Question about Whirlpool Duet GHW9150P Front Load Washer
Unlock controls whirlpool direct washer - Whirlpool Duet GHW9150P Front Load Washer
  • 15,935 Answers
This advise is for Kenmore Elite and Whirlpool Duet front loader washers and dryers with a Control Lock problem.
This may or may not be an indication of a serious problem. In the majority of the cases, this is a simple operator error. Nearly all these model appliances have some sort of Control Lock feature on the front panel now. This is a designed safety feature that is used to prevent small children from manipulating the controls. The controls can be easily locked or unlocked by pressing and holding the following button on the front panel:
Whirlpool Duet Washer - Press and hold the END OF CYCLE SIGNAL button for 3 seconds.
Whirlpool Duet Dryer - Press and hold the END OF CYCLE SIGNAL button for 3 seconds.
Kenmore Elite Washer - Press and hold the DRAIN/SPIN button for 3 seconds.
Kenmore Elite Dryer - Press and hold the AUTO DRY LEVEL button for 3 seconds.
These instructions may not be all inclusive for all Kenmore and Whirlpool models, but they are the most common. Chances are, if you have a Control Lock feature, the instructions will be printed on the front panel adjacent to the button that is required to lock or unlock the controls.
NOTE: These instructions may also work for newer model Maytag, Hotpoint, Admiral and Fridgidaire model front loaders as well. Refer to your owner's manual or front panel for instructions pertaining to your sepcific model.
If the Control Lock feature will not lock or unlock the appliance, unplugging the unit for AT LEAST 30 minutes is recommended in order to reset the main control board. In many cases this is all that is required to correct momentary glitches.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Sep 30, 2010
How do I unlock the control panel?
here you go
Press and hold the "End of Cycle Signal" button for approximately three seconds until the "Control Locked" indicator light shuts off. This unlocks the control panel so that the washer is ready for use.
Read more : http://www.ehow.com/how_5701217_unlock-control-whirlpool-duet.html How to Unlock the Control on Whirlpool Duet eHow
Sep 29, 2015 | Whirlpool WFW70HEBW Duet 4.1 Cu. Ft. Front...
How do I unlock a whirlpool duet washer
from a previous discussion:
Wait at least three minutes after the end of the cycle before attempting to unlock your Whirlpool washer. The door will not unlock until the motor speed equals 0 and 180 seconds have elapsed since the motor control unit received the "Stop" command. If the water in the washer is warmer than 122 degrees Fahrenheit or the water level is set higher than Wool, Delicate or Hand Wash, the washer must drain before the door latch will unlock 2 Hold down the "Control Lock" button on your Whirlpool washer for three seconds at the end of the washing cycle. Listen, and when you hear the unlatching sound, the door should open.3 If your Whirlpool washer did not unlock at the end of Step 1, press and hold the "End of Cycle" button for five seconds to manually reset your washing machine.4 Unplug your Whirlpool washer and leave it unplugged for 45 minutes. After 45 minutes, plug your washer back in. The washer's programming should be reset and the door should open.5 Manually unlock the door of your Whirlpool washing machine. Make sure to unplug the appliance before completing the manual unlock. Use a screwdriver to remove the metal strip, called the toe panel, at the bottom of the washing machine. Once you've removed the toe panel, reach up inside the front panel of the washer and feel around for the door latch. Locate the tear-drop shaped tab at the bottom of the door latch and pull it gently. When you hear a click, the door should open.
Jan 04, 2015 | Whirlpool Washing Machines
Whirlpool duet washer door will not unlock or complete the cycle
  • Oct 13, 2011 | Whirlpool Washing Machines
    I have a front load whirlpool washer. Could you please tell me how to get the washer out of control locked mode?
    Without the model number of your washer, it is difficult to advise you on how to unlock the controls. Most controls will have the instructions for locking/unlocking on the front panel. Check for a lock icon on the controls. Some washers have a specific lock button with a padlock icon on it. The normal method for locking/unlocking is to hold the button for 3 deliberate seconds or until the control unlocks. This may take as long as 10 seconds on some models.
    Aug 16, 2011 | Whirlpool Washing Machines
    Whirlpool Duet Dryer Lockout function stuck
    May 06, 2010 | Whirlpool GEW9250 Electric Dryer
    What does the code F11 mean?!
    This information is taken directly from the Whirlpool trouble shooting guide we found on our Duet Sport. I quote: "The motor control unit has internal failure; repeating under or over voltage, or over current conditions." Possible Causes/Procedures 1. Unplug washer or disconnect power. 2. Check wire harness connections between the drive motor and the motor control unit. And between the motor control unit and the central control unit. Check the motor and do a continuity test. 3. Plug in washer or reconnect power. 4. Check the motor control unit by by looking for operations of the drive motor. 5. Check the drive motor for powered rotations. 6. Replace the motor control unit.
    As previously stated, this is quoted directly from the guide. Hope that helps.
    Feb 15, 2010 | Whirlpool Duet GHW9150P Front Load Washer
    Control is locked
    To unlock the controls
    Select and hold END OF CYCLE SIGNAL for 3 seconds until the
    CONTROL LOCKED Status light turns off.
    Feb 12, 2010 | Whirlpool Duet GHW9150P Front Load Washer
    Unlock control lock in washing machine, whirlpool, duet
    Hold control lock for 3 sec. It will make a sound and the door will unlock.
    Mar 21, 2009 | Whirlpool Duet GHW9150P Front Load Washer
    The indicator light says 'control locked', how do I unlock it?
    Rightmost button has directions under it. Please contact me if you need further help or leave feedback if appropriate as that is how I get paid. Thanks for letting me help you!
    Nov 30, 2008 | Whirlpool Duet GHW9150P Front Load Washer
    Whirlpool Duet GHW9150P Front Load Washer Logo
    93 people viewed this question
    Dan Webster
    Dan Webster
    Sal De
