Question about Fisher and Paykel Washing Machines
Fisher Paykel washer making loud whine/grind noise on spin-out
My fisher paykel washing machine in the past month has started making a very loud whining, kind of grinding noise when spinning out. This noise lasts about 30 to 45 seconds.Have had this machine about 4 years. is there a belt or bearing that could cause this? It still washes and completes cycles without interruption, however noise is quite loud and does not sound normal.
aborcass
  • 2651 Answers
SOURCE: fisher & paykel washing machine fault codes
try removing hte screws from the rear of console and within the console usually is a techsheet with an explanation of hall hte major faults
Posted on Mar 12, 2008
SOURCE: service manuals and diagnostic codes with results/reset code
http://www.aars.com.au/F&P%20Service%20manual%20517735.pdf
Posted on Feb 06, 2009
  • 10 Answers
SOURCE: Fisher & Paykel GW612 Top Loading Washing
Hi there
That fault is the pump blocked error (no change in water level).
i have a quick and easy way to solve this problem.
first turn the machine off then tilt the machine back and lean it on something(a chair or wall), look underneath, in the top right hand corner of the plastic outer boul you will see a small pump motor it has a fan on it spin this fan and if it is hard to turn that means there is somthing stuck in the drain pump keep turning the fan and try to free whatever is stuck in the pump, then try the machine on spin again all goin well the object in the pump should come out with the drain water(doing this will not harm the machine) if the object is still stuck you will need to get the water out of the machine (bailing or siphioning will work) and tilt the machine back again and take the wires off the pump and there should be a white tab on the boul holding the pump on pull this tab and twist the pump anticlockwise about a quarter turn(you will need a few towels or a boul or bucket to catch the water) and it should come off exposing the blockage.
Hope this solves your Problem.
Nick
Posted on Aug 03, 2009
  • 3 Answers
SOURCE: Fisher & Paykel Smart Drive 7.5 washing machine.
Unplug the machine have someone tilt the machine back and look under the machine for a little fan on a motor give it a turn to see if it spins it might just be sticky or it may need replacing.
Posted on Feb 20, 2010
  • 343 Answers
SOURCE: what is error code 136 on a fisher & paykel IW...
136 fault is 'motor stall'...Quite often this is a broken wire to the motor. However it could also be a Motor fault, or Rotary Position Sensor problem. Water damage can cause this fault as well. After a visual check for broken wires or water damage, and if your machine is in good condition, you should consider a tech....Good luck...Nomess
Posted on May 24, 2010
Making loud whine/growling noise while filling with water
Is your machine loud on spin cycle as-well,
Your seal and bearings need to be replaced.
Mar 02, 2013 | Fisher and Paykel GWL11 Top Load Washer
Fisher paykel codes
There is a code book inside the top of the washer where the electronics are.
Apr 02, 2009 | Fisher and Paykel GWL11 Top Load Washer
Fisher-Paykel washer pump noise & some water left in tub
Lube the brass bearings on the motor. For some reason the bearing on the bottom nearest to the cooling fan will start to whine. I would guess because it's kicking dust up around the unit. I used a lube that will hold in place. Lube between the bracket that holds the motor together and by the fan. The noise should stop. I also suggest you lube the top bearing as well. The lube I recommend is a Silicone paste type.
Jan 04, 2009 | Fisher Paykel EcoSmart GWL15
Washing machine makes buzzing noise
Check the water pump for an obstruction in the chamber area, your pump may be sticking and that will cause the buzzing sound. The water pump runs during the fill portion of the cycle on several of the selected wash cycles to recirculate the water.
Nov 06, 2008 | Fisher Paykel EcoSmart GWL15
Noise in wash cycle
This is normal, because your washer will make sounds that you may not have heard from other washer.
Jun 07, 2008 | Fisher and Paykel Fisher Paykel Intuitive...
Fisher and Paykel Washer leaking water
call fisher paykel they will take care of you chances are the diverter valve is bad they have been having problems with them and make sure your repair people are fisher paykel certified VERY IMPORTANT
Dec 18, 2007 | Fisher Paykel EcoSmart GWL15
Washing Machines Logo
1,084 people viewed this question
Top Fisher and Paykel Washing Machines Experts
Dan Webster
Dan Webster
Owen Barnes
Are you a Fisher and Paykel Washing Machine Expert? Answer questions, earn points and help others
