Question about PfaFF Creative 7570
How do you thread a pfaff 7570 - PfaFF Creative 7570
  • 201 Answers
If only we could put video links in here! But here goes:
Raise the presser foot;
Turn the hand wheel until the take-up lever (the hook bit that goes up and down, above the needle ) has reached its highest position;
Remove the small spool holder from the horizontal thread holder that is under the lid. Put thread reel onto spool, replace spool holder;
Pull thread behind first thread guide - it is the cream flat plastic bit towards the back - about 1" x 3/4" (i.e. the thread takes the first exit at the back);
Bring it down the left-hand long slot on the front of the machine, back up the right-hand slot, over the hook of the take-up lever, back down the right-hand slot and pass it from the side between the thread guide (silver metal bit just above the needle - looks a bit like curled metal). I found this last guide the most difficult to figure out - tried to get the thread into the curled bit - but you don't do that - it just slips in behind;
Thread goes through the eye of the needle. You can use the needle threader or not. Instructions for needle threader:
Lower sewing foot (makes more room and clamps the thread in the upper tension discs so it is less likely to keep spooling off while you are trying to thread);
Turn handwheel until the needle is in highest position;
Pull the needle threader straight down and then twist it to the front so the tiny hook on the threader goes through the eye of the needle;
Take thread under the larger metal hook on the left, put your thumb on it to stop it coming off, thread goes back towards the needle and under the small hook that is poking through the needle from the back;
Twist the needle threader towards the rear, releasing the thread carefully and allow the threader to move upwards. There should be a loop of thread left in the eye of the needle and you can now pull it all through to the back.
That sounds really complicated but I find the Pfaff needle threader works really well, unlike that of some other machines. I also have a Husqvarna Designer 1 whose needle threader works great, but the one on my friend's Designer SE is useless. Go figure!
Posted on Feb 02, 2010
Blinking Red led on Pfaff 7570
Make sure the bobbin has thread. The manual should provide information in the troubleshooting section.
PFAFF creative 7570 Instruction Book
Nov 13, 2016 | PfaFF Creative 7570
Would like to know how to thread a twin needle on a Pfaff 7570
put the twin needles in the needle holder and then thread the first
needle like you normally would then add a second spool or cone
of thread then thread the machine the same way you did with the first
needle and then thread the second needle
Jan 27, 2013 | PfaFF Creative 7570
PFAFF 7570 User Manual
The only one I found is $40. http://www.sewingstyle.com/pfaff-7570.html You may be able to contact the site for additional information.
I think I would speak with a Pfaff dealer for information before spending this much for a manual.
Apr 27, 2010 | PfaFF Creative 7570
On what number should I put 7570 tention when
Refer to the manual. If you do not have a manual, start at 4 and work your way through the numbers, bit by bit until you get good results.
The bobbin thread should pull the top thread slightly under and to the back.
Machine embroidery bobbin thread is heavier than the standard size machine embroidery top thread and this also helps to pull the top thread to the back.
Mar 07, 2010 | PfaFF Creative 7570
I cant set the tension on my PFAFF 7570 the thread keeps
First make sure your needle is in correctly. Then make sure you are threading the machine correctly especially make sure you thread the take-up lever. Make sure your tension dial is at a 4 to 5. if this does not work, let me know
Oct 19, 2009 | PfaFF Creative 7570
Jamed Pfaff CD 7570:
Your machine probably has a thread lock which is a piece of thread caught in the hook. If this is the problem then here is the solution.
Grasp the hand wheel and turn it back and forth,increasing the amount of force used each time. It should break free after about 4-6 tries
sewman7
May 08, 2009 | PfaFF Creative 7570
Bobbin tension
Check also this links, hope they can help you:
Pfaff 1475 7570 7560 FAQ
threading a pfaff creative 7570
Aug 10, 2008 | PfaFF Creative 7570
Service manual for pfaff 7570
www.sewusa.com is a good place to look if your machine is not listed email them and they will try to help. Also look at their "repair or threading page".
May 01, 2008 | PfaFF Creative 7570
Threading a pfaff creative 7570
Always thread the machine with the presser foot up. This keeps the tension disks open while you are threading. Open the lid on top. Put thread on spool holder. Go directly to your left and down the path on the farthest left. Go all the way to the bottom and bring the thread up on the path closer to the spool. Hook the thread through the metal piece that moves up and down while sewing. It should be in the highest position when threading. Run the thread down and clip into the small metal holder above the needle. Pull down needle threader, draw thread across front of it from left to right and pull through needle.
Jan 30, 2008 | PfaFF Creative 7570
Sewing Machines Logo
786 people viewed this question
Top PfaFF Sewing Machines Experts
Tally Girl
Tally Girl
Douglas Plant
Douglas Plant
Irene Tulloch
Are you a PfaFF Sewing Machine Expert? Answer questions, earn points and help others
