Question about Maytag Washing Machines
How to remove agitator on maytag washer model lat9457bae
  • Maytag Master
  • 3,361 Answers
Use a 1/4 inch hex wrench to loosen the screw on the lower part of the agitator,then pull it off.
EZ...PZ.
Posted on Feb 02, 2010
I have a Maytag Washer Model LAT9206BAE, I have cleaned the washer but my clothes are still getting a lint like substance on them. Is there a screen or something on the discharge that may be blocked.
There is no filter. You may have something that is hung up under the agitator. To remove the agitator, remove the fabric softener cup, then the bolt that holds the agitator on and lift the agitator out.
Nov 22, 2012 | Maytag Washing Machines
HOW DO i REMOVE THE AGITATOR FROM maYTAG WASHER MODEL # MAV6457AWW
Gently remove the fabric softener cup off of the top of the agitator
Using a ratchet, an extension and socket; then remove the retaining bolt under the fabric softener cup.
The agitator will lift off after the bolt is removed.
Installation is:
Drop the agitator in place. Install bolt.... tighten bolt with ratchet, extension and socket. Install the fabric softener cup.
Fabric softener cup is item 14 this link:
http://www.appliancepartspros.com/partsearch/model.aspx?model_id=5170378&diagram_id=28464917#d28464917
The bolt you need to remove is item 4 of the above link.
Thanks for choosing FixYa,
Kelly
Feb 05, 2011 | Maytag MAV6457 Top Load Washer
I think my daugther's retainer is stuck under the agitator. How can I get it off to check?
If this is a Maytag Atlantis model washer, just follow these steps to remove the agitator:
1. Remove the center post cap and softener dispenser by pulling it off.
2. Locate the agitator bolt under the center post cap and loosen.
3. With the agitator bolt removed, lift up on the agitator by grabbing the bottom flange.
If the model number is incorrect, please post back with your correct information. I hope this helps you.
Nov 11, 2009 | Maytag Atlantis MAV7551 Top Load Washer
REMOVAL OF TOP AGITATOR ON MAYTAG WASHER
i believe all you have to do is put you fingers underneath it grab the sides and pull up,that will remove the whole agitator,if you want to change the dogs,pop off the top fabric softener dispenser and take out the 7/16 bolt and remove middle section,change your parts and put it back the same way you took it apart
Nov 03, 2009 | Maytag PAV2300 Top Load Washer
Maytag washer model number lnc6760 how do you get
Hi, Remove the cap on top of the agitator and you will find a bolt holding the agitator in. After the bolt is removed, the agitator should lift out.
Please let me know if this helps or if i can assist you further.
Vic
Jul 05, 2009 | Washing Machines
MAYTAG top loader makes high pitched squeal when agitating/spinni
This is a classic symptom of pulley/motor shafts/bearings in need of lubrication. It's not the agitator. You'll need to take the back off (with power unplugged) to access.
May 12, 2009 | Maytag PAV2300 Top Load Washer
How do you remove the agitator on a Maytag Dependable Care Washer?
If this is a Maytag Performa or Atlantis model all you have to do is remove the center cap on the agitator by pulling on it and locate the agitator bolt underneath. Loosen the bolt, and the agitator should pull straight up.
If this is a Maytag Dependable Care series there will be 1/4 inch screw along the side of the agitator towards the bottom. Remove this screw and the agitator will pull straight up.
PS If the problem is due to the build up of fabric softener, soak in some hot water to loosen it up. Fabric softener is essentially a form of liquid wax and it is common for it to accumulate and clog the dispenser in this manner. Periodic cleaning is recommended.
Aug 09, 2008 | Maytag Dependable Clean Top Load Washer,...
I have a foul smell comming from my washer I want to try to take off the agitator and clean it How? :)
It depends on what model Maytag washer you have. If you have an Atlantis or Performa model Maytag you remove the agitator by, first, pulling the agitator cap and softener dispenser off. Locate the bolt on the center post and and loosen. The agitator will pull straight up to remove. If this is a Dependable Care model Maytag, there's a 1/4 inch screw located on the SIDE of the agitator about 3 quarters of the way down. Locate this screw and loosen. The agitator will pull straight up to remove. I hope this helps you.
Aug 01, 2008 | Maytag Washing Machines
Maytag washer fabric softener dispenser is yucky
There is a 1/4" machine screw in a recessed hole close to the bottom of the agitator. Remove screw. Lift agitator off agitate shaft.
Nov 28, 2007 | Washing Machines
Washing Machines Logo
201 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
