Question about HP Pavilion MX70 17" CRT Monitor
I cant open the disc loader - HP Pavilion MX70 17" CRT Monitor
    Brigadier General:
  • 10,406 Answers
Straighten one end of a Norwegian paper-clip, and insert that end into the small hole on the face of the drive, and push until you feel some resistance.
Then, push it another 1/8 to 1/4 of an inch, and the drive-door should "unlock". Then, you can manually slide the tray open.
Posted on Feb 02, 2010
Tray will not open. Says check desk.
Three reasons.
1. a worn up loading belt at the disc loader mechanism.
2. a broken gear wheel at the disc loader mechanism.
3. a damaged disc.
Mar 05, 2016 | Televison & Video
Why the disc loader of dvd player not opening not opening
pl change ur Philips dvd player loader bald may b solved urs problem
May 23, 2014 | Philips portable dvd player phillips...
Used your disc player which was bought with a digital home theater system two years ago.. First time it was ever used and half way through the movie it shut off after a notice appeared saying...
you have a problem in mechanical disc loader. try to clean it. and little bit head adjustment... if cant do it call a qualified technician to do.
May 30, 2011 | Samsung Televison & Video
CD/DVD drawer won't open so CD stuck inside :(
Well you can please follow the below steps -
1. Unplug the DVD player and take the outer casing of the DVD player off. This entails either taking out two or three screws or simply sliding one of the pieces of plastic in either direction.
2. Locate the disc loader cover. The disc loader cover is located where the extending DVD tray finally comes to rest within the DVD player. It's the part that holds the DVD loader in place.
3. Bend the two tabs outward that hold the loader in place. This is a delicate procedure because you don't want to hurt the device. The tabs are relatively easy to break since they're plastic in most cases.
4. Slide the disc tray out. If your disc got stuck before it was read, it's probably still on this tray. If so, your problem is solved. However, if the disc was fully set and loaded, the job isn't quite finished yet.
5. Move the small mechanical arm that holds the disc in place over so that the disc and the reader are both exposed. Some DVD players will not have anything holding the disc in place. Instead, these devices use a system not unlike that of a common DVD case. The DVD will be locked in place in the center.
6. Carefully lift the disc up and out of its loaded position in the DVD player. This may entail sliding the disc reading mechanism over slightly. This won't hurt the device as long as you're careful. You should be able to access and remove the disc.
Good Luck!! Thanks for using FixYa!!
Feb 03, 2010 | Cambridge Audio Azur 540D DVD Player
Sony DVP CX860 300 disc just keeps rotating the carousel
I just got one of these and i notice mine does the same thing. WHat i found that helped mine is tip the unit back a little. The loader uses a little but of gravity to get the disks to roll back into the loader. If its level the wheel sometimes cant spin the disk up into the loader fully. If its tipping back a little the disk will roll back easy into the loader and load it properly.
Also, dont forget if your playing a disk and you want to stop the unit, DONT POWER IT OFF AT THE UNIT. Power the unit off by the remote power this way it will finish its cycle and put the disk back into the proper slot.
Jan 18, 2009 | Sony DVP-CX860 Multi-disc DVD Player
I cant open the disc loader on my laptop
Look closely on the front of you cd drive for a small hole, about 1mm in diameter. This is the emergency eject button. You'll have to use a needle or a paper clip, push it in slowly, increasing pressure when you hit the button inside. The spring will open the drive just a little, then you can just pull it out. Hope this helps!
Dec 27, 2008 | Computers & Internet
Rio HT2030 disc loader will not open
I have had the same problem. There is a rubber ban that acts as a drive belt to open and close the disc loader. i took the cover off and then the disc loader cover off to expose the bubber ban. Then i replaced it using two rubber bans from my daughter's braces and reassembled. Works great again.
Dec 23, 2008 | Rio HT2015 DVD Player / VCR Combo
WILL NOT READ SOME BOUGHT MOVIE DISCS
one of the solutions before spending $$ is, you need to open the unit remove the dvd loader,CAREFULL OF PLUGS AND RIBBON CABLES!!! open the dvd loader, clean the laser GENTLY WITH A CLEAN COTTON TIP, and re assemble. if that doesnt fix the units issue,the second option is you will need to replace the dvd loader, part number is found on white or yellow sticker. hope this helps.
Dec 20, 2008 | LG RH1999H DVD Recorder/HDD Recorder
RH1888HS /hdddvd
what you need to do is open the unit carefully remove the dvd loader, open it and gently clean the laser with a clean cotton tip, if that doesnt fix the problem you need to replace the units dvd loader. part number found on white or yellow sticker on dvd loader. hope this helps.
HP Pavilion MX70 17" CRT Monitor Logo
238 people viewed this question
Top HP Computers & Internet Experts
Tony
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
