Question about RCA P52937 52" Rear Projection Television
I have a RCA P52937 tv. I dint wanted to turn on. I was told to change the flyback and the H.O.T. transistor. I just did, now when i plug the tv i can hear a chirping for about 5 seconds then when i press the on button it sounds again and stops. Any solutions for this problem thanks
  • jguevara2749 Feb 02, 2010
    I keep on plugging in the tv until it finally work for 2 or 3 hours yesterday night. Right now on the morning i try turning it on and it wont turn on and i can hear the noise again. What should i do??? It did work yesterday very well??
    Thank You, Replacing the deflection board its expensive. i dont really know how the caps look like to replace them.
  • 4,889 Answers
The high pitched noise you have mentioned is definitely coming from the horizontal deflection circuit. Check the deflection circuits for any damaged capacitors on the deflection circuit. Cracked, leaky or swollen(at the top) if its electrolytic. SMD caps are more complicated. You should have a multimeter capable of measuring capacitance and equipped with a tweezer. Best thing would be just to replace all the caps on the deflection board. Should be around 15-20 of them.
Sai.
Posted on Feb 02, 2010
  • eagle338
    eagle338 Feb 02, 2010
    Did you try replacing the caps? If you want to get over with it quickly replacement deflection board should do the trick.
    Sai.
  • eagle338
    eagle338 Feb 03, 2010
    Sorry for the delayed response. Its 6.30 here in India and I just woke up. The capacitors look like little cans with sometimes with a "+" at the top. Since you have accepted the thread you may not be able to post further comments on it. But I am not gonna leave you stranded. Send your further responses to vls_powerful2002@yahoo.co.in and I will see you through this.
    Sai.
No power and their is a beeping noise coming from the back of the tv.
The beeping is usually caused by failed HOT Transistor and also possibly the flyback. You can get the Flyback and HOT repair kit from www.tvrepairworld.com
Feb 06, 2013 | RCA P52937 52" Rear Projection Television
Hi my rca p52937 won't turn on and is making a
The ticking sound is almost always caused by the Flyback and Hot transistor. It could be other items also located on the deflection board but flyback is most likliest. You can get a replacement flyback and Hot tarnsistor from www.tvrepairworld.com
Jul 07, 2011 | RCA Televison & Video
Find a horizontal output transistor or flyback
Flyback transformer part number for a tv RCA F32648
Mar 06, 2010 | RCA F32648 32" TV
My 60' RCA big screen won't turn on and it has a ticking noise coming from the back, like if it's a bomb
the ticking noise is a shorted horizontal output transistor which is loading the 140 source from the power supply
and its a good bet your flyback transformer is bad also
if its a ptk195
its repairable and the parts are available the transformer wil be a after market and if your going to try and repair it your self make sure you get a hr there a better transformer
Oct 28, 2009 | RCA P52937 52" Rear Projection Television
Where can i get a flyback for a rca 52 projection tv m#p52937yx2? I read all day and it seems to be the fix? wont go on and has a clicking sound that persists untill you unplug it.
1.) RCA no longer sells this part--a company called ASTI makes a replacement for the RCA #250694---they call it #2086
2.) If you go to Ebay you will find seller "sewsales55" sells this replacement transformer for 19.95 plus shipping--type in search 250694 and you will see it--they sell lots of parts and give a 6 month warranty--fyi--If I was you I would check the HORZ output transistor--usually it is bad also---I have repaired dozens of these sets with this trouble-usually just the flyback transformer and the output transistor.
If you need help or have questions let me know.
I do this here for free so if this helps you take just a minute and give me a vote here.
SD TECH
Sep 09, 2009 | RCA P52937 52" Rear Projection Television
My 36' RCA TV JUST QUIT WORKING. TURNED ON POWER
A shorted horizontal output transistor or shorted flyback. If the flyback is shorted replace also its HOT.
Apr 05, 2009 | RCA F36650 36" TV
RCA P52937 Flyback Transformer question
The lead going from the flyback to that other device is a voltage divider or splitter as they're incorrectly referred to... To remove the leads press down firmly, twist and then pull up...
Bill
Nov 21, 2007 | RCA P52937 52" Rear Projection Television
Rca 36 " F36650
horz output transistor goes out with the fly
Nov 20, 2007 | RCA F36650 36" TV
Rca p52927 chassis ptk 195 wont power up all of a sudden
ctc chassis with the 195 chassis were famous for flyback transformer shorting and taking out the horizontal output transistor also.
Oct 24, 2007 | RCA P52937 52" Rear Projection Television
No power
The P52937 uses the PTK195 series chassis. If the TV makes a squeeling noise the instant it is plugged in then unplug it immediately and do not plug it back in. I have seen this many, many times. The flyback (high voltage) transformer has shorted out and the extra current it was drawing has shorted out the horizontal output transistor, so the B+ supply is dead shorted and the power supply squeels as a result. This is very common in that chassis. The flyback and output transistor will have to be replaced by someone with experience in RCA projection TV's. The HV block in the PTK169 sets is the one known to be bad a lot - the block in the 195 is very reliable and I have never seen one of those bad.
Jul 05, 2007 | RCA P52937 52" Rear Projection Television
RCA P52937 52" Rear Projection Television Logo
118 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
