Question about Amana NAV2330AW Top Load Washer
My clothes don't always spin out. have to put through spin cycle several times. It doesnt happen all the time. Im figuring its the V belt what do you think
    Novelist:
  • 127 Answers
Yes the vbelt (part# 27001007 )could be worn, as could the idler roller (#40045001 ) , and arm (#27001028).
However if you find traces of oil as in motor oil your gearbox/transmission is leaking and you may as well start searching for a new unit as the transmission is around $230 and not a quick/easy chore to change..
best of luck, have fun,
ttfn
Posted on Feb 02, 2010
Clothes washer tub spins on wash
sounds like u have a problem with the "brain". The agitator and spin cycle should never run at the same time. therefore it leads me to A: brain issue B:problem in the actual transmission of what cycle should be running. You will continue to smell the burning rubber due to the issue being one of the two explained above. Does it ever NOT spin? If this is the case the likely hood is that it will be a solenoid.
Apr 21, 2013 | 2000 Honda Accord
Washing machine does not spin well and leaves the clothes soaking wet
Likely a bad belt or tensioner causing it to slip. Take it apart and look to see what the belt is doing or call a repair man.
Apr 22, 2012 | Whirlpool Washing Machines
Hot water stops filling too soon.
Fill setting has to be adjusted and the belt is slipping on the spin cycle and not generating enough centrifugal force to get the water out.
Aug 25, 2017 | Kenmore 22422 Top Load Washer
When washing a load of colored clothes the spin cycle doesn't remove the water from the fabric properly. Clothes come out dripping wet.
it could be one of two things the only way to figure out what exactly would be process of elimination unfortanently. First check your motor for any possible damage youll be looking to hear any unusual noises or physical damage. If your motor is ok then move on to check the agitator to see if its functioning properly listen to hear if it does any sudden stopping and going or if it is having a hard time spinning. if so replace the drive belt. if replacing the drive belt doesnt work its your gearbox
Jan 29, 2011 | Frigidaire GLTF1040A Front Load Washer
During the spin cycle the washing machine becomes VERY noisy, sounds like its off-balance, but happens EVERY time, even with very small loads. The whole unit doesn't move when it happens, just extremely...
During the spin cycle the drum moves at a higher RPM and so the counter weight of the clothes within can make the drum rotate eccentric or out of sync.
So check if the belt is loose on the motor, checck if the spindle is tight with friction or the drum assembly suspension is out of alignment.
You must check the reason with the following points to confirm the drum spinning making noise. check point of noise , is this on hitting the sides , or from the motor, any foreign objects or the drum spindle. But you are the judge with a first view. Use good lighting to look out and confirm the fault.
Sep 16, 2010 | Frigidaire FEX831CS Top Load Stacked...
THE LAST SPIN ON A FRIDGEAIRE WASHER DOE NOT SPIN HARD ENOUGH TO PULL THE WATER OUT ANY MORE ITS A XC24017503 MDEL NUMBER 10 CYCLE
Frigidaire washers have a special belt that loses its ability to grab over time. NO other belt will fix your spin problem but the original Frigidaire belt. Fortunately for you, it is quite easy to replace. Also remember that the spin cycle is not for draining water, it is for wringing residual water from clothes while the pump is running.
So, your actual problem in the spin cycle itself.
Another factor to consider is that the bottom tub bearing on many frigidaire washers tends to rust and degrade over time producing a roaring noise. If this has happened to you, replacement is problematic and expensive, if not, you simply need a new belt.
Mar 05, 2010 | Dishwashers
Clothes are to wet after spin cycle
The clothes are wet after spinning When the clothes are wet at the end of a cycle, check these: Motor coupler Spin cycle Siphoning Water-inlet valve Motor coupler To test the motor coupler, re-start the washer in its spin cycle. Let the machine run for a minute, and then open the lid and notice whether the tub is spinning: If it's spinning when you lift the lid, the coupler is fine. If it isn't spinning--and your machine was produced by Whirlpool®--you may have a broken coupler. Many Whirlpool-made washers use a small, relatively inexpensive device called a motor coupling. This plastic-and-rubber component is mounted to the shaft of the motor on one side, and to the transmission on the other. Over time, the coupler wears out and fails. When that happens, you need to replace it completely. Spin cycle If the washer doesn't reach its proper spin speed, the clothes may be too wet at the end of a cycle. Check to be sure the load is properly balanced and run a spin cycle again. If the clothes are still wet, you may have a worn or loose belt (Maytag®), a worn clutch (GE®/Hotpoint®), or a worn motor pulley or tub bearing. Replace the applicable component. Alternatively, there could be clothes caught between the inner and outer tubs. Read the "It spins but won't pump" section of the "It won't drain" section. Also, there could be other things that cause friction on the drive train. Seek the assistance of a qualified appliance repair technician. Siphoning If the water that pumps from the machine goes right back into the machine after the spin cycle, it may be because your washer is siphoning the water from a laundry tub with a slow drain, back into the washer. Try to improve the draining of the laundry tub. (Is there something stuck in the drain?) Also, be sure the drain hose doesn't reach more than about 4 inches into the laundry tub. If it does, cut off the excess. Water-inlet valve Water-inlet valves eventually fail. One problem that may develop with a water-inlet valve is that it can no longer completely shut off when the electricity is turned off to it. Then, the valve may leak and drip water into the clothes tub--you may notice that your washer has water in it when you haven't used it for a few days. To fix this, replace the valve.
Jan 24, 2010 | Kenmore Washing Machines
Damp clothes at end of spin cycle
Time to check out and clean your filter...........
Mar 01, 2009 | Maytag Atlantis MAV8551 Top Load Washer
Washer belt is loose, & seem to slip at start of spin cycle.
there are several drive belts for this model... check here to see if the one you are fitting is the correct one... also,is the tensioner siezed? causing the tension to be too slack therefore allowing the belt to shred at speed?
check here .. http://www.partselect.com/AppliancePartList.aspx?Brand=Admiral&Appliance=Washer&ModelNum=&Type=Belt&MinSize=U&MaxSize=U&Electrical=U&Metal=U&Plastic=U&OneColor=U&PageSize=15&FirstPart=1
Dec 03, 2008 | Admiral AAV7000A
Washer spin cycle
Hi joystoy
I would start with the belt. it sounds like the belt is going and that is the least expensive to fix. try that, if that doesnt work then i would call a repair company to look at it.
brent
Sep 29, 2008 | Maytag Neptune MAH5500B Front Load Washer
Amana NAV2330AW Top Load Washer Logo
112 people viewed this question
Top Amana Washing Machines Experts
Dan Webster
Dan Webster
Charles T Nevin
Charles T Nevin
Are you an Amana Washing Machine Expert? Answer questions, earn points and help others
