My external hard drive is no longer being recognized by my laptop. After having my laptop's boot drive reformatted I began reconnecting all of the peripherals. The computer would not recognize the external drive. The light on the drive would come on when I plugged it into one of the USB ports but Windows XP did not recognize it. No messages, it just isn't recognized (does not show up under my computer). I called the manufacturer (Hitachi) and they had me try a couple of things, including trying it on another PC. That machine didn't recognize it either. They did ask if I had another USB cable but I didn't. Could that be the problem? They did say that it was under warranty but I don't want to lose the data or pay the exorbitant recovery fees to get the data back. Any help you can give would be much appreciated. Its a Fibrek Simpledrive from Hitachi. Thank you.
  • 922 Answers
I doubt it is the USB cable as it has no moving parts that could fail. If it is in good physical shape then it is probably good.
Frequently, external drives are not accessible because the computer is already using the drive letter that the external drive wants to use.
Open Windows Help and Support. Search for "drive letter".
Select "Assign, change, or remove a drive letter." and follow the instructions.
I recommend picking a letter towards the end of the alphabet such as W, X or Y.
If this doesn't work it would be good to test it on another computer. If it works on a different computer then the drive is good and your computer is where the problem lies.
Although it may void your warranty, removing the hard drive from the USB enclosure and connecting it directly to the PATA or SATA connector on your motherboard should allow you to access it if it is the USB enclosure that has failed. This is a task that most computer shops can perform for you. (E.g. Best Buy's Geek Squad)
I hope this helps.
FYI: I have been servicing computers for 12-years now and Hitachi has the highest failure rate of any hard drive I have ever encountered. IBM bought Hitachi's hard drive division serveral years ago and they had so many failures they sold the division back to Hitachi! Needless to say, you should also stay away from IBM hard drives. The most reliable drives I have encountered are Western Digital and Seagate. I have mixed experience with Maxtor, Fujitsu and Toshiba drives.
Posted on Feb 02, 2010
Please help! I have a gateway NE51006u Intel celeron quad core processor N2920 windows 8 laptop. Recently it has been making clicking and notifying me that there is no bootable device. I have tried all...
Solution 1: Instructions for Performing the Power Discharge Procedure (ATX Reset)
Information:
Your computer has no power at all or cannot boot properly. In some situations this can be caused by an external device or an electrical problem. This can usually be solved by removing all external devices and resetting the power supply.
Instructions for laptops:
1. Disconnect all external devices you have.
2. Unplug the power adapter from the laptop.
3. Remove the battery pack from the laptop.
4. Press the power button and hold it for at least 15 seconds.
5. Reconnect the power adapter.
Do not yet reconnect the external devices, they should stay disconnected. Do not yet reseat the battery pack.
6. Switch your laptop on and test if it boots normally and watch if the power LED lights up.
7. If the power LED still does not lights up, continue with the next steps.
8. Disconnect the power adapter from the laptop.
9. Press the power button and hold it for at least 15 seconds.
10. Reseat the battery pack. Do not reconnect the power adapter.
11. Switch your laptop on and test if it boots normally.
Solution 2: Unplug and reconnect System Hard Drive
1. Unplug the power adapter from the laptop.
2. Remove the battery pack from the laptop.
3. Unplug and reconnect System Hard Drive. This is normally accessible by removing a panel at the bottom of the laptop or removing the back enclosure (see User Manual).
4. Reseat the battery.
5. Switch your notebook on and test if it boots normally
Jan 03, 2015 | Computers & Internet
Media test failure, no os
Your hard drive is missing from the system. Or, just does not recognize it.
The obvious - Remove any USB devices like drives and any media from disc player. Its trying to load, but can't find bootable hard drive, CD, or USB...
Remove the hard drive and re-seat (reconnect). Check BIOS by pressing an F key during boot. Look on the screen for correct Function key. Might be F2 key. Verify BIOS recognizes the drive. It must be listed! There is no going forward if it's not. Check boot order and make internal hard drive first. Save and restart.
Dec 10, 2012 | Dell Inspiron 1501 Laptop
How can i reformat my acer aspire 4520 without cd rom?
Try this method it may work.
If you can boot up with the external USB hard drive on your Acer, then use a working computer and copy the Windows installation CD onto the external hard disk then connect the USB externak hard disk to the USB port on your Acer and boot up using the external hard drive.
Feb 18, 2012 | Acer Aspire 4520-5141 Notebook
The dishnetwork tech reformatted my external hard drive and now I want to use it on my laptop and the laptop is not recognizing the usb connection of the external hard drive. Please help... It is a...
1. Three things could be happening here.
One the drive isn't completely formatted.
Two you have a bad USB controller in the USB external case.
Three you could have a bad USB cable.
Jun 13, 2011 | Seagate FreeAgent Desktop External, 1.5TB...
EXTERNAL HARDRIVE NOT RECOGNIZED IN WINDOWS XP
Uninstall the driver and then reinstall. make sure the drive is not connected until the driver is installed.
May 30, 2010 | Western Digital Elements powered by WD 320...
External Sata Drive no longer recognized
My friend it sounds like your hard drive. I know thats not what you want to hear. But don't worry there is hope! You can have the data retrieved from your hard drive by using this online company which I highly recommend:
http://www.gillware.com/
Aug 10, 2009 | Western Digital My Book Home Edition 500...
HP Pavilion zv6100 laptop CMOS will not recognize the HD
You could have a faulty disk controller. Try inserting a different working hard disk into the HP and see if it can detect it in the BIOS. If not then the disk controller is faulty and this is a motherboard problem. A replacement motherboard may not be worth it, put your money towards a new laptop and put the hard disk into an USB hard drive adapter case and use it as an USB external hard drive.
Jul 15, 2009 | HP Computers & Internet
Laptop Won't Recognize External HD
You can try opening the device manager in Window XP and uninstall the external hard disk (make sure you show unplugged devices).
Then replug the drive again, and it should reinstall the drivers.
Jules
Feb 22, 2009 | Beyond Micro Mobile / 250GB / 7200 / 8MB /...
My laptop cannot recognize my external cd rom
Need to go to the hard drive maker website and look for a driver and install it to your computer search for the model # on the website of the hard drive company
Jan 31, 2009 | Toshiba (PX1052E-1NMD) External 24x CD-ROM...
Data Recovery
try Tigerdirect for your cable.
Oct 21, 2007 | HP Pavilion ze4560us Notebook
k24674
jasbo
jasbo
