Question about Baby Gear
Can i repair something once a battery has rotten i it
  • 3 Answers
Yes you can. Take a small amount of baking soda and mix with a drop or two of water just enough to make a paste. Then dip a Q tip in the paste and apply it to the corroded surfaces. This will foam up and remove the battery acid that is still present. Wipe away the foam residue with a wet paper towel. If the metal contact surface still has some corrosion repeat the first step. When all the metal surfaces are corrosion free, take another Q tip and apply a very, very thin layer of Vaseline to the metal parts and it will be as good as new.
Posted on Feb 03, 2010
How do I repair the rotten wood on my deck
Once you have dry rot in a deck it is very hard to stop completely. It is a fungus, and spreads tendrils in the wood grain. Repairs have to involve chopping away all the rot to sound wood, and then treating it. Simply painting it with something s ineffective.
There are many commercial fungicides, all poisonous, so take care. A popular DIY treatment is a mixture of glycol (concentrated auto antifreeze) and borax, with a bit of liquid soap.
There is usually a lot more rot than meets the eye, often in the joists and bearers. The strength of the decking can then be compromised, and if concerned, ask a builder.
You are often best off just ripping out the whole lot, and replacing it with preservative treated timber which will never get the same problem.
Aug 09, 2016 | Garden
Soles on arch shoes
I would say that any shoe repair shop could help you with this problem. If the rubber is rotten, perhaps it has gotten in contact with gas, oil or some solvents. If it is not rubber, then it may have been kept in a place with too much humidity.
Apr 15, 2014 | Arche Clothing Accessories
Alternator burns out
You have a faulty battery, that's probably what killed the other alternator. The rotten egg smell is gases coming from your battery. Change the battery before you cook the second alternator.
Nov 26, 2011 | 2001 Pontiac Grand Am SE
What's your problemm?chevy colbalt smells like rotten eggs
The rotten egg smell usually occurs from time to time. It comes from the battery being charged by the alternator. However, if it smells continuously there is a problem. It's likely that your alternator is overcharging the battery. This needs to be looked at soon. The alternator will need to be replaced or repaired. Hope this helps.
Nov 05, 2011 | 2006 Chevrolet Cobalt
My 2002 Pontiac GP V6 smells like rotten eggs from the exhaust
The rotten egg smell if it is coming from the exhaust is a very good sign that you catalytic converter has failed or is failing. but a bad or battery that is being overcharged can also make a rotten egg like smell.
Jun 05, 2011 | Pontiac Grand Prix Cars & Trucks
I have a samsung touch screen that got really wet hgow do I dry it so it does not get damaged?
once dry the parts on the fone may rust making it useless... take it to a foneshop so they can use the right vhemicals to clear it of contamination from the water ingress... i repair fones. your fone will most likely work once dry but within maybe weeks or months it will be useless and the IC's on the board would have rotten beyond repair
Mar 26, 2011 | Cell Phones
My 2005 chevy malibus check engine light came on it's running really rough. It also smell like rotten eggs. I have tried the gas cap thing and checked all thefluid levels and still nothing
its your alternator voltage regular failed and your alternator is isnt being limited to 12 vots and its overpowering your electric system. the smell of rotten eggs is your battery over heating and the acid inside is boiling giving off the sulfur based smell. this is unhealthy for you to breath and is a sure sign that your car needs to be repaired. you need to replace your alterantor and battery immeditly or it coud damage your vehicals computer. The new altenator will have a new regulator in it and you will be good.
Dec 02, 2010 | 2005 Chevrolet Malibu
Smell of rotten eggs, and smoke coming from under neath the battery on the drivers side.
Disconnect the battery and remove it...WEAR PROTECTIVE CLOTHING!! The battery sounds like it is leaking acid and, as such, needs to be replaced ASAP! Once you pull the battery out of the car, only set it down on a surface that will not erode from the acid. If the battery is indeed leaking, you will see the corrosion where the battery was eating away the metal. This will need to be cleaned and neutralized before anything else can happen, if the battery is leaking.
I do think your battery is leaking; sulfuric acid smells like rotten eggs and the smoke is from the acid eating the metal it is coming into contact with.
Dec 07, 2009 | 1994 Volvo 850
Hello 1998 ACE Shadow 750 cc headlight not working high pitch alarm sound rotten egg smell and battery was very hot after sitting for a hour what could the problem be. Joyce
tthe battery has run out of acid and cooked itself(thats the rotten egg smell)it needs to be replaced,but even more sinister is the reason it did it,it sounds like the alternater has fried itself and that is why the battery cooked,so your alternater needs repairing before you put a new battery in,or it will cook the new battery to
Jun 24, 2009 | 1999 Honda VT 750 CD Shadow A.C.E. Deluxe
Baby Gear Logo
Top Baby Gear Experts
Dorel UK
Dorel UK
Are you a Baby Gear Expert? Answer questions, earn points and help others
