Question about Dryers
Dryer tumbles but no heat. no low heat or hi heat
  • Dryers Master
  • 8,220 Answers
It could be the heating element, a safety limit, a control problem, or an electrical problem. A heating coil is used to warm the clothes as they get tossed gently inside the drum. A blower mounted on the motor pulls air through the heating element into the drum and out the exhaust. The element gets old and briitle with use and eventually needs replacement. That is what you check first. On gas dryers vibration and age will cause the igniter to crumble and fail. If it turns out the element is fine then one of the safety's might be blown. These safety's are set to a certain temperature
for the dryer to operate safely. The drum temp control for cotton is 160f. A limit on the heater housing is 250f. If it fails another smaller limit is mounted nearby that blows at 300f. If that temp exceeds 350f a duct fuse mounted on the blower housing opens and kills most dryers. On gas dryers the duct fuse will kill the gas assembly but the dryer will still run. If all of those safetys are good the timer could be the problem. The timer has a terminal on it that runs down to the heating element. If you suspect it is bad you can check it with a meter. That leg of the timer should have continuity with other terminals on the timer at different spots on the timer. Turning the timer and checking for continuity will give a clue. If you cannot get continuity with any other terminal on the timer at any position on the dial then you have a burned contact in the timer. If that turns out to be good, you would need to inspect the electrical outlet for proper power to the machine. On American models the motor runs on 120 volts but the heating element must have 240 volts. If you have more questions just post a comment. Good luck on repairing your machine. I have some repair photos: HERE
Posted on Feb 02, 2010
  • 135 Answers
SOURCE: tumble dryer
Can be a few things. Start by resetting your circuit breaker. The dryer motor can run with partial power but the heating element cannot. Make sure your not set to a no heat setting. After those checks you have to get into the mchine to check your heating element and thermostats.
Posted on Apr 12, 2008
amgm
  • 32 Answers
SOURCE: Hotpoint Aquarius VTD 00 Tumble dryer no heat
Hi, it sounds like the reset stat gone on your vented drier. Remove the back cover, where the element is, and you should find two stats, one with a green spot. That's your reset stat. If you have a multimeter, turn it to buzzer and check the stat by touching the connections with the meter leads. If there's no buzzing, it's the reset stat. also check if the dark side of the stat is pushed inside. Remove the stat and hold it about 20inches from the floor. Drop it on the floor and the dark side will become flat. Repeat as many times as necessary. GUARANTEED TO WORK. Put everything back and that's it.
Cheers
Posted on Feb 15, 2009
  • 7 Answers
SOURCE: Hi,there is no heat coming from my Bosch Tumble Dryer
USUALLY A FAULTY THERMOSTAT OR HEATER ELEMENT ASSEMBLY
Posted on Apr 10, 2009
beltronic205
  • 1461 Answers
SOURCE: White Knight sensordry tumble dryer which only works on low heat
Could be element or thermostats, element is twin giving two heats ie !00watt/ +1800watt, possible one side has gone, you bcan check with multimeter and compare readings..Good luck
Posted on Oct 01, 2009
heatman101
  • 43501 Answers
SOURCE: the tumble dryer drum turns but there's no heat
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check out this electric no heat tip...
heatman101
Posted on Oct 06, 2010
Hi. My tdvcw bush tumble dryer turns but won't heat up. There's no reset button. Also the temperature light is flashing
What To Do If Your Tumble Dryer Is Not Heating Up - YouTube
? 2:33
https://www.youtube.com/watch?v=uWtRXie82oY
Nov 17, 2011 - Uploaded by BuySpares
If your tumble dryer isn't heating up, it's likely that the heater may .... helllo, i have a bosch dryer it works ...
Dryer problems: How to fix a dryer that's not heating up ...
? 3:03
https://www.youtube.com/watch?v=aFXbYp--K5g
Jun 4, 2010 - Uploaded by eSpares
For all your tumble dryer spare parts go to http://bit.ly/1LJTuT6 In this video, Rory shows us how to change the ...
Jan 25, 2016 | Dryers
Hi. My tdvcw bush dryer is turning but not heating up. The temperature light is flashing. There is no reset button on back of dryer. I have a child and need clothes dried. Thanks in advance
My tumble dryer is not heating up! - 24'7 Home Rescue
https://www.247homerescue.co.uk/my-tumble-dryer-is-not-heating-up-2/
My dishwasher won't fill with water! ... My TV will not turn on! ... If your tumble dryerdrum is not heating up, but the drum is spinning normally, then you might be ...
Tumble dryer not heating - White Goods Help
The tumble dryer drum turns but there's no heat on either low heat or full heat
heatman101
Mar 13, 2010 | Bosch Axxis WTA 3003 Electric Dryer
Tumble dryer overheating!
It could be a faulty thermostat, or the high/low heat switch is faulty, it will be one or the other.
Hope this helps.
Jan 17, 2010 | Dryers
Oct 01, 2009 | Dryers
My nepture dryer wringles the clothes very badly
Most common problems with wrinkles is too much clothing is in the dryer causing and allowing to tumble freely. 2nd, the dryer is not putting out enough heat and cause the clothes to stay damp and stay winkles. 3rd the exhaust fan may be not working properly. you might able to solve the problems by trying to reduce the amount of load, allow it to tumble freely and I don't know if your dryer are putting out enough heat. the cause of low heat can be the heating element is going out. hope that help some.
Aug 09, 2009 | Maytag Dryers
Maytag pye2300ayw runs but does not heat.
hi..the reason to this problem is your heating
element might have gone bad.
check it out..
thank u..
kindly rate my response..
Jun 30, 2009 | Whirlpool LER5636P Electric Dryer
Apr 09, 2009 | Bosch Dryers
No heat to tumble dryer
Check the thermal disc with an OHM meter. One will be next to the heat element (high limit) and another on the air exhaust area which is the low limit.
Dec 16, 2008 | Dryers
Dryers Logo
145 people viewed this question
Top Dryers Experts
Dan Webster
Dan Webster
