Question about Dishwashers
How can I determine what model number my kenmore
My Kenmore dishwasher seems to leave food on dishes and is not working as well as it has in the passed. Is there some way to determine what the problem is or if I need an expert
    Problem Solver:
  • 10 Answers
The model number may be on a label located in the door jamb, probably along the top. If not try removing the lower panel (below the door.) You may find a placard there.
Posted on Feb 04, 2010
I have a kenmore dishwasher. I had it checked out by service and there is nothing wrong with it however it leaves a white film on my dishes. What can i do to stop this?
You may try a different detergent, and this may give you some relief. What works best, in my opinion, is to use the least amount of detergent that you can, and still get the dishes clean. Cut the added detergent in half, and go downwards from there. We are currently using ~25% of the recommended amount, and the dishes clean up very well, with no residue.
Rinsing excess food off of the dishes prevents the soft food disposer in most new models from being overwhelmed, and will increase the overall performance of your machine over several cycles.
Also, using a good rinse agent will help, as will opening the cabinet door after the drying cycle (while still warm), allowing the dishes to continue to air dry.
Hope that this gives you some relief.
Best regards,
--W/D--
Jan 20, 2011 | Kenmore 24 in. 17482 / 17484 / 17489...
My kenmore dishwasher model 363.1404898 is not cleaning my dishes and leaves behind food on dishes
Check your heating element..
A bad heating element causes many problems in dishwashers…
Dishwasher Problems The Heating Element not Working
Dishwasher Maintenance
heatman101
Asker's Testimonial " explanation very clear. will give it a go and see how simple it was. thanks Ronnie " - ronnieshomes
Sep 04, 2010 | Kenmore Dishwashers
Kenmore Elite dishwasher will not dissolve soap or wash well.
Temperature should be 140F. and the units heater should energize during fill to achieve this.
May 19, 2010 | Kenmore 24 in. 15173 Stainless Steel...
Dishes and glasses are not coming out clean even inside of dishwasher has some residue left on it after washing
Most dishwashers have a soil separator which separates the soil from the water while it's washing. When a wash cycle is over a valve opens in the separator to allow the soil to go down the drain. If it's not working properly the washer will leave a film or food particles on the dishes.
Post your model number and I'll try to find a diagram which shows you your parts.
Apr 19, 2010 | Kenmore 15121 Built-in Dishwasher
Dishwash
sometimes those dispensers become defective,, make sure nothin is obstructing it from opening possibly dishes or rack attachments,, if not then u will need to order a new dispenseer assembly if this is a whirlpool built kemore,,,( kenmore just puts there name on aplliances, they dont build them) just to let u know if u didnt know already...
deteremine your model number go to sears online check out there parts and service page and research parts by puttin in your model number and determine the part number for your model ,,,, i believe they vary from 20 to 60 dollars ,, this is somethin you could do just have to get part and seperate the panles by removing the screws all around the inside door.. hope this helps
Jan 31, 2010 | Kenmore 24 in. 17482 / 17484 / 17489...
Kenmore 17033 dishwasher will not clen dishes
USE JET DRY and clean the system every once in awhile by running it through a cycle with no dishes and use washer cleaner for that model.
Jan 07, 2010 | Kenmore 24 in. 17033 Built-in Dishwasher
Kenmore elite dishwasher leaves food particles on dishes
If someone is putting dishes in the washer and obstructing the spray ams that would cause food to stay on dishes. After loading dishwasher and pushing in baskets make sure the spray arm doesnt hit any of the dishes causing them to not clean properly. If that doesnt work or is definately not your problem try removing the spray arm and seeing if it has food inside of it. Some times they get food build up in them and need to be flushed out.
May 12, 2009 | Kenmore 24 in. 17482 / 17484 / 17489...
Dishes not rinsing well,
I would check the bottom drain area. Sometimes food can stay down there and block the drain or get back around onto the next load.
Apr 06, 2009 | Kenmore Dishwashers
My kenmore elite leaves food all over my dishes and utensils when the cycle is over. what would the problem be
Try rinsing all of the food off the dishes before u put them in the dishwasher, also run the hottest water u can into the sink before u start the dishwasher.
Mar 06, 2009 | Kenmore 24 in. 17482 / 17484 / 17489...
Dishwasher is not washing dishes.
Make sure your water is at least 120 degrees and change to a dishwasher detergent with a water softener and a rinse aid in it.
Jan 31, 2009 | Kenmore 24 in. 17032 Built-in Dishwasher
Dishwashers Logo
43 people viewed this question
Top Dishwashers Experts
Owen Barnes
