Question about Craftsman 24 Hp 48" Deck Yard Tractor
Carburetor adjustment for craftsman snowblower model 247.888530. Runs lean.
4 Suggested Answers
SOURCE: drive chain loose and poped offmy snowblower
Two things you can do. First if you look close you may see a spot where you can adjust the chain tension. Nest your chain should have what is called master link. Look close and you will see a clip that undoes the link. Pull the link out and the chain will come apart. If you are not mechanically inclined take it to any small engine shop and they will take a link out for you and then you will be home free.Hope this helps. donnyb60
Posted on Mar 23, 2009
SOURCE: possible carburetor problem? Mower runs for
i have a lt 1000 2005 when i start it with cold engine it boggs for a minute then it starts to run smoothly please help me
Posted on May 08, 2010
  • 760 Answers
SOURCE: Craftsman II model 917255911. Will
I couldn't find the manual for your tractor but I did fiind one for a 917255917 model it calls for a 71-25231 snow thrower. The 842 model you listed must not be complete number. There are several different models that start with 842. Does your tractor have the horizontal engine that has clutch on front, and drive pully on rear of engine? I used to have one like that and I had a sears blower on it. You'll need wheel weights and chains too.
Posted on Sep 24, 2010
Craftsman snowblower model 247.886940 runs like choke is sticking
It's possible the choke is sticking and the shafts could need lubricating. Check the float as will it might be sticking Is there an adjusting screw on the carb the fuel adjuster may need to be readjusted to run leaner.
Feb 24, 2018 | Craftsman Garden
How do I adjust a craftsman snowblower carburetor
there is a screw that regulates air fuel mixture and another for idl,
normally you close the mixture screw and then open it 3/4 way
if you have cleaned the carb correctly and relpaced parts correctly you should be able to adjust idl with the idle screw
Nov 07, 2017 | Craftsman Garden
Craftsman chainsaw chainsaw troubleshooting .....mine runs with choke on but speeds up and cuts off when i take choke off?
Denise,
Check to see if the boot between the carbureator and the engine has a crack in it, if it is cracked air will leak in causing a lean mixture and hard starting. Also will not run unless the choke is on.
Mar 30, 2014 | Craftsman Garden
Adjust choke
I am not sure about yours but my Craftsman has a adjusting screw in the carb to set the gas. If it is choking you screw it in a little and if it falters screw it out a little. You should be able to adjust with it running. Just turn a little at a time. Mine uses a flat screw driver.
Jan 22, 2014 | Garden
Craftsman snowblower throttle problem
Sometimes on them the throttle shaft which goes in to the carburetor gets rusty and turns hard. If you can't move the throttle butterfly by hand spray pb blaster around the shaft and move it back and forth to unstick the butter fly shaft.
Jan 12, 2014 | Briggs & Stratton Snowblower Snow Blower...
Back firing out muffler stalls under load
Could be a bad exhaust valve seat, sticking exhaust valve and possibly a lean running carburetor which is causing the engine to stall out on loads.
Jan 03, 2014 | Briggs & Stratton Garden
Need to know what size chain for drive on craftsman2 8hp 27" snowblower
Look on the unit and find the model number. It usually starts wit 917.
Find it and then go to sears.com and type in the model number.
Oct 22, 2013 | Craftsman Tecumseh Snowblower 7hp...
208cc b&g craftsman snowblower governor settings
sounds like last years ethanol gas messed up your carburetor.
Probably have to drop the carburetor Bowl and clean the Jet
Nov 22, 2012 | Craftsman Snow Blower / Snowblower Bottom...
Need carb setting wont idle runs in spurts
There is usually a sticker with a craftsman Model Number on it, often "358.Something". That number can be used to find an IPL and if you are lucky an OM here: Sears PartsDirect http://www.searspartsdirect.com/partsdirect/index.action Start at 1.5 CCW from lightly seated then tune for performance like this:
Carburetor Adjustment by Madsens.com
http://www.madsens1.com/saw%20carb%20tune.htm
CW is leaner; to lean will destroy the saw. If over tightened closed (CW) the adjustment screw faces are easily marred; marred adjustments are difficult to impossible to set properly.
Clean the air filter; adjusting with a dirty filter can cause a run lean condition once cleaned and the saw run.
There are 2 wav (sound - idle & full – may not be highlighted) files that I find most helpful, I think you will too. HTH
Lou
Feb 19, 2010 | Poulan Garden
Adjusting a Craftsman Snowblower Carburetor
crafsman snow blower have choke on to run it
Dec 17, 2008 | Garden
Craftsman 24 Hp 48" Deck Yard Tractor Logo
2,866 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Jim Parker
Jim Parker
Dennis Key
Dennis Key
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
