Question about Panasonic PT-47WX53 47" Rear Projection HDTV
Projection off the screen?
My PT-47WX53G appears to be displaying an image slightly larger than the actual screen area. This is both TV (DirecTV via the DVI input) and gaming (PS3 connected via component video).
TV logos run off the edge of the screen and game data appears to disappear off the screen as well. It's similar to when a Proxima projector displays an image slightly bigger than the projection screen.
How do I shrink the image to fit the screen again?
  • Anonymous Mar 23, 2009
    Aspect ration on my vizio tv is off when I load a ps3 game - image on game is larger than the tv screen
That is called overscan, you can adjust it in the service menu
Posted on Mar 24, 2008
  • 8,596 Answers
Try pressing the "Aspect/Prog -" button on the remote - it should be just underneath the number 9 key - try pressing once, see if it fits better, try pressing again to see if it improves until you get a better match
Posted on Mar 07, 2008
Pt-47wx53g tv won't click over n than the power button will blink 5 times
IC4511 has failed on the DG board replaing the DG board as a unit i the only way to fix the issue. The DG board isnt serviceable
Jun 01, 2012 | Panasonic PT-47WX53 47" Rear Projection...
Panasonic pt-47wx53g tv power light blinkcs 5 times and goes out.
Convergence problem...causing the TV to shut down. Goto www.TvRepairKits.com and get one of their fixes.
Jun 04, 2010 | Panasonic PT-47WX42 47" Rear Projection...
PT-47WX53G. TV got moved. Unable to move blue
The convergence ICs have failed which is very common when the set has been moved as a wek IC wont allow the color to be moved. You can get the PT52WX53G convergence repair kit from www.tvrepairworld.com which is the correct one for your model. The kit contains the parts and the CD with repair instructions.
Apr 10, 2010 | Panasonic PT-53TW53 53" Rear Projection...
My HDTV seems to be very Low Def - Panasonic Projection PT47WX54J
Ur convergence it dead.Must replaced the 2 convergence ICS.Know how to solders?Tries Tv repair World.com,Tvrepairkits.com for the convergence kit to repair it ur self.The Shop will cost U $300 parts and labors.
Jan 27, 2010 | Panasonic PT-47WX53 47" Rear Projection...
Panasonic CinemaVision PT-47WX53G : half the screen is distorted
did you try to try to adjust the vertical and the horizontal of your tv?
Oct 05, 2009 | Panasonic PT-47WX53 47" Rear Projection...
Hi, We need solution for B-Ray connection to PT-47WX53G
We solved the problem with Sony experts from Vio. Thank you
Jan 03, 2009 | Panasonic PT-53WX53 53" Rear Projection...
Red-striped ghost images.
when you leave your TV (no matter what kind) and you leave it for long periods of time on a static image or something.. the image tends to burn in to the screen... so changing the glass would be a way to fix it.... the problem is that that kind of repairmen is more expensive and difficult than buying a new set...
Dec 24, 2007 | Sony Grand WEGA KF50XBR800 50" Rear...
Green Area appears in lower part of screen
wayne, is it there as soon as the image comes up or does it have to run awhile before it appears? Let me know,
Nov 29, 2007 | Hitachi 53UWX10B 53" Rear Projection...
How to reset defaults Panasonic HD PT-47WX53G TV/picture
First of all are you sure you were in the factory menu this step requires alot of known how!!!!!! By using your hand unit only customer controls can be reached unless you know factory menu setup. Which starts like this ,make sure antenna to cable then go to menu set sleep timer to 30 mins exit out now enter ch 124 then press v- down on tv you should now see on top CHK ,also these sets have double convergence patterens.if you were in factory set up for more information look in www.freelists.org techassist/09-2005 .let me know if you still need help.
Nov 14, 2007 | Panasonic PT-47WX53 47" Rear Projection...
You will have two of the STK392-110's in the set so a good idea to replace both. The reason is one of the IC's is dedicated to RED horizontal and vertical and then GREEN horizontal, the other is dedicated to the BLUE horizontal and vertical and then the GREEN vertical. These are the best place to start for ghosting in the colors.
Mar 12, 2007 | Sony KP-51WS500 51" Rear Projection...
Panasonic PT-47WX53 47" Rear Projection HDTV Logo
234 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
