Question about Microsoft Xbox 360 Console
Single red light - Microsoft Xbox 360 Console
    Problem Solver:
  • 5 Answers
If this is on the Xbox 360 power button, you have the 'red ring of death'. get a new Xbox or clean it with a dry towel.
Posted on Feb 02, 2010
My new Dyson Serial Number PM8-US-HHB1494A will not charge.
Suspect a dead battery or a defective charger
Dec 28, 2016 | Dyson Vacuums
A boat with a flashing red light at night what does it mean
The only requirement for a sea going vessel to use a light that is flashing red at all is for a wind in ground craft. (a pontoon enabled aircraft) that is flying close to, landing on or taking off from water.
Nov 06, 2016 | Televison & Video
Separate 1 switch 3 lights
You need separate wire going to each light.
Here are diagrams:
2 single pole switches, before you started to replace
http://waterheatertimer.org/images/2-single-pole-switches.jpg
Single pole and 3 pole to control each light separately: must identify black wire to each light. If each light does not have separate black wire inside the switch box, then it is not possible.
http://waterheatertimer.org/images/single-pole-and-3-pole.jpg
Add a comment
Jul 05, 2013 | Electrical Supplies
I purchased the pr 180 photo electric switch from home depot.there are not any wiring instructions enclosed.I have two black wires and a ground in the wall. there is a green ( ground ) black,red, & a...
Leviton PR180 is a single-pole or 3-way motion activated light switch.
Resources:
http://www.leviton.com/OA_HTML/ibeCCtpItmDspRte.jsp?item=452283§ion=10892&minisite=10026
The green connects to bare ground wire.
The yellow-red is not used EXCEPT to replace 3-way switch. Cap off yellow-red wire when wiring single-pole.
Your single pole switch has two black wires.
One black wire is Hot from breaker, and the other black wire goes to Load.
Turn power on, and test each black wire to bare copper wire. Tester lights up on Hot wire.
Hot wire connects to PR180 black wire.
Load wire connects to RR180 red wire
Take a moment and rate answer:
And take advantage of fixya expert assistance live.
For a price, expert works with you while you work on switch or any do-it-yourself project.
Fixya is always less expensive than a service call.
Sep 07, 2011 | Leviton ODS10-ID Decora Wall Switch...
My GE lighted rotary dimmer switch has 3 wires coming from the same hole- 2 black and one red. Is the red wire the ground wire?
No.
It is most likely a three way dimmer, where the two black wires would run to the other three switch, and the red wire would either run to the breaker panel or the light fixture (depending on the electrical box location).
If you're using this in a single-pole application, place a wire nut on one of the black wires, and then wire it as a single-pole device using the red wire and the remaining black wire.
And make sure you have the power turned off before attempting.
Jan 26, 2011 | General Electric Ge Deluxe Lighted Slide...
Red light at power on
Too bad. The quickest/cheapest way to proceed is to buy another router, either online (through 'www.UsedEverywhere.com') or at a "big-box" consumer electronics store, for less than $50.
Aug 01, 2010 | Linksys Wireless-G WRT54GS Router...
I need schematic for 450 signal bridge
Each side of the 450 signal bridge has 3 connections....one common to both one lights green light the other the red You need to connect the red and green wires to a 153C contactor the pressure switch that changes the light colors as the train passes. The side of the 153C that has 2 terminals is for the red and green bulb wires. The single terminal and the third terminal on the 450 get connected to 12V fixed voltage. Repeat the process for the second track and contactor. This is the simple mode of wiring a signal bridge or any of the single change the color signals...153,163,353 and 452 single signal; bridge.
Feb 22, 2010 | Toys
Replacing a ceiling fan pull chain light switch.
that is strange
normally a 3 wire switch could only be able to control 2 things + off. black would be common, red would be one fan speed or set of lights and blue would be the other fan speed or set of lights.
if it is a replacement, couldn't you just hook it up like the switch you are removing?
most likely the black wires are grounds for everything and white would be power. hook it up however you like. white power would hook up to the black wire on the switch and then the blue to one light and red to the other set of lights white wires.
good luck!
Jan 06, 2010 | Westwind Classic Hugger Polished Brass 52"...
How can I wire fluorescent tube light.There's 2 cables incoming through the wall.One has red,black and green/yellow.Other has red and black only.I've tried connecting both reds from the incoming cables to...
if you have 1 switch ! take the cabel wiv the yellow red black an green conect green to E earth , conect the to reds together that will feed the switch connect the black to the nutral on the light fiting and tape up the yellow not needed !,then take the cabel wiv only red and black , the red is connected to the other red as explaind above ,then the black is the return from the switch therfor connect it to the live tuminal on the light fiting MAKE SURE U TURN IT OFF AT THE FUSE BORD FIRST PLEASE!!!!!!!!!!!
Sep 29, 2009 | Hydrofarm Hydrorfarm Flco200d Fluorescent...
Single red light flashing
Needs 3 red light repair. You can contact us at xbox360fixer@verizon.net
THanks
Jan 03, 2009 | Microsoft Xbox 360 Console
Microsoft Xbox 360 Console Logo
Top Microsoft Video Game Consoles & Games Experts
marley mcelhinney
Tre Elkins
Martin Murray
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
