When I turn on my computer it does not detect the external Lacie 1 tet, also the hard drive starts to beep regularly until I turn it off.
  • 19,396 Answers
Hi.
If the hard drive is beeping, that means that it is damaged.
You can follow a general troubleshooting here, but it may not help:The computer does not see my drive anymore
Troubleshooting is for WD disk, but it is the same on your Lacie.
If the beeping is coming from the board at the bottom of the hard disk drive, inside the Lacie, then the disk is usually not repairable.
The internal hard drive must be replaced and the data will be lost.
The only definitive test is removing the hard drive, observing its behaviour , and eventually testing it on a different enclosure.
If when opening the case, the drive itself is clicking and beeping, then the hard drive heads are broken. If it is beeping with no sound, then it is a broken hard disk motor.
In both situation the data can only be recovered using a special facility (clean room). Recovery is expensive.
Try first following general troubleshooting. Also call Lacie at the number listed on the owners manual to see if they can cover part or all the repair.
If the hard drive is beeping, usually you have lost the data inside the hard drive.
Posted on Feb 02, 2010
My computer will not detect my LaCie external hard drive
Hi, Try to restart your computer while it is connected. It may detect it then. Good luck.
Sep 23, 2011 | LaCie Computers & Internet
My 500G Lacie external drive is no longer detected by windows. Sometimes it will say the USB port or device is mulfuction. Sometimes it does not detect it at all.
Does this happen in several computers? If it does, then the interface is probably damaged, in which case you could (at your own risk) disassemble the drive and install the hard drive inside a desktop computer to access your data., since theres a standard SATA hard drive inside.
Mar 21, 2010 | LaCie External USB 2.0 500GB 7200 RPM 500...
Lacie 1 tb external hard drive won't work
ya .. put it for replacement and u get a new one for free .. just dont tell them u dropped it
Jan 10, 2010 | LaCie Hard Disk 1TB Desktop with Hi-Speed...
Imac is not detecting my LaCie External Hard Drive
Do you have a CD disc software installer of your external hard drive (F.A. Porshe 160GB).? If you got it, you must reinstall it, so that your Imac can detect it. Otherwise, find it at the internet and download it.
The power failure could have damage some stored data about your External Hard Drive in your Imac. That's why, you have to reinstall it. Send us your e-mail comments for us.
Oct 17, 2009 | LaCie Design by F. A. Porsche 160 GB Hard...
My computer is not detecting my LaCie Hard Drive
there is a usb port inside hd .box /many time it is damage and also usb cablle damage . so once time change this thing one by one to check. there is a rare chance to damage hdd. we have facinge many time same problem. this hdd and laptop hdd are same. only potr is diffrent, (nepal)
Oct 09, 2009 | LaCie External USB 2.0 500GB 7200 RPM 500...
Lacie extern. hard drive is recognized, but I can't access files
Try connecting the Lacie to another computer, if it doesn't work then the hard disk may need to be formatted using Disk Manager. I suggest you format as a primary partition in FAT32.
If it doesn't work then it is possible that the hard drive in the Lacie has failed.
To test the hard drive, remove it and connect it to an USB hard drive adapter and connect it to a working computer's USB port. If it deosn't detect it as an external drive and you connot open folders and files then it is faulty.
You can install a new hard drive in the Lacie and then format in FAT32
There are companies that can recover data from faulty hard drives BUT it will cost you an arm and a leg for their services.
Sep 12, 2009 | LaCie F.A. Porsche (301177) Hard Drive
I have a lacie design by F.A. Porsche 250Gig Hard drive - It has failed and is making a buzzing sound follwed by a beep - is this repairable?
Sounds like the hard drive in the Lacie has fauled.
You can install a new hard drive in the Lacie and then format in FAT32.
Sep 10, 2009 | LaCie Design by F. A. Porsche 160 GB Hard...
Is my LaCie External USB 2.0 500GB fried/dead???
You're not missing any step at all, because with SATA hard drive if its really working your computer should
automatically detect it and since this hard drive suddenly stop working there's a possibility that its already
fried but if you want you can try this hard drive again to a different computer and if still not detected by
second computer its already dead.........
Nov 07, 2008 | LaCie External USB 2.0 500GB 7200 RPM 500...
Lacie 120GB dropped
If you open it up you will see that the drive is a regular computer drive. You should be able to plug it into a computer as a secondary drive and try to get the data off. But if it's clicking and making noises there may be no hope. Sorry!
Jan 23, 2008 | LaCie Design by F. A. Porsche 160 GB Hard...
Lacie sounds like its working , but i can't find the icon on computer
Your hard dive is probably not formatted. You can check if your external hard drive is detected by the BIOS during bootup. You can also check this by Right click on taskbar > properties > startmenu > customize > advanced > scroll down completely and select system administration tools "Display on the all programs menu" > ok. Click on start > all programs > administrative tools > computer management > double click on storage. click on disk management(local) here you should see your lacie. If you dont then the drive is probably not detected. If you see, you can just partition it from here and it will appear in your my computer.
Dec 24, 2007 | LaCie (301015) 120 GB Hard Drive
254 people viewed this question
k24674
jasbo
jasbo
