Question about Saniflo SaniPlus-Round SaniPlus Macerator Toilet with Round Bowl
Is it okay to run a sink for a kitchenette through this system? A small amount of greasy dishes will be washed in it.
  • 122 Answers
It will be fine. The soap and hot water will keep the grease from congealing. Even if it does, the solids from the toilet and the rpm of the macerator will keep it pretty darn clean. I did one for a rental apartment 10 years ago and have no issues at all.
Posted on Feb 02, 2010
My Maytag quiet series 200 is not cleaning and despite many attempts it is also leaving terrible residue on dishes.
I found this on ehow I believe it will help. How to Troubleshoot Dishwasher Residue By Dale Yalanovsky eHow Contributor
5Found This HelpfulGeorge Doyle/Stockbyte/Getty images
Dishwater residue is a fairly common occurrence, and several things can cause it. Even the newest dishwashers may leave residue, and it might have nothing to do with the actual dishwasher function itself. However, there are things you can do to prevent, limit or completely remove dishwasher residue during every washing cycle.
Other People Are Reading
  1. Detergent Residue
    • Modern phosphate-free detergents are the main culprits when it comes to detergent residue. After every wash, many leave a slight whitish residue behind. After several washings, the residue becomes caked on and leaves a noticeable white tint to your dishes. Some dishwasher detergent brands are better than others, and either minimize residue or do not leave any. Once residue is present, however, the only way to remove it is by hand scrubbing or scraping.
    Hard-Water Residue
    • Hard-water residue comes from non-softened water from your hot water tank. Non-softened water leaves a white tint on dishes, but no amount of scrubbing will remove it. Only by wiping a small patch of the dish with vinegar or lemon juice will you be able to ascertain whether the white residue left is hard water or detergent. The slight acidic action of the vinegar or lemon juice removes hard-water stains, but they have no effect on detergent residue.
    Greasy Residue
    • If the dishes feel greasy when they come out of the dishwasher freshly washed, you are dealing with a greasy residue. There are two main reasons for this: either the detergent is not an effective grease remover, or the hot water inside of the dishwasher, either from the hot water tank or the dishwasher's heating elements, is not hot enough. Boosting the hot water temperature on the water tank may solve the problem, and a second wash cycle may be needed for the dishes. A preventive measure of running the dishwasher empty with a full load of detergent also removes the residue inside of the dishwasher.
    Streaking and Spotting Residue
    • If you have spotting or streaking on your dishes, that may be a sign you need a rinse agent. Many modern dishwashers recommend a rinse agent to prevent spotting or streaking, and without one, your dishes will never be crystal clear or streak-free. The next time you do a dishwasher load, add a rinse agent. If the dishes come out spot- and streak-free, the problem is solved.
Read more : http://www.ehow.com/info_12285021_troubleshoot-dishwasher-residue.html
May 19, 2015 | Maytag Dishwashers
We have a Kenmore Elite 630.16304401 dishwasher, lately we are getting small black greasy spots on the plastic dishes, also same spots on the plastic parts in the sump where you clean the filter? We h
A couple of thoughts:
1) It could be a gasket somewhere starting to break down. Check your door seal.
2) Food particles could have gotten caught somewhere in the drain hose, or something, and then turned black with mold and bacteria, then when you wash, they get siphoned back into the dishwasher if the flap which composes the anti-siphon check valve on the drain hose is starting to stick open.
Try putting a cup of bleach in the top rack and run a complete cycle with no other dishes in it. Then, load up some plastic dishes and wash them as normal. See if that helps. If it does, replace your check valve.
Also, insure that your drain hose is looped up above the bottom of your sink to prevent debris from your garbage disposal backing up into your dishwasher.
Good luck and keep us posted!
Oct 22, 2014 | Kenmore Dishwashers
LG dishwasher
If you're sure you're using enough soap, check that your hot water is connected and that you're using a hot-water wash (some dishwashers have a cold-water option, this will often give unsatisfactory results if washing greasy dishes - especially beef fat).
Jul 02, 2014 | Computers & Internet
White powdery film is on dishes at end of cycle.
Too much detergent. the amount of detergent should vary with the amound of soil left on the dishes. Most users will pre wash their dishes in the sink, but still use the full recommended amount of detergent. There is no soil for the detergent to bind with, so it builds up in the pipework of your dishwasher. when the water evaporates during the drying cycle, the detergent residue is left behind on your dishes. Run a cycle or two with your dishwasher empty. add a cup of white vinegar to each cycle, but dont add any more detergent. After that, cut your detergent amount by half, and see if your issues go away. if not, please post the model and manufacturer of your dishwasher.
Nov 18, 2010 | Dishwashers
On normal wash cycle the dishes are still greasy and there is food debris on the inside door the machine has water and runs through its cycle but the dishes especially the top rack is still...
Depending upon the age of the DW, you may have a restricted or bad pump. You also could have a restriction in the drain line that goes to your sink.
Oct 13, 2010 | Kenmore Dishwashers
MY SISTEM IS RUNNING VERY SLOW AN FREESS UP IS NOT MOVING WHAT CAN I DO TO FIX IT?
1. Start the Windows "Task Manager" (use CTRL-ALT-DELETE to launch it). Compare the amount of virtual memory being used with the amount of physical memory (RAM) that is available.
Not enough RAM is like piling dirty-dishes in the sink;
sooner or later, you need to remove some of the dishes,
in order to make room to wash the rest of the dishes.
Moving those dishes in/out of the sink takes time.
Trying to use much more "virtual" memory than "real" memory also takes time.
2. Disconnect the Ethernet cable from the computer, and disable any built-in wireless adapter. Does the computer start to run faster, when it cannot communicate with the Internet?
3. Virus-scan it.
4. It's possible that the disk-drive has some "bad' spots -- Windows tries & tries & tries to write to that bad spot, which, of course, slows everything down.
5. Close unnecessary programs (WinAmp, BearShare, BitTorrent).
Aug 19, 2010 | Microsoft Windows XP Professional
Dishwasher overflowed, garbage disposal still works. Ran the dishwasher and noticed food and debris shooting back into sink thru garbage disposal. Water was on floor. Upon completion of full cycle, water...
Before loading into the machine you have to remove food particles. Washer will wash the greasy surface. If particles are left in the dishes, the same will find entry to the drain system. Check the drain filter in your machine. Clean them. Mostly problem will be solved!
Apr 08, 2010 | GE 24 in. Profile PDW9880JSS Built-in...
I have a greasy buildup on my dishwasher filter.
It is the grease left on dishes or pots & pans. It can be cleaned off using a good regular dishwashing detergent like Dawn in the sink, not in the dishwasher. To prevent it, scrape the dishes & pots better, and if possible, turn the temperature of the hot water up a few degrees. You should also change dishwasher detergents to a liquid, with a built in water softener.
Sep 05, 2009 | Frigidaire Dishwashers
The dishwasher was full of soap suds but most of the water drain
Suds? If you use dishwashing detergent you shouldn't get suds. If a small amount of sink type dish soap is left on a dish before loading it into the dishwasher this can happen. I would use several rinse and drain cycles with the racks and dishes removed until the suds are gone.
Never use any type of liquid dish soap made for sinks. The same thing that makes suds in the sink will make even more in the dish washer.
Hope this helps!
Feb 15, 2009 | Fisher and Paykel 24 in. DD603H W Built-in...
Smelly drum
run a load with no clothes, hot water and a gallon or two of bleach and less then 1 drop, very small amount of dish detergent. the dish detergent is used as  surfactant (makes the bleach stick to the interior walls)
run an extra rinse cycle to make sure you get all the bleach out before putting clothes in.
Jul 04, 2008 | Hotpoint Ultima WF865 Front Load Washer
Saniflo SaniPlus-Round SaniPlus Macerator Toilet with Round Bowl Logo
80 people viewed this question
Top Saniflo Home Experts
paulcarew
Donni Steen
Are you a Saniflo Home Expert? Answer questions, earn points and help others
