get it to work. If so you'll need to have the motor checked out for shorting. Also look for any binding of the gear assembly as for broken spacers and slides which are nylon
Mar 23, 2010 | 2005 Ford Expedition
I need to know what fuse supplies power to the electric brake controler. I blew the fuse wiring the controler 2004 super duty
A diagram with fuses and where they go came in the manual when the truck was purchases. Go on line and you should be alble to look it up and Google.
Nov 19, 2009 | 2003 Ford F350 Super Duty DRW SuperCab
WHAT KIND OF WIRES DO WE NEED TO HOKUP A LEXMARK X3350 ALL IN ONE PRINTER.
Standard Ports USB Compatible with USB 2.0 Specification (Type B)
Optional Network Ports Lexmark N4000e Fast Ethernet (Print Only)
Lexmark N4050e 802.11g Wireless Print Server (Print Only)
According to:
http://www.lexmark.com/lexmark/product/home/277/0,6970,204816596_653399443_473191701_en,00.html?tabId=1
Sep 10, 2009 | Lexmark X3350 All-In-One InkJet Printer
What does the 4th light ,not counting the 2 larger button, means
4th light? plz be more specific and i might be alble to help you thank you
Jul 28, 2009 | Office Equipment & Supplies
Lexmark Z2420 Printer Logo
103 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
