Question about LG WD-3274RHD Front Load Washer / Dryer
Water pump failure?
Strange noise began coming from the compartment that houses the water pump (like a baseball card in bicycle spokes.) I emptied the machine of water, checked the filter, removed coins, collar stay and a bobby pin. Afterward the noise continued. My girlfriend accidentally added 3 times the correct amount of detergent and found that the machine was full of water after the cycle had completed. I drained the water, disassembled the machine, confirmed all tubes to be clear, ran diagnostic mode meant to operate the water pump and the machine simply filled with water: no drainage nor sound from the pump compartment. Drum spins perfectly, but the machine will not drain. Is my water pump shot?
  • LG Master
  • 3,361 Answers
The water pump drain motor has something stuck in it or it has gone bad like most LG parts.
Remove the drain pump and look for any foreign object to be removed.
Check the drain pump for a failed pump motor.
LG is pretty.
Posted on Feb 02, 2010
Testimonial: "Thanks for the feedback - good, fast solution. Took the pump apart and verified that there's nothing in there that shouldn't be. Ordering new now. "
Whirpool front load washer model LHW0050PQ4 makes sputtering sound during spin cycle
Power plug off the wall first. Check out the pump which comes after the filter, something shd be clogging there; it shd move freely.
Remove back of machine to see if anything is touching the wheel belt or pulley.
Pl click helped, if helped.
Apr 09, 2013 | Whirlpool LHW0050PQ Front Load Washer
Machine had been giving E20 error code - filter cleared and it re-started ok. When wash was in progress - jammed at rinse stage and all lights came on (except spin speeds) and humming noise and nothing...
E20 is an error code for drainage failure.
Check where the appliance drain hose connects to the house drains for a blockage.
If it's onto a spigot under the sink, take them off and check both for a blockage.
If these are ok then it's likely to be a blockage in the pump.
You'll need to drain the water out manually.
Put a shallow dish below the filter and slacken the filter.
Tighten it to stop the flow of water while you empty the dish.
Once empty, take the filter out, clean out the debris and ensure nothing is left jamming the pump.
Before refitting the filter, put the machine on drain or spin and listen at the filter housing to see if you can hear the pump running.
If you do, fit the filter and try the machine again.
Thanks for using FixYa
Oct 11, 2011 | Zanussi ZWD1470W Front Load Washer / Dryer
My machine is making a weird noise. Sort of like a baseball card in bicycle spokes.
I had the exact same problem with my machine. I just had it serviced last week. The problem was loose change that was inside of the pockets in the laundry got caught in the waterpump. The repair person had to get the change out of the waterpump and it runs just like new again.
Oct 26, 2010 | Haier HLP23E Top Load Washer
There is a clacking sound in the engine. Sounds
could mean a lot,,,valve train,,,timing chain,,connecting rod, or risk pin,,that's the part that connects to the piston to the connecting rod that connects to the crack shaft,,if the sound is more louder on the bottom it could be that,,,if on the passenger side of car the motor noise is loader,,could be timing chain,,,try in locate the clacking noise first,,,
Apr 05, 2010 | 2003 Pontiac Grand Am
The pump, pumps out the water after the wash, Not after rinse.
the magnetic shaft in the pump worn, so you will have to replace the pump
Feb 04, 2010 | Kenmore Washing Machines
Grinding noise from passenger side engine
The water pump bearings could be going out and they will make a grinding noise.The water pump doesn't always leak when the bearings are going out.
Sep 01, 2009 | 2002 Dodge Neon
2004 Ford Taurus V6 noise underhood appears to be belt
Sounds like a bad idler pulley,or belt tensioner. Most likely not water pump since the check engine light is not on. Altho it couold be the water pump and for some reason (bad sensor, burnt out light) the check engine isnt coming on. Either way it would be best to have it looked at.
Apr 21, 2009 | 2004 Ford Taurus
Loud noise
Hard to say for sure without more info. Sounds like something caught in pump though. Give us the brand and a model number.
Nov 15, 2007 | Washing Machines
LG WD-3274RHD Front Load Washer / Dryer Logo
820 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
