Question about Epson PictureMate Photo Printer
I just put a new ink cartridge in and it's printing in blue streaks after several tries. What do I do?
    Problem Solver:
  • 14 Answers
Remove the cartridge
Take a cloth or paper towel and lightly dampen with warm, distilled water.
Fold the towel in half twice and hold in the fingers of one hand
With your other hand, gently "Blot" the cartridge by pressing the printhead into the towel a few times.
Insert the cartridge back in.... Try this!! hope it works!
Posted on Feb 02, 2010
Printer has stopped printing blue
Make sure that you are inserting only genuine Lexmark cartridges in your printer. Removing then re-inserting the color cartridge into the printer is a quick to minor cartridge communication issues.
Make sure that your color cartridge still has substantial ink level for printing using the Lexmark Solution Center software on your computer.
Click Start > Programs > Lexmark X74-X75 > Lexmark X74-X75 Solution Center. Check the ink levels.
If color ink level is still good, then it probably just needs some cleaning. Print quality issues can be due to dirty or clogged print cartridge nozzles. From the Maintenance tab in the Lexmark X74-X75 Solution Center, click Clean print nozzles to fix horizontal streaks. Your printer will then print a test page. Try to print a color page again to verify that the problem with the blue color is fixed.
If the problem continues, try to insert a different known working color cartridge to identify if it's a faulty cartridge issue.
Oct 26, 2011 | Lexmark X75 All-In-One InkJet Printer
After several head cleanings, the blue & magenta test patterns continue to have blotchy patterns that result in streaking across my printed documents. How can i get these two to print evenly?
You can try removing the cartridges from the printer and putting the print heads (the bit the ink comes out of) in a saucer of warm water for a few seconds and then wipe any excess off with a clean lint free tissue.
The warm water softens up any ink that may have dried up making it easy to wipe away. It also saves a lot of ink in comparison to running the head cleaning utility which effectively forces ink through to try and clean itself.
After this, ensure the cartridges are dry, replace them and run the head cleaning utility again to see if it has resolved the problem.
Regards,
sjstore2
Dec 18, 2010 | Epson CX8400 All-In-One InkJet Printer
Leaving black streaks down paper? Ink cartridge
If this started after cartridge was replaced, then it is probably defective.
Take the cartridge out and take a look at the print head. Clean the print head.
Put the cartridge back in
Try and feed paper (not printing anything on it, if you can not get it to just feed paper, print a blank page) and see if it still has lines. If so, you are probably going to have to clean ink from inside the paper feed area. If not, try using it for a while and if it starts again, get a replacement cartridge. You might want to save some of the bad prints to show the clerk and try to get the new cartridge under warranty.
Mar 18, 2010 | IBM Infoprint 1612 Express Printer
I have a HP 4100 printer. Installed new ink.Purple streaks
That's a neat trick. The 4100 is a printer that uses one BLACK toner cartridge. It doesn't print in color. And it doesn't use ink.
Oct 24, 2009 | HP LaserJet 4100 Printer
My canonmp830 printer is not printing in black ink
**Repeat from previous post. Would not print black. I went through all the troubleshooting of cleaning the printhead several times. The Nozzle check (found under Printing Preferences/Maintenance tab) kept coming out without the PGBK section (Black) printed on it. All the colors printed. If your see any of the colors missing, it is probably the same problem---it needs the Print Head replaced.
Part # QY6-0061-010. I was able to find it at Canyon Computer Supplies in Phoenix, but you can also order them via the internet from multiple outlets. Mine cost $59.57 with tax...much cheaper than a new printer. The replacement is very easy...Canon has info on how to do it at http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&fcategoryid=123&modelid=12804#SupportDetailAct ...if the link doesn't get you right there, search MP830, Support & Service, then search print head & you should find it. Once you remove all the print cartriges (printer ON), the gray lever on the left side lifts up and releases the print head...which is the unit that houses all the print cartridges. I just put the new print head in, replaced all the ink cartridges, did a nozzle check...and it worked!! I love fixing things myself.
Jun 02, 2009 | Canon PIXMA MP830 All-In-One InkJet...
Canon Pixma IP3500 prints B&W with white streaks
as i can suggest you that it can be the problem of head clogged internally where you insert your black cartridge .and the other main cause is while you give a head cleaning command to get the cartridge cleaned it sucks or pulls  the ink from the cartridge in such a huge quantity that 3-4 cleanings make the cartridge totally empty .due to this the ink gets very low and the printouts come with streaks.many a times setting the print mode in best makes the copy perfect.but the printing gets too slow in that best mode.
Feb 26, 2009 | Canon PIXMA iP3500 Printer
Blank Ink not pumping to print head
Turn off the device after removing the printhead After removing the printhead, turn off the device, wait about 20 seconds, and turn it on again without the printhead installed. After it has restarted, reinsert the printhead.
it will go through this long routine of perhaps 20 min or so. after its compleate it should print great.
Nov 22, 2008 | HP Officejet Pro L7590 All-in-One InkJet...
New ink cartridges and still won't print .....streaks and faded ink.
hi ,
-try cleaning it manually - by a lint free cloth and moisten it with water then dub unto the printhead of the cartridge- 4 about 4-6 times,then finish it with a dry cloth-
-then run the cleaning cartridge on the printer
-then print an alignment page
-there is no problem on the printer its just the cartridges
jim
Sep 30, 2008 | Lexmark X1150 All-In-One InkJet Printer
Problem printing with HP Business inkjet 1200
I have a HP Business Inkjet 1220 Printer, and the block ink cartridge light is flashing. I replaced the cartridge with a brand new one, closed the door, and black ink light is still flashing. I put in another neew black ink cartridge, closed the door, and same issue- black cartidge ink light flashing. I cannot print- what to do?
Oct 28, 2007 | HP Business Inkjet 1200dtn Printer
Epson PictureMate Photo Printer Logo
338 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
