Question about GE 24 in. Profile PDW9880JSS Built-in Dishwasher
Rust in solenoid per plumber. fix or replace?
  • GE Master
  • 3,361 Answers
If there is rust there is a water leak.
Find the cause of the leak and determine if it is repairable before you replace the solenoid.
Posted on Feb 02, 2010
Testimonial: "thanks. The water heater leaked and was replaced which led to rust in solenoid."
My Elkay water fountain is clogged up, water does not drain properly, how do I unclog
To unclog the elkay water fountain just look out for push button catridge and and turning it to adjust how far it is pushed or you can even try with chemical drain cleaners like draino or liquid plumber or CLR(Calcium,Lime and Rust Remover) & if still the problem hire plumbing repair services.
All Plumbing Repairs
Apr 29, 2015 | Elkay Water Cooler ADA Wall Hung 8 Gallons...
Wil not turnover makes all the usual sounds when starting then will start clicking will not engage starter & turnover moter
Probably a rusted starter solenoid - get a hammer and give the solenoid (cylinder attached to the starter motor) a few good thumps. If that fixed it, get the unit replaced because it will happen again.
If this trick does not work, check the wiring for loose or rusted earth - another common fault
Jun 08, 2014 | 1996 Land Rover Range Rover
We have a Rheem hot water system installed in 1994. We think from the owners guide left by the installer that it is a model 52F. Our plumber is having difficulty getting a replacement part. The bottom...
Hello, The plumber should be able to call Rheem directly and if that does not work, your local parts supplier for Rheem should be able to get him a number for the Rheem factory (I'm assuming he called and the parts supplier could not locate the part he needed??)
Hope this helps. Thanks James
Apr 04, 2011 | Heating & Cooling
Entire basin is draining all over the floor. Local plumber checked all the hoses and replaced. Comment from other cafe indicated that the unit may have a cracked casing, Phone advice from other...
yes I would ,to test for crack nun a little water feel the pipe if its coming from the side of the pipe a washer will not do make sure the waste has no water leaking from this I have a big favour if you can take a picture pls come back to me quick ,I do 100s of them a week some are just tight ups some need replaced,its not a hard job to do,we make it seem hard when its not ,I just hope you last plumber didn't rip you off
Jun 16, 2017 | Cma Dishmachines CMA-180UC Dishwasher
My hot water in the kitchen comes out slowly but the cold water comes out like it should.
Your water heater pipes may be clogged - if your water heater is more than 7 years old you may need to replace it. Visually inspect your water heater to see if there's any visible rust near the bottom or a slow leak. If you are on a well as opposed to city water, Rust is probably your culprit. If it's electric, remove the covers and check out the elements there - there should be a small amount of rust visible if the heater is old. Gas units are very different in construction, and changing a water heater is not exactly an easy job - I would suggest calling in a Plumber to change it, as most states require a licensed plumber to execute this type of job, and many cities require permits for this to be done too.
Nov 03, 2010 | Home
HOW DO YOU GET THE EKLAY WATER FOUNTAIN APART TO REPLACE SOLENOID SWITCH
I have written up the entire process with all the steps and lots of pictures on my blog at: http://johnfixesstuff.blogspot.com/2014/10/how-to-fix-elkay-model-ezfs81b-replace-solenoid-35981c.html
Sep 16, 2010 | Elkay Water Cooler ADA Wall Hung 8 Gallons...
I have rust spots/stains in my bathroom door frame which is alongside my showerwater appears to be getting into the door frame (aluminium not wood) and staining the paint its rust spots so i know its...
aluminium does not rust so the stain will not be rust stains
could be leaking fitting at the plumbing pipes at the taps
could be that the washer under the tap insert is leaking especially if not replaced when doing the spindle seals
May 03, 2017 | Washing Machines
How can adjust the volume of water coming from the drinking spout on my Elkay water fountain?
On our Elkay drinking fountain there is a set screw underneath that you can turn to adjust the flow rate. I have detailed how to adjust the flow along with how to replace the solenoid on my blog at: http://johnfixesstuff.blogspot.com/2014/10/how-to-fix-elkay-model-ezfs81b-replace-solenoid-35981c.html John Fixes Stuff How To Fix an Elkay Model EZFS8 1B Drinking Fountain...
Mar 19, 2010 | Elkay Water Cooler ADA Wall Hung 8 Gallons...
Ice dispenser door flap does not stay shut
IS IT A GE? GE HAVE A PROBLEM WITH DOOR SOLENOID IN CUP CHUTE RUSTING,GET A FLASHLIGHT AND LOOK UP THERE,IF IT IS RUSTED YOU WILL HAVE TO REMOVE FRONT PANEL AND REPLACE IT,THANKS-MIKE
May 30, 2008 | Refrigerators
GE 24 in. Profile PDW9880JSS Built-in Dishwasher Logo
77 people viewed this question
Top GE Dishwashers Experts
Mike
Garth Jackson
Are you a GE Dishwasher Expert? Answer questions, earn points and help others
