Question about Motorola Mobility Hint QA30 Cell Phone
Good evening I have a Hint qa-30 phone and I can not get iy to turn on it loads as far as the M then just keeps blinking on and off and thats it any ideas?
  • Charles Osborn May 11, 2010
    have you removed the battery for 3 min then replace and let it reset its self?
    Problem Solver:
  • 5 Answers
This is due to either an uncharged battery or a bad battery i suggest you charge it for an hour or replace the battery
Posted on Feb 03, 2010
1999 Durango left blinker blinks real fast right blinker normal all bulbs are good and operate what's the problem
You have a resistence problem in the wiring or bulb socket. The flasher relay will blink faster if it has less electrical load. With a volt meter check the amount of voltage you have on the ground side of the bulbs with the signals operating. Should read almost no voltage .1-.2v. Check the same on the good side for qa reference voltage. Trace the circuit with the higher voltage reading to find the voltage drop.
May 24, 2014 | Cars & Trucks
Tip
I had a lots of lint, hair, bottle cap, stones, jewelry, coins, broken Christmas...
This advice is for Kenmore Elite and Whirlpool Duet model FRONT LOADING washing machines. If you experience a problem where the washer does not drain properly or the drain pump makes excessive noise, here’s the information you need to check the drain pump:
Symptom: PUMP IS RUNNING, BUT NOT DRAINING PROPERLY.
  1. Unplug the washer while servicing inside the unit.
  2. Remove the lower kick panel under the door by removing the three 7mm screws under the bottom edge of the panel. HINT: Use a couple of blocks of wood to prop up the front feet of the washer to gain better access to the screws. Once the screws are removed the panel should drop down, and then pull off. If the panel becomes stuck, a slight tap on either side will dislodge it.
  3. Locate the drain pump. It will be located directly under the wash tub (it is the only pump this washer has).
  4. There is an access removal cover on the pump that can be removed to clean out the trap. BEFORE doing this, it is strongly recommended that you remove all residual water from the wash tub & drain line or you will have about a gallon or so inside your washer and on the floor to clean up.
  5. Here’s a helpful way of quickly removing the residual water. If you own a wet/dry shop vac, remove the drain hose from the standpipe at the wall and pull a vacuum with the shop vac. This will empty the wash tub, pump and drain lines. If you don’t own a shop vac, grab a bunch of old towels and open the access on the pump slowly so that it comes out at a trickle. Allow the towels to soak up the majority of the water. Close the access and stop the water if you need to get additional towels.
  6. Open the pump access and remove once you have all the water drained. Check the drain pump for foreign objects and debris. Check the pump impeller and make sure there’s nothing caught in it. Items as small as toothpicks or cotton swabs have been known to stop this pump from working.
  7. Clean out the pump thoroughly and reinstall the access cover. Make sure the cover is snug, but do not over tighten.
  8. Place the drain hose back in the standpipe (IMPORTANT – DO NOT FORGET!).
  9. With the bottom panel still off, plug the washer back in and select the following on the operator console – DRAIN SPIN, NO SPIN, and then press any button under OPTIONS 4 times (it must be the same button). “C00” will show on the console display as the washer begins diagnostics mode.
  10. Check the drain pump for leaks as the washer fills. The pump is gravity filled and will hold water even it is not pumping. Allow washer to run through diagnostics until it begins the wash tub tumble cycle.
  11. At this point, you can stop the diagnostics procedure by pressing PAUSE/CANCEL 2 times. The drain pump energizes and the washer will begin to drain.
  12. If the drain pump works normal and there are no leaks detected, reinstall the bottom panel and tighten screws.
NOTE: It is normal to have residual water left inside the wash tub under the wash basket. This is why it is important to leave the door ajar when not in use so this water does not become sour.
on Feb 02, 2009 | Kenmore Elite 45986 Front Load Washer
Problems with dicovery 925 keep blinking purple light and can't pair with the phone help
Something you may want to try is start from the beginning. Check to make sure there are no other bluetooth devices loaded onto your phone that might interfere with the process. Turn off your phone. Disconnecting the battery of your mobile for 30 seconds and reconnecting helps to reset the phone. The instructions for turning off the headset and re-pairing the two devices are located in the following link for the Plantronics Discovery 925 User's Guide.
Good luck from Headsets Direct!
Sep 03, 2011 | Plantronics Discovery 925 Bluetooth...
My time changed with day light savings, but my phone has not seemed to recgonized this and it says its an hour ahead of what it should be. how do i change it to the right time?
The Time on the Motorola QA 30 Hint is controlled from the Network, so there is no way for the user to manually adjust it. Try turning the phone off for a few seconds, and when it boots back up, the time should be updated. If not, it might take another hour or two, but it will eventually be correct.
hope this helps
R
Nov 07, 2010 | Motorola Mobility Hint QA30 Cell Phone
My samsung phone SCH-S379 not starting up. The model number keeps blinking continuosly even while charging. removed the battery and put it back. no result
There seem to be a problem with the phone, that is why it keeps blinking and not turning on whenever you try to turn it on.
The problem is a software problem and mainly is that there is a virus on the phone, virus can be contacted either by file transfers via bluetooth and other means or from file downloads from internet.
The solution to the problem is simply for you to get the appropriate software and cable, then you flash the phone.
After flashing the phone, it will come become normal once again.
Take care and good luck
Oct 31, 2010 | Cell Phones
My printer (Epson R800) keeps on giving me the error 'Media not loaded correctly'. Even before it's even tried grabbing the paper, it starts blinking red on the paper/trash button. I've never had this
Please make sure that the paper that you are using is included under the printer's paper compatibility list.
Make sure that you are selecting the correct paper type on printer settings.
Trash and re-install the drivers.
Apr 29, 2009 | Epson Stylus Photo® R800 InkJet Printer
My phone just blinks vcast now
I work for verizon-take your phone to a verizon store, have them swap it out for a new one. If your phone is under warranty you should be able to swap it out for a new one. If you are in contract the WARRANTY IS GOOD FOR THE LIFE OF THE CONTRACT. Call our Customer care line, don't go back to the store.
Mar 31, 2009 | Samsung SCH-u740 Cellular Phone
My 2 month old 37" LG HDTV won't turn on...
just resolder capacitor then use a pc fan on iy
good luck
Dec 06, 2007 | LG DU-37LZ30 37 in. LCD HDTV
I have no clue on what happened!
Sounds like a huge tech. problem, I would contact your purchaser instantly, have you tried taking out your sim card and seeing if it still does this? Another this, If your phone got wet, It could be doing this, It has done this to me before, and If it did get wet I hope you have water insured! Ways to get water out are putting your phone in the freezer for a day - That is, if it got wet.
Nov 29, 2007 | Motorola Mobility SLVR L7 Cellular Phone
Motorola Mobility Hint QA30 Cell Phone Logo
60 people viewed this question
Top Motorola Mobility Cell Phones Experts
Virgil Wolter
Level 1 Expert
Rami Obeid
Level 1 Expert
D. E. Hev
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
