Question about Lexmark X4270 All-in-One Multifunction Printer, Copier, Scanner, Fax
Lexmarkx4270 read erro 1203 check manul what the proble
    Problem Solver:
  • 15 Answers
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Power off the AIO and remove the power supply from the back of the unit. Wait 30 seconds, then reinsert the power supply, and power the AIO on.
Did the error message return?
Yes: Continue to step 2.
ue to Step 4.
Posted on Sep 07, 2010
  • Yilin Sep 07, 2010
    Since the solution is a little long, so it devides into parts as below:
    Solution Part1: Power off the AIO and remove the power supply from the back of the unit. Wait 30 seconds, then reinsert the power supply, and power the AIO on.
    No: Print a test page. If the test page prints, the error is resolved.
    Power off the AIO and remove the power supply from the back of the unit. Open the top cover of the AIO. Using the carrier belt, gently move the cartridge carrier to the middle of the unit.
Error 1203 on lexmark p6250 printer
Erro 1203 solution
1. open the front cover of the printer
2. wait for the cartridge carrier to be in the center..
3. remove the mono and color cartridge or printhead
4. clean the gold connectors or circuit on the printhead
next: power off the printer while the front cover is open .
5. then clean the printer cartridges carrier circuit ..especially those gold connectors....and reinstall the printhead or cartidges..
6. close the front cover and power up the printer..
Good Luck!
Feb 26, 2011 | Lexmark P6250 All-In-One InkJet Photo...
Comes up with erroe # 1203... what is that?????????????????
The error indicates either a communication failure between one of the cartridges and the printer or a short in one of the cartridges. To determine which is causing the problem, follow the troubleshooting steps on this link: http://bit.ly/aDUAjM. Thanks.
Aug 20, 2010 | Lexmark X5495 Printer
Hi my name is Hector,on my 2.5 inch display it say cartridge erro error #1203. I checked my users guide it dosnt say anything about error numbers.
Error 1203 is a very interesting error code. Here is what I found out about error 1203
It's mean your catridges overflow even from brand new catridges after a several prints or right after you refilled the catridges. Check to see if ink are smeared on the holder where the contact panel with the catridge. I have the same problem which I think lexmark have a problem and overlook.
Solution:
I use the klennex with a few drops of water to dampen and clean off those contact on the holder and my printer work again.
The refill ink work very well if you let it sit 24 hrs. Then before you print anything, you should run aligned the catridges a couple times then run clean catridges a couple times.
Print the test page to see how it's look and way you go.
Be sure not to leave any debris of klennex on those holder contact panel.
or try this other option:
Dell All-in-One Printer Cartridge Error 1203.
I found if you cover a copper contact on the color cartridge the error clears and the cartridge works. Looking from the contact side for the color cartridge 2nd row contact 2 from the left. I found if I use an ohm meter from 2nd to 3rd contact I measure 119 ohms. I believe that is a shorted cartridge. If you bought it New I would get it replaced. I use a SMALL square piece of Scotch tape. I believe this will work on Lexmark printers.
Jan 06, 2010 | Dell 966 All-In-One InkJet Printer
Error code 1203 , what dose error code 1203 stand for in owners manule
It could be this
Error 1203 is an issue that occurs either when a cartridge is bad or the printer cartridge Slot is bad...
1 - try cleaning the copper contacts of the both carts and cart slot in the printer and try again..
or
2 - when error shows up, shut the printers power off; wait one minute and turn it back on press copy.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Dec 22, 2009 | Dell 946 All-In-One InkJet Printer
I have error eading 1203 what is that and how can
I have an error reading 1203 that won't let me print. Message consult users guide.
Oct 08, 2009 | Lexmark X4270 All-In-One InkJet Printer
Lexmarkx4270 want work wit my window vista
Try this link below:
http://downloads.lexmark.com/perl/downloads/downloads.cgi
Select the county if the windows is displayed
Select Lexmark 4720 under drivers.
In the dropdown list you will see a link to the Windows Vista drivers.
Nov 30, 2008 | Office Equipment & Supplies
Lexmarkx4270 all-in one
Remove the black ink cartridge and examine the print head on it - you will probably find a small piece of tape (very thin) covering the jets - usually blue in color - remove it and reinstall the cartridge.
Nov 25, 2008 | Lexmark X4270 All-In-One InkJet Printer
I am getting a message error 1203
Try this first see if it will help.
ERROR 1203 LEXMARK ERROR 1200 Error 1203 is an issue that occurs either when a cartridge is bad or the printer cartridge Slot is bad...
or
Aug 02, 2008 | Dell 924 All-in-One InkJet Printer
Lexmark X4270 All-in-One Multifunction Printer, Copier, Scanner, Fax Logo
50 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
