Question about Panasonic Televison & Video
We have an old 1987 J C Penney 27'' tv. Model # 685-2512. Still works fine but some channels have been blocked out and I don't know how to get them back. Could someone help with this please?
SOURCE: some channels have no sound some are in spanish
Had same problem, could not correct it with menu from remote. Pulled power plug for one hour, computer resets and can be reprogrammed when powered on.
Posted on Nov 30, 2006
  • 373 Answers
SOURCE: unlock code
Is there a reset buttom that can hold in after it is turn on , you may have to hold it for a few second
Then turn it off and back on again and see what happen.
Posted on Jan 28, 2009
  • 13 Answers
SOURCE: channel not increasing above 9
it sounds like it needs to be switched from ant to cable, here is a link to where you can download the owners manual http://esupport.sony.com/US/perl/model-find.pl?mdl=KV-2780R+
Posted on Apr 04, 2009
moeshere
  • 33 Answers
SOURCE: 27" sylvania tv stuck on one channel
unplug tv for about half a hour and replug it back in to reset it and see if that works..I also have that big remote and it worked find for me the first time so maybe tv just needs to be reset. hope that helps
Posted on Apr 05, 2009
  • 144 Answers
SOURCE: the picture has a green tint to it on all channels
The color signal consists of Red, Green and Blue. Those three colors, at various degrees, make all the other colors on your screen.
If you have a BRIGHT green screen it's best you don't operate your set.
If it's just tinted green then there is a problem on the CRT (Cathode Ray Tube) drive board. Do check your "tint" setting and see if someone misadjusted it. If that isn't it then you need to have your set on an electronics bench and get an estimate for repair.
Posted on Apr 17, 2010
I have a 7050 model JC Penney sewing machine. I can not thread the machine properly, because there are tiny loops appearing on the underside of the material being sewn? Help?
The only place I saw for your manual was at tias, relics. You can google it and see the one I saw, I think the cost was $17 for a reproduction copy, I don't know who else would carry it, but it will answer your questions on how to thread it properly. Without seeing it I am assuming that you do not have it threaded right, or it needs a new needle. I am sure that it is a good old machine and worth fixing, they don't make em like they used to. I am not sure who made your model, so it would be best to buy the exact manual for your particular machine. Sears and Penney's did not make their own machines, they had other manufacturers make them, like Elna, Singer Necchi etc. Sometimes you can even purchase a repair manual that a Penney's technician had, I did with an old Kenmore that I had, but alas, it only confirmed my suspician that the motor was shot. You may be lucky and find one somewhere else for less money but I don't have time to do more research. Good luck
Apr 15, 2011 | Sewing Machines
Need the unlock code to get channels on the t.v. model ku-27525. yr1996. sony trinitron..*** we're in desperate help..please
Have you used Parental control to block channels?
Maybe just go into the TV menu and unlock there.
If not and the TV is using a cable or Satellite box then just use Video 1 or others even channel 3 to get the channels from the box.
Today we have a lot of free digital TV from our old roof antennas you might look into that.
My own Cablevision on Long Island ,NY has lost 5 and 9 due to a dispute with their source but who cares I have digital from my roof antenna put up in 1965. Please let us know if these ideas helped.
I'm going fishing...>))'>
Sep 30, 2010 | Sony FD Trinitron WEGA KV-27FS100 27" TV
I have a toshiba standard tv 27A33. it has one
This television uses a feature called a V-Chip which allows parental control and consequently blocks channels of your choice. This set is approximately 7 years old and the owners manual is no longer available on line. You can over ride any blocked channel by entering the menu, select parental controls and enter the "secret" code. How one channel got blocked is a mystery. I suspect someone was exploring it's features when they accidentally blocked a channel. Normally the system control works flawlessly and if you have no other symptoms you need to reset that channel. That info is in the owners manual that came with your set.
Mar 30, 2010 | Toshiba 27A33 27" TV
Captions only on certain channels?
Closed captioning isn't broadcast on every channel and program, so the information may not be present. Since captions are displayed on other channels, you know the set is working properly. If you are on a cable system you can try asking their customer service people if they know anything. But the TV is fine.
Mar 26, 2009 | Zenith B27A11Z 27" TV
Lost the set up sheet
your tv might be very old so check the tuner curcuit for poor solder joints
Jan 16, 2009 | RCA TruFlat 27F520T 27" TV
Digital to Analog Change Over
you are fine. if you do not get a pic or sound it could be that the rabbit ears you are using are not compatable with your box. you may need a diff. type of rabbit ears
Dec 30, 2008 | Zenith C27A24T 27" TV
How do you reset a locked out channel when the code is forgotten?
Try pressing simultaneously the QV and 9 on the remote to bypass the parental lock. Then press the MENU button and go into the menu to turn the lock off. At least this is how it works on several other old Mitsubishi televisions. I don't have anything on ***********'s model, but this is worth a try. I hope it works for you.
Nov 12, 2008 | Mitsubishi Televison & Video
Channel Reception
1) Auto-program
2) Exchange under warranty
..........T.
Dec 19, 2007 | Sansui DTV2760 27" TV
Setting the channels
You can download the manual from the link below: http://safemanuals.com/download_94794.htm Please update the question & let us know if the information given was useful to you - Good Luck!
Aug 19, 2007 | Toshiba 27A34 27" TV
Televison & Video Logo
74 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
