Printer not printing
Printer prints when turned off & on (test page) but when you request a page to be printed it doesn't
  • Anonymous Feb 19, 2008
    printer will print a test page, but will not print anything else
    PRINTER PRINTS TEST PAE ONLY, WILL NOT PRINT ANYTHING ELSE
    Scholar:
  • 89 Answers
Make sure all cables are connected first. You may need to verify that the printed is installed correct by going to control panel and then to printers. Verify the printer is listed. If not you'll need to install it first. If installed and listed. Go to device manager and make sure driver is installed. You might even try to update driver by going to Printer Manufacturer website. Any more info would also help solve. Hope this helps. Thanks
Posted on Feb 19, 2008
HP Deskjet D2560
First step is to see will if it print a test page.
Go to Start, settings, printers. Right click on the printer, properties, print test page.If that doesn't work there should be a head cleaning option in properties that will make it clean the print heads.
Try the self-test? I'm not sure on the 5550 printer, but do this:With the printer ON,
1. Press and hold the power button
2. While holding the power button, press the resume button 4 times
3. Release the power button
Apr 18, 2012 | HP DeskJet D2560 InkJet Printer
Why is paper blank
Try to re-seat the cartridges in the printer. Open the printer cover > remove the cartridges > close the printer cover > re-brick you printer by pulling out the power supply - black box behind the printer where the power cord is plugged in, and re-plug after 10 seconds. When the printer turns on, reinsert the cartridges and close the cover. Try to print a document again to verify that the problem is fixed.
If that doesn't help, the problem could be due to a clogged print cartridge nozzle. Please follow the steps below to fix print quality issues with your model:
  1. On your computer, go to Start menu.
  2. Go to Programs.
  3. Go to Lexmark 3600 Series folder.
  4. Select Lexmark Solution Center.
From the Maintenance tab, select Clean to fix horizontal streaks. Your printer will then print a page forcing ink through to clean the print cartridge nozzles.
After printing the test page, try to print a document again to verify that the problem is fixed.
Feb 12, 2012 | Lexmark X3650 Printer
Lexmark wireless printer 1400 series prints blank pages
  2. Go to Programs.
  3. Go to Lexmark Z1400 Series folder.
Jan 22, 2012 | Lexmark Z1420 Printer
I connected my hp C5180 to my pc then printed a test page, it started to print and hasn't stopped. It just keep printing pages of code. How do I stop this???? Tried cancelling, tried turning off...
YOU NEED TO GO TO PRINTERS...AND CHANGE HOW PAGES YOU WANT TO PRINT...AND TAKE THE PAPER OUT OF PRINTER, SO IT DOESN'T USE UP ALL YOUR INK!
HOPE THIS HELPS!
Aug 31, 2011 | HP Photosmart C5180 All-In-One InkJet...
My printer won't print. my computer is hooked up to it, and it doesn't give any error messages. it just doesn't do anything.
Go to Control Panel/Printers. Right click on your printer's name, and hit Print Test Page. If printer prints a page out, then the problem is likely with the software you're using to print - make sure you have selected the right printer in the dropdown. If the printer's name doesn't show in the Printers folder of Control Panel, the driver for it has not been installed. Do so and try again.
Jun 18, 2011 | Lexmark X2670 All-In-One Printer
Hi, I've got a 5500 designjet and when I print, after cutting paper, the printer reboot and after the initialization, the I/O card doesn't work. After that, I switch off than on and the problems...
It sounds like a bad JetDirect network interface card.
Turn the plotter off, remove the JetDirect card and see if it prints an internal test page without rebooting.
If it prints OK, turn off and reinstall the JetDirect card and see if it prints the same internal page OK.
If it prints OK both ways, you may have a bad Main PCA.
Jun 15, 2011 | HP DesignJet 5500PS InkJet Printer
Printer DeskJet 820Cse didn`t work
test page printing but doc files not printing....
HP DeskJet 6940
Sep 26, 2008 | HP Deskjet 6940 InkJet Printer
Canon BJC 4300 InkJet Printer
i assume the cleaning method that you perform is offline (taking the cartridge our and clean them). I suggest you clean the head during the printer on.. try to perform below steps per the manual Cleaning the printer Printing the test pages Cleaning the print head I assume you do not have the manual anymore (no DVD) i list down the step below Its a bit long manual I suggest you download them from the canon website.. if you still have problem I can send to you the BJC 4300 manual Cleanning printer Make sure the printer is turned off before cleaning it. It is a good idea to unplug the AC adapter also. Do not clean the exterior of the printer with volatile liquids such as thinners, benzine, or any spray-type or chemical cleaners; doing so will damage the surface of the printer. When cleaning the printer, avoid the area near the print head on the BJ cartridge. Do not touch the print head. Ink may leak out and cause stains. Clean the printer regularly to avoid printing problems. Remove any ink mist or paper debris from the interior of the printer using a soft cloth moistened with water. Clean especially well around the platen area. If the rollers become dirty, you can clean them using a small soft brush. Clean the exterior of the printer with a soft cloth moistened with water. Clean away smudges and dust. Do not use paper products (such as paper towels or tissues) to clean the inside of the printer. Printing the Test Pages You can print these test pages to check the operation of your printer and your print quality. Test A This test prints a repeating pattern of characters. Demonstration This test prints a sample page describing the printer's features. Printing the Test Page From Windows You use the Test option on the Control tab in your BJC-4300 Printer Driver for Windows to print a self test, demonstration page, or a nozzle test pattern. Before selecting a Test option, make sure paper is properly loaded in the sheet feeder (see Automatically Feeding Paper starting on page 3-7). Click on the Test option and then click on the Print button. Printing the Test Pages Using the Operators Panel To print a test page, make sure the printer is turned off and paper is loaded. Press and hold the POWER button until you hear the number of beeps that correspond to the test page you want to print. Test Page Number of Beeps Pages Printed Demonstration 1 Continuous Printing Status Information 2 1 Page Test A 3 Continuous Printing Nozzle Test 4 1 Page When you release the POWER button, the test page starts to print. *All self-test prints require Letter or A4 size paper. Using a smallersize paper for a self-test print will result in parts of the printoutbeing printed directly on the platen. All self-test prints are printed in accordance with the current printing settings (font, printing mode, etc.) *Red- Information for technician not included in the user manual Cleaning the Print Head Your printer is equipped with a print head cleaning function to ensure constant high quality printing. Cleaning the Print Head From Windows If you are using Windows, you can execute print head cleaning from the Control sheet in the printer driver. Simply click on Clean Ink Head. 4300 Chapter 4 Page 6 Cleaning the Print Head Using the Operators Panel If you want to clean the print head from the operator panel, follow these steps: 1 Make sure the printer is turned on. Make sure the green POWER light is on. 2 Press and hold the RESUME button for at least two seconds until the printer beeps twice. The POWER light will blink for several seconds while the print head is being cleaned. Perform the print head cleaning only when you encounter a print quality problem. Unnecessary and repetitious cleaning will waste ink. If you execute the print head cleaning while paper is manually loaded, the printer will eject the paper and then perform the cleaning. 4300 Chapter 4 Page 7
Aug 24, 2007 | Canon BJC 4300 InkJet Printer
Test page
I had the same problem and being helped by HP operator.
first take the USB cable out of your computer, then put it off and then on again...it starts to print the test page again...then after the printer stops printing, put the just printed testpage face down on the scanner(glas) and press scan manually...after the scanning(you wait till that is finnished) and then put the printer off and on again....then connect the USB cable to the computer and that will stop the printer from printing the testpage every time you startup your printer....
hope it wil solve your problem, it did for me...
Dick van den Broek
The Hague
The Netherlands
Feb 23, 2007 | HP PSC 1510 All-In-One InkJet Printer
144 people viewed this question
jasbo
jasbo
