Question about Krups XP2070 10 cup Coffee Maker/15 bar Pump Espresso
Need schematic on main board connections: Krups XP2070 coffee mak
On the Krups XP2070 coffee/ expresso maker I need to know where to connect J3 white wire cluster from control panel on new main board. Is it J6 or J3 on the main board?
SOURCE: Krups Caffe Bistro 867 Expresso & Coffee Maker INSTRUCTIONS
http://www.krupsusa.com/All+Products/Coffee+Machines/Espresso+coffee+machines/Products/867+Bistro/867+Bistro.htm
Posted on Aug 21, 2008
  • 279 Answers
SOURCE: We have a krups combo expresso and coffee maker. I
When is the last time you cleaned it out w/ vinigar?
Posted on Sep 18, 2009
  • 12 Answers
SOURCE: no power at all on my krups xp2070 coffee maker
Most likely you need a new power module. Not easy to do yourself and it could be dangerous if you are not careful. The replacement module cost $50 to $60 and if this is the main problem it should be worth fixing. I don't know how much the service centers charge to replace the unit.
Posted on Dec 18, 2009
  • 39 Answers
SOURCE: my Krups combo espresso/ coffee maker xp2070 will
Do you have power to the control module? Can you set the time or is the display completely dead? Mine was completely dead and I replaced the power module and the display/control module.
Posted on Dec 29, 2009
  • 39 Answers
SOURCE: Cannot power up a krups xp2070 coffee/espresso maker
I did not find a repair manual. Most likely you need to replace the power module or the control module. They sell the power module and control module for < $60. It is difficult to replace but not impossible if you are good.
I have a krups xp2070. The espresso side powers
Sadly FIXYA has no clue as to your abilities to repair , and most times we find that coffee makers are not consumer repairable anyway
Jan 21, 2018 | Coffee Makers & Espresso Machines
Need Manual for XP2070
http://www.krupsusa.com/Consumer+Services/Product+Support/Results/Manuals/ResultManuals.htm?SelectedService=Manuals&SelectedGuIDService={36EDBCD3-43C5-49F9-916A-09483F86C4FB}&SelectedProdRef=XP2070Click the link and click the Black and Green Icon to download.
Nov 19, 2011 | Krups Coffee Makers & Espresso Machines
Where can I buy the water flow meter When I start the machine, it warms up properly and after the lcd shows it ready, I select the numbre of cups I want. Unfortunately, the machine only pumps a small...
Same problem I have, flow meter! you could buy it @ http://www.smallappliance.com/product.asp?pid=13677&cur=USD&cam=krupsusa although I am not sure which cluster you would connect the flow meter to the power board. My husband and I have opened the machine and we forgot to reconnect the flow meter to the power board. If you could take a look for us either J3 or J6 I will be more than happy to know. thks
Mar 24, 2011 | Krups XP2070 10 cup Coffee Maker/15 bar...
My Krups Model XP2070 has no power. I am an electronics tech. Does anyone have or know where I can find a schematic for the power module?
1800Parts.com has the schematic and we have all the parts too. We are open to answer any questions that you might have as well. It could be a problem with the board or power supply.
Jan 20, 2011 | Krups XP2070 10 cup Coffee Maker/15 bar...
When I try to make espresso with my new XP2070, water comes out through the steam arm and not through the nozzles. I've tried it without coffee and all the water still comes out through the steam/hot water...
David, the XP2070 won't operate properly until you've set the clock on the unit.
In case you don't have an owner's manual, I've attached a copy of the manual from the Krups site that you can download and print for free.
Please take some time to reaquaint yourself with the setup and procedure for using the expresso portion of the unit, as you might just have some sequence issues that is preventing the expresso from getting brewed.
Otherwise, it could be that the unit has a faulty seal in the pressure vessel that isn't allowing the expresso side to function properly, hence the reason the water might be coming out of the frothing tube instead of through the expresso brewing section.
http://www.krupsusa.com/NR/rdonlyres/C308FB44-1EC6-4119-A060-C73BD65F4789/7355/XP2070espresso.pdf
I hope you find this Very Helpful and best regards!
Nov 09, 2009 | Krups XP2070 10 cup Coffee Maker/15 bar...
No power at all on my krups xp2070 coffee maker
Aug 11, 2009 | Krups XP2070 10 cup Coffee Maker/15 bar...
I have a krups xp2070 coffee/expresso maker just stopped working
Most likely your power module failed. Mine went bad after 18 months of operation. You can order a replacement power module and control module from a Krups service center or from SmallApplicance.com. The replacement is not easy since you have to disconnect all the electrical connections. The module is about $60. I don't know how much the service center will charge to replace it.
Jun 13, 2009 | Gaggia Syncrony Logic 74884 Espresso...
Dead Krups XP2070
I think you are right. Most likely the power board at the bottom. I saw a post about replacing the transformer but I when ahead a replaced the power module to fix mine.
Jun 07, 2009 | Krups XP2070 10 cup Coffee Maker/15 bar...
Krups XP2070 - expresso part - timing
It sounds like your flow meter is not working properly. Most likely it goes for about 5 seconds, stops and starts blinking with all the icons on. You can replace the flow meter and get it working again.
Dec 29, 2008 | Krups XP2070 10 cup Coffee Maker/15 bar...
Krups XP2070 10 cup Coffee Maker/15 bar Pump Espresso Logo
114 people viewed this question
Top Krups Coffee Makers & Espresso Machines Experts
Billy Mac
Ross Keen
Are you a Krups Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
