Question about HP TouchSmart IQ770 PC Desktop
I have HP touchsmrt with a key pad model #RK713A. There is a delay time between bottons pressed and appearing on the monitor. Sometimes the charactors do not appear on the screen
  • 36 Answers
There may be a setting problem on your computer.
Check in the control panel.
Posted on Feb 13, 2010
Need self-cleaning instructions....missing manual.
To Self-Clean: 1. Close the oven door. 2. Move the door lock lever to the right to the locked position. 3. Press CLEAN. 4. Press the "up" or "down" arrow pad. CL-M (Clean - Medium soil, 3 hours) appears in the display. If the door is not closed, beeps will sound and "door" will appear in the display until the door is closed and the Clean pad is pressed again. If the door is not closed within 45 seconds, the self-cleaning operation will be canceled and the display will return to the time of day. If more than 5 seconds elapse between pressing the Clean pad and the "up" or "down" arrow pad, the program will automatically return to the previous display
5. To choose a clean setting other then Medium, press the "up" or "down" arrow pads to scroll through the self-cleaning settings. CL-H (Clean - Heavy soil, 4 hours) CL-M (Clean - Medium soil, 3 hours) CL-L (Clean - Light soil, 2 hours) Choosing a cleaning level automatically programs the selfcleaning time. 6. After 4 seconds, the oven will start cleaning. "LOCK" and "CLEAN" will appear in the display. The cleaning time will count down in the display. To Delay Start Self-Clean: Before delay starting Self-Clean, make sure the door is closed completely or it will not lock and the cycle will not begin. 1. Press DELAY. "DELAY" will flash and "00:00" will appear in the display. 2. Press the "up" or "down" arrow pads to enter the amount of time you want to delay the cycle. Delay time can be set from 10 minutes (00:10) to 11 hours and 59 minutes (11:59). 3. While "DELAY" is flashing, press the CLEAN pad. "CLEAN" will flash in the display. 4. Press the "up" or "down" arrow pad. CL-M (Clean - Medium soil, 3 hours) appears in the display. 5. To choose a clean setting other then Medium, press the "up" or "down" arrow pads to scroll through the self-cleaning settings. CL-H (Clean - Heavy soil, 4 hours) CL-M (Clean - Medium soil, 3 hours) CL-L (Clean - Light soil, 2 hours) Choosing a cleaning level automatically programs the selfcleaning time. After 4 seconds, "CLEAN," "DELAY," and "LOCK" will appear in the display to show that the oven is set for a delayed clean operation. The delay time is displayed
Apr 21, 2015 | Kitchen Ranges
Tip
How to reset an HP printer waste ink tank aborber (only work on certain models)
Press and hold the '*' key on the key pad,
then press the '#' key and release them both.
Then enter '123' to enter maintenance mode.
Press the right arrow (beside the OK button) until System Config menu appears on the panel.
Then press OK two times to clear the error condition, Then press cancel two or three times to return to the top menu.
Then power off and back on, print a test page
If this does not work there is another method that may work I have posted a TIP for as well.
on Jan 02, 2010 | Office Equipment & Supplies
GE SPACEMAKER MICROWAVE OVEN MODEL J VM64 003 LIGHT SWITCH BROKE HOW DO I REPLACE IT?
Unfortunately it appears none of these parts are avail anymore. The physical buttons, key panel assy, touch pad support are no longer available. The smart board (WB27X5239) seems to floating around, but this does not appear to contain either of the 2 buttons or switches as part of it's assembly. Pleazer Appliance..
Jan 11, 2015 | GE Microwave Ovens
Wireless Keyboard HP RK713A not typing correctly
Try going to Device Manager. Right click on the Keyboard and choose Properties. Click on Update Driver as it might find something (let it look online also). Reboot the computer. If that doesn't work, go to Device Manager, right click on the keyboard, choose Uninstall, and reboot the computer. When the computer starts up and sees the keyboard and loads a driver(s) for it, it might fix it. Good luck.
Jan 15, 2018 | HP Computers & Internet
What are the appropriate steps to connect an external monitor to an HP Pavillion DV2000? When I try, nothing appears on the external screen... Thanks, RF
One of the function keys has a small monitor screen icon. Press that key while holding the Fn key, and you will enable the external monitor connector. These laptops don't automatically sense when you've connected an external monitor. On some models, the first press enables the external monitor and shuts off the laptop screen. If that happens, press the keys again and the laptop screen will come back on.
Oct 14, 2010 | HP 417035-001 - HP Pavilion dv2000 Series...
How do I unlock a wireless keyboard
On the keyboard you will find a lock sign key on the kayboed press that one.
Jan 13, 2010 | HP USB Wireless Keyboard/Optical Mouse...
Change batary lost desplay of charecrers
You can reset the calculator:
Turn the back of the calculator towards you. Extract the top left rubber pad on the back of the calculator and use a paper clip to press the Reset button. If that does not restore the calculator to health, you should perform the dagnostic tests.
The following procedure valid for the 48G should work for the HP48GX.
Make the calculator perform a
Self test.
  1. Turn calculator on
  2. Press and HOLD the key [ON]
  3. Press and release the key with "E" to its right (the one before last in first row)
  4. Relaese the [ON] key.
It tests the RAM and ROM. You will see various patterns on screen. Afterwards you should see
IROM OK,
IRAM OK,
HP48GX OK
The self test will continue repeatedly until you perform a
System Halt
  1. Press and HOLD the [ON] key
  2. Press and release the "C" key
  3. Release the [ON] key.
The empty stack should appear.
If you do not see IROM OK and IRAM OK, the calculator requires service.
If the above procedure is successful, you may want
to test the keyboard.
  2. Press and HOLD the [ON] key
  3. Press and release the "D" key.
  4. Release the [ON] key
  5. Press and release the "E" key. KBD 1 should appear on the top left corner of the screen.
  6. Starting at the upper left corner of the keyboard, and moving Left to right, press every key in sequence. If you follow the sequence and the keys are functioning properly you should hear a hight pitch sound at each press.
  7. If everything is OK, when you press the last key (+) the screen displays KBD 1 OK.
To exit the keyboard test proceed as described above under System Halt.
If you follow the proper sequence and a hexadecimal number appears after pressing a key, the calculator requires service.
Hope it helps.
Aug 10, 2009 | HP 48gx Calculator
I have hp dv2000 laptop with nvidia g6150 dual view monitors and when i switch to my hp l1706 LCD monitor the screen will appear then shut off after a couple of seconds sometimes it will work for about an...
when u connect the monitors try to follow these instructions ok
1) u must logged to the windows
2) after 2 min from logging
3) press and hold the "Fn" button then at the same time press "F5" button for about 10 seconds
4) if nothing happened try the 3rd instruction till the screen will appear
hope this helpfull
good luck
Jul 29, 2009 | HP Computers & Internet
Proline locking issues
The Proline manual (comes on a CD with the player) says:
6.3.7 Key lock
This function sets a time delay from when key lock function is started or the player is switched on, after which the player will automatically stop responding to the control buttons. Pressing any button will then display the message ‘Locked’. Key lock is useful, for example if you put the player in your pocket and don’t want any buttons to be pressed accidentally. The time delay is to let you start playing the music and so on. You can choose a delay of ten or thirty seconds, one, three or ten minutes, or you can disable key lock completely. •
Press and hold the V+ button for a couple of seconds to temporarily unlock the keys.
Mar 17, 2008 | Audio Players & Recorders
HP TouchSmart IQ770 PC Desktop Logo
1,247 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
