Question about Zebra LP 2844 Thermal Printer
How do I restore factory settings to a zebra barcode printer LP-2844-Z
  • 35 Answers
The ^default command has been added to the EPL2 commands, starting in firmware version 4.39. This command will set the printer back to factory settings as long as the printer is in page mode. The command is not supported in line mode at this time. The command is case sensitive.
Syntax: ^default.
You can send the command to the printer via the parallel or serial port.
Parallel:
Open command prompt (DOS prompt) See windows instructions for details.
At the prompt type:
ECHO ^default>LPT1 <enter>
Serial:
Assuming standard communications on the printer of Baud 9600, No parity, 8 bits, 1 stop bit and use of COM 1:
At the prompt type:
Mode Com1:9600,n,8,1 <enter>
ECHO ^default>COM1 <enter>
Posted on Feb 16, 2010
  • lancer284 Feb 16, 2010
    Syntax: ^default.
    Parallel:
    At the prompt type:
    ECHO ^default>LPT1
    Serial:
    At the prompt type:
    ECHO ^default>COM1
How can I reset a Zebra LP 2844 printer to factory defaults
press the green buton untill flash 4 times, then press untill flash 7 times to calibrate and print sensor profile. turn off and turn on again.
Sep 16, 2010 | Zebra LP 2844 Thermal Printer
I have Zebra LP 2844-Z printer and the barcodes
Here are 3 suggestions.
Check that your label size definition is correct, measure your label height in mm and check that your printer driver settings match.
Perform a calibration. How?? when printer is on labels loaded and green light, hold feed key and wait for 2 blinks then release feed key. (If you release it after 1 flash you will print a configuration label)
If you are using Zebra Designer, download latest version of Zdesigner V2. Install latest printer driver V2.63. This driver & Zdesigner allows you to calibrate the printer directly from within Zdesigner. Go to File/Printer settings/ advanced options and click calibrate at bottom of page. when printer calibrates then tick the box USE PRINTER SETTINGS and printer will now work properly.
Jul 01, 2010 | Zebra LP 2844-Z Thermal Label Printer
Zebra LP 2844 Printer Error, Cannot Print
Try this
START
SETTINGS
PRINTER/FAXES
in the pop up window go to
FILE/SERVER PROPERTIES
DRIVERS
SELECT THE MFC5440 DRIVER AND REMOVE
SELEST THE LP 2844 DRIVER AND REMOVE
Now go to www.seagullscientific.com and download the Zebra driver pack, once downloaded run it and install the Zebra Lp2844 to with the USb port.
This should solve the problem, if not please come back.
trevor
Feb 15, 2010 | Zebra LP 2844 Thermal Printer
Barcode sometimes doesn't print
If this is the Eltron Version (Not the LP2844-Z), go to the driver and select the printer tab (Could be different depending on the driver used) what your looking for is a "Tools" button. In this section you can send commands to the printer, enter ^default and send. this will reset the printer to the factory defaults. Also check the page size in the application and make sure it is what your using, this is to make sure your not cutting off the barcode at the bottom.
Nov 06, 2009 | Zebra LP 2844 Thermal Printer
Zebra LP 2844 direct thermal printer is only printing half the width of the label. Label dimensions appear correct in prefrences.
check the "unprintable areas" on the preference. it should be Zero. find the Zebra Setup Utility on www.zebra.com , with that utility program, try to set the printer to the factory default
Jul 10, 2009 | Zebra Eltron LP 2824 Thermal Printer
Zebra LP 2844
The printer is in line mode. Do the following to take it out of line mode:
Turn printer power off.
Hold the feed button while turning printer power on.
When the light starts flashing, release the feed button.
When the light starts flashing again, press and hold the feed button.
When the light turns steady amber, release the feed button.
When the light turns steady green, the mode is changed.
Verify the mode by printing and inspecting a status report.
This requires good timing and may take several tries. You'll know it worked if no labels are reeled out after you're done.
Feb 28, 2008 | Zebra LP 2844 Thermal Printer
Zebra LP 2844 Thermal Printer Logo
1,145 people viewed this question
Top Zebra Office Equipment & Supplies Experts
Dave Busselle
Level 1 Expert
Are you a Zebra Office Equipment and Supply Expert? Answer questions, earn points and help others
