UNIT WILL NOT TURN ON. WAS RECORDING PREVIOUSLY. DISPLAYS "SAFE" MESSAGE.
  • taankeny Feb 02, 2010
    UNPLUGGING FOR 10 MINUTES RESET THE VCR TO ORIGINAL CONDITION. THANKS FOR YOUR HELP.
  • 19,396 Answers
Unit is in safe mode.
try disconnecting the power cord. Wait ten minutes and connect back.
If there is a disk inside the unit, press repeatedly the eject button on the unit while you turn it on, so to eject the disk.
If there is a disk inside, that is causing the Safe mode. The disk must be removed. Do the procedure above a couple of times.
Also call the manufacturer at the number listed on the user manual to check warranty status and get service details.
Posted on Feb 02, 2010
  • Ginko
    Ginko Feb 02, 2010
    You are welcome.
8550 cold reset
Performing a cold reset 1 Print a configuration page to record the previous printer settings. 2 Turn the printer off. 3 Hold down GO while turning the printer on. Release GO after COLD RESET appears on the printer control panel display. COLD RESET (in English) appears on the display for one second to verify that the key sequence has been recognized, followed by the power-on self-test message. Once the power-on self-test is finished, the message RESTORING FACTORY SETTINGS displays in English.
Sep 22, 2011 | HP Color LaserJet 8550dn Printer
I miss a few words...how do I back it up to get to that spot. When I try it...it goes all the way to the beginning. Very frustrating. Thank You.
Hello I think what you want is to over record on a top of the previous dictation, but this recorder does not work that way example: let say that you are counting 12345678910 and you want to correct and add ACBD between 5 6 to listen back 12345ABCD678910. This recorder don't work that way, the only feature that this unit have is add or insert to the end, on the file that you are listen. During playback press REC for more than 1 second the record indicator appears and "ADD" will flash for 3 seconds in the display window the indicator will turn red and the new recording will be added at the end to the current message.
I really recommend if you want to used a Digital Recorder like the old style analog recorder with a slide switch this unit is really easy to operate and all the features that anyone needs, I think the price is not bad, is really a professional digital recorder http://www.tvps.com/Products/Philips-9380-Pocket-Memo-Digital-Recorder---New-LFH-9380__PH-LFH-9380.aspx
Apr 19, 2011 | Sony ICDB600 Digital Voice Recorder
How to reset voice record on my panasonic KXTG9331T?
Greeting message
When the unit answers a call, callers are
greeted by a greeting message. You can
record your own greeting message or
use a pre-recorded greeting message.
Recording your greeting
message
You can record your own greeting
message (2 minutes max.).
1 {GREETING REC}
2 Within 10 seconds, press
{GREETING REC} again.
3 After the base unit beeps, speak
clearly about 20 cm (8 inches) away
from the MIC.
4 Press {?} (STOP) to stop recording.
Using a pre-recorded greeting
message
If you erase or do not record your own
greeting message, the unit plays a prerecorded
greeting message for callers
and asks them to leave messages. If the
message recording time (page 39) is set
to “Greeting only”, caller messages
are not recorded and the unit plays a
different pre-recorded greeting message
asking callers to call again.
Playing back the greeting
message
Press {GREETING CHECK}.
Erasing your greeting
message
If you erase your own greeting message,
the unit plays a pre-recorded greeting
message for callers.
Press {GREETING CHECK}, and then
press {ERASE} while your greeting
message is playing.
Listening to messages
using the base unit
When new messages have been
recorded, the message indicator on the
base unit flashes.
Press {6}.
L If new messages have been recorded,
the base unit plays back new
messages.
L If there are no new messages, the
base unit plays back all messages.
Operating the answering
system
Key Operation
{^} or {V} Adjust the speaker
volume
{7} Repeat message
(during playback)*1
{8} Skip message
(during playback)
(STOP)
Pause message
– To resume playback,
press {6}.
– To stop playback
completely, press
{?} (STOP) again.
{ERASE} Erase currently playing
message
*1 If pressed within the first 5 seconds of
a message, the previous message is
played.
check if this works and tell me if any issues
Apr 30, 2010 | Panasonic KX-TG1033S Cordless Phone
I can't eject DVD disk and VCR tape. The panel display write SAFE
To unlock the unit, press and hold the INFO button on the recorder's remote control for five seconds. The display will no longer read SAFE and the unit will operate correctly.
Hope this helps!
Jul 08, 2009 | Samsung DVD-VR330 VCR and DVD Recorder
Retrieving messages over phone
when your greeting answers, punch in your code, usually a 4 digit code, each manufacturer has their own default code that it comes with.. check the manual or website
Apr 14, 2009 | Lands Phones
Power button flashes SAFE
I unplugged the unit for 30 minutes and it finally went out of safe mode.
Oct 12, 2008 | Televison & Video
Vcr unit stuck in safe mode
Turn on unit. Press "lock" on remote (third from left bottom row.) Display on unit should say safe off.
Sep 02, 2008 | Televison & Video
Sony ICD-P210, ERR ACCESS message
Your problem may have been caused when you removed the unit from the PC without using the "safely remove hardware" option.
What you need to do is download the latest version of Digital Voice Editor (I think we are up to 3.1 now)
When you connect the ICD unit it will probably give you a number of access errors
Ignore them and go to the IC Recorder Menu. Select WHOLE and DELETE. Delete everything.
After a minute or so the unit will come to life and you'll see the Directories that are standard in your unit.
Remove the hardware from the computer (safely! by closing the program first) and turn the unit off.
Now turn it on...... Bingo!
Apr 01, 2008 | Sony ICD-P210 Digital Voice Recorder
Error code u80
Take It To A Repair Shop And Let Them Put In A Security Code Or Look Through The Manual
Feb 01, 2008 | Panasonic DMR-EX75EB-S DVD Recorder/HDD...
Sanyo DVD RECORDER displaying "SAFE"
the "LOCK" feature disables the front panel buttons. Press "LOCK" on the remote control to LOCK/ULOCK.
Jan 18, 2008 | Sanyo DRW-1000 DVD Recorder/VCR
Televison & Video Logo
Top Televison & Video Experts
Electro Med Services...
