Question about RCA RTDVD1 System
Lost output to all speakers from surrond sound have audio thru audio output had a ststic shock when turning off after power back on no surrond sound
3 Suggested Answers
budmrtn
  • 11361 Answers
SOURCE: l46wd22yx5 rca tv lost sound thru tv speakers,
Verify first in the audio setup on screen menu that the speakers are not set to OFF. Otherwise you may have bad power amp sections.
Posted on Nov 02, 2009
  • 668 Answers
SOURCE: rca model f32695bc. I
Most of the problems with no sound on this model is caused by the eeprom that has crashed the data for the audio circuit. When it does this it triggers the mute transistors on causing no sound.
Replacing the eeprom will fix the problem but you will need to make horizontal frequency, vertical and horizontal width adjustments. Because this alignment is tricky, I would not recommend doing yourself. If you do, make sure you are able to down load the service information from google. You will need to have the chassi number. Make sure to include the letter or letters after the chassi #.
Example. CTC177AB. This is important so you will be able to get the correct eeprom.
I hope this helps,
Sky Assoc
Posted on Nov 25, 2010
How do I turn off my 550 Samsung tv speakers?
Take the audio out from the audio output RC jacks (Red and White). Then connect a headphone into the headphone of the TV. The speakers then will then get off. Never insert a dummy stereo jack, as the amplifier without speakers can get damaged (depends on the audio IC used).
Jul 18, 2012 | Televison & Video
My surrond system wont work whith my vizio tv now that we downgraded to just cable whithout the dvr box i plug in the jacks but nothing come out. so my do i need a audio plug to convert it from the tv to...
look for an audio output on your tv, perferrably a digital output. the tv's hdmi wont work because its an input, not an output. if your tv does not have an audio output, you are out of luck, and will only get surround sound with dvd's/blue rays...
Mar 08, 2011 | Durabrand 5.1 Surround Sound Computer...
Not all the speakers working
Open your audio control panel and set it to 5.1 surrond sound. Not all speakers will work unless a dolby surrond sound signal is being sent out. There will be a pseudo surrond setting which will emulate the 5.1 for you in the audio control panel
Mar 03, 2011 | Logitech X-530 Computer Speakers
I have surrond sound speakers thats loud but wend
I had an issue like that with one of my dell desktops too. The speakers were very quiet. I turned up the volume on the speakers, turned up the volume in windows. Unisntalled and Reinstalled audio drivers, I eventually assumed that the speakers were just junk. After buying a soundcard (I was originally using onboard sound), I discovered that the speakers were much louder through the soundcard than through the onboard audio.
Feb 28, 2011 | Dell Computers & Internet
Bose surrond sound not working...
Your TV may have a setting to make its Audio Output Variable or Fixed. That is, as you turn the TV's volume down or up it will either vary the output (as it seems to be doing in your case) or keep it Fixed so external electronics can still use it when the TV's volume is down or off. Some TV's do it another way - they have a selection to turn the TV's speakers OFF.
Feb 03, 2010 | Bose Cinemate Digital Home Theater System...
Kenwood VR6070 speaker/amp problems
unit needs repair. Look at the b speakers. Conect a speaker or two to the B position. If you have no sound than your surrond sound is ok and the unit is bad. Sound comes directly into the b speaker and not threw the surrond system. My 6070 has a cold start up problem. no sound. time to purchase a new one. to costly to repair.
Dec 30, 2008 | Kenwood VR-6070 Receiver
AUDIO
This TV ONLY transfer audio OUT to a ANALOG SYSTEM THRU AND ANALOG SIGNAL. That is, TV will play sound fine in your surround system but any digital (HDMI) wont sound.
Mar 11, 2008 | JVC HD-56FN97 56" Television
Wire house speakers
Two ways--first you can open up the unit and use the exsisting wires from the tvs internal speakers or goto radio shack and ask them for a audio jack splitter,you would than connect the wires from the speaker to the splitter then plug the jack into the audio input on the back of the tv.If your thinking youll get more sound from these speakers by doing this it wont work unless you have a surrond sound system.Only an amplifier can boost the output.
Feb 23, 2008 | Alpine CDA-9815 CD Player
Setting up receive set top box and tv for surround sound
Plug the TV to an open channel on your receiver via this output:
*Rear, 1 x Digital audio output (coaxial) ( TOSLINK )
This will look like a single RCA output plug.
Set that input channel on your receiver to some sort of virtual surround mode because it doesn't look like your HDTV has a decoder in it (meaning it will come out stereo and the receiver will have to fake it).
Turn the volume all the way down on the TV and use the receiver to control TV volume just as you do with DVDs.
*Substitute this with the digital audio output on your set top box if you are sending video only to the TV from the set top box (component, DVI or s-video connections). So video goes to the TV, audio to the receiver.
Feb 03, 2008 | Televison & Video
Surrond sound
For Stereo Mode (Front L & R Speaker), you must plug RCA cables (match up red and white) from Output on DVD player to DVD Input on the back of the receiver. Then with speaker wire, run from receiver speaker output (Front Speakers) to designated speaker (make sure + and - match up to both input and output). As for hooking up surround sound, I'm currently trying to figure that one out with just using the L, R and Center. I don' t want wire running all over the place just for rears. Hope this helps
Sep 04, 2007 | KLH R5100 Receiver
RCA RTDVD1 System Logo
76 people viewed this question
Top RCA Audio Players & Recorders Experts
Gyula Lacz
Are you a RCA Audio Player and Recorder Expert? Answer questions, earn points and help others
