Question about Kitchen Ranges
We have a whirlpool range that commonly goes to PF and shuts off while in use. We can restart it agiain, but it is a pain when it keeps shutting off.
  • 619 Answers
Maybe bad solder joint at one of the L, (line or voltage), connections on the board. This is repairable with the use of a soldering iron if that is the case. Also check the connections at the power source to make sure connections are good. Other than this replace the control but check power first.
Posted on Feb 02, 2010
What dose PF mean
I would check the power to make sure of the polarity, two hots and a ground. Once that checks out ok and still has a problem, check the power cord connections in the dryer, that green wire goes to chasis ground or terminal N, G, and the solid color wires to the line 1 and line 2. If it still trips on PF, then a wiring diagram and tracing the power failure is needed, perhaps a control transformer but its too early to say now. Diagnose.
Feb 04, 2015 | Dryers
What when pf error come on
Hello & Welcome to FixYa
PF error means power failure which is generally caused when the control board inside the unit goes bad. You can try unplugging the unit for 15-30 minutes, if the issue returns then the control board needs replacement. Please get back to me if you have any other questions.
Kevin
Aug 01, 2011 | Whirlpool Gold GW399LXU Gas Range
We purchased a use stove, whirlpool Model #RF386PXEZ, went to plug it in and it flashed pf, then the plug sparkled and it shut off?? what could this be. Help??
Always shows PF meaning power failure when first plugged in. As for spark check to make sure nothing was knocked loose and grounded during move.
Feb 27, 2011 | Kitchen Ranges
I HAVE A NEW WIRLPOOL OVEN, AND KEEP GETTING ?PF? CODES I CALLED SERVICE AND THE REPLACED A SWITCH, IT WORKED FOR A SHORT PIRIOD OF TIME AND THE PF CODE RETURNED? SERVICE CAME BACK AND REPLACED THE PANL...
the next thing for you to check is your main power circuit breaker if you have one side of the breaker is bad or weak this will cause a power failure.also make sure the wiring to the terminal block is in good order and not damaged.the terminal block could have a problem as well.
Jan 24, 2010 | Whirlpool GY396 Electric Kitchen Range
Gas range shut off with PF on screen what does
The PF means there was a power failure, you should be able to clear this code by pressing the cancel button
Jun 04, 2009 | Kenmore 79012 / 79014 / 79019 Gas Kitchen...
Whirlpool Gas Range E2 F3
I HAVE A WHIRLPOOL GAS RANGE MODEL NUMBER SF379LEMS.OVEN WILL LIGHT UP BUT AFTER TEN MINUTES IT WILL KICK OFF ANF ON ON ,THEN AFTER AWHILE I WILL JUST SHUT OFF.ANY SUGGSTIONS. ADAM
Nov 23, 2008 | Whirlpool GS470LEM Gas Kitchen Range
Whirlpool GS563LX gas range
have you tried to hold the Night Light/cook top lockout for 5 seconds?
Regards
Sir Dana Taylor
jdtaylor@live
Apr 23, 2017 | Whirlpool GS563LXS Kitchen Range
Whirlpool Wall Oven sometimes power fails in middle of a baking session. Display goes blank and oven will not work for 10-20 minutes. Then oven will come back on with a PF readout.
Could be several things; 1. Electrical connections in oven are loose. 2.The circuit breaker for the oven could be failing. 3. The electronic control is failing. Make sure when oven is operating, the cooling fan is operating. If the cooling fan is not working, the electronic control will overheat and shut down.
Jun 01, 2008 | Whirlpool Kitchen Ranges
WHIRLPOOL SLIDE-IN RANGE
PF means power failure.  Usually you can hit cancel or clear and this will go away.  Let me know if this helps.
Oct 12, 2007 | Whirlpool RF378 Electric Kitchen Range
Kitchen Ranges Logo
87 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
paulcarew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
