Question about Frigidaire FEX831CS Top Load Stacked Washer/Dryer
Washer is spining but water won't go out
On the spin cycle , washer is spinning but water is not going out. any solution?
    Genius:
  • 3,587 Answers
Hmm..check the outlet hose for a blockage, first...then backtrack to the pump that's down below..
Posted on Feb 19, 2008
Washer does not go through the spin cycle
while the machine is empty and in the spin cycle open the lid and hold down the lid switch spin the basket with your hand if it spins slowly you probably have a worn out clutch.
Jul 15, 2012 | Washing Machines
Washer is full of water but will not spin
if your washer has old dial selector ,does it continues and finishes "cycle" without spining or does the selector stops moving also you could have a bad timer ,newer ones will have some sort of electronic module
Feb 23, 2012 | Kenmore Washing Machines
Not spining
1st,check if you have lay down the drain hose to the ground,2nd if the drain hose is blocked.3rd,if the drain pump has problem
Mar 07, 2010 | Frigidaire ATF6000ES Front Load Washer
I have a fisher paykel eco which is spining water on the floor.
You could take the pump out and check it for obstacles
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Mar 05, 2010 | Washing Machines
Not spining- water standing can't get water to
If your washer is not spinning ! You first need to drain it. Then underneath your washer you will find your drive system. It will consist of drive belt, drive pulley or pullies and motor. Belt could have come off , if so check the condition before reinstalling, also some times from overloading the belt will spin on the pulley which will make it hot and thanks to the manufacturer the pulley is likely plastic. Parts supply shops best source for belts and possibly pulley though sometimes they want to sale you the whole motor with pulley which you don't need. If so uae internet to find your pulley probably under 10.00 dollars. Hope this helps.
Feb 23, 2010 | Kenmore 23822 Top Load Washer
Washer will fill fill with water but doesn't start wash cycle
it will fill but won,t spin, will throw out water as if it washed, then it take water to rinse but won,t spin ,then will throw out water as if it did , but clothes are soaked
Feb 21, 2009 | Roper RAS8445KQ Top Load Washer
The spin cycle for my
Dear shelldon39, Fri 2-20-2009 9:24pm EST (USA)
Some machines will shut down during the spin cycle as a precaution to prevent damage!
They will do this if you overload the washer with clothes and/or use too much detergent!
If this doesn't help please get back to me with more details!
jack
Feb 21, 2009 | Whirlpool Ultimate Care II LSQ9564J Top...
Excess water in clothes after spin cycle
Unblock the outflow pipe from the machine that goes into the sump under the sink. (have a pot ready for water overflow) This will help drain the water. If the spin cycle is making a screetching sort of noise then it is possible that the carbon brushes will need changing. This affects the spinning if the brushes are worn.
Nov 05, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
Spin cycles not spinning, does drain water before spin
check the wig-wag.it is the part near the cam bar.has 2 coils on it. also check the yellow wire going to the solenoid it may look ok but could be broke internally.
Nov 04, 2008 | Washing Machines
Spin cycle
hold cancel for 10 secs
hold end of cycle signal 10 secs.
one of them should reset it.
Feb 13, 2008 | Frigidaire ATF6000ES Front Load Washer
Frigidaire FEX831CS Top Load Stacked Washer/Dryer Logo
Top Frigidaire Washing Machines Experts
Gerry Harvey
Gerry Harvey
Jason Harris
Jason Harris
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
