Question about Dishwashers
Kenmore Dishwasher Leaving Greasy Film
Recently, our ~2yr. old Kenmore 665 Dishwasher began doing a poor job of cleaning the upper rack load. The lower seemed to be okay. I pulled out the entire interior water delivery assembly and removed a tremendous amount of scale from all the pieces. I also removed about a 1/8" build-up from the element. Even with the heated dry off, the steam poured out of the unit at the end of the cycle...but the top rack is still shaky and we noticed much of the silverware (lower rack) hadn't even been touched. I'm beginning to suspect some kind of timer and/or premature soap latch issue. We've often had some hard water deposit issues, but until recently, things always got clean. Any ideas?
    Welcome Back:
    Visited the website for 2 consecutive days.
  • 26 Answers
First check the detergent is being released.
Then check the filter is clear and clean.
Next check each of the spray jet spinning arms are free to spin and clear of blockages (there are holes in these and food particles, particularly rice, may block the holes.
Finally set it to wash on its hottest setting.
You may wish to place a half a lemon in the unit to freshen it up too.
Posted on Apr 27, 2017
    New Friend:
  • 19 Answers
After you do the two previous responses, and if they fail to solve the problem, I would check the connections on the feed tubes. It almost sounds like the top arms are not getting enough water. There could be one that is not secure and is bleeding water out the back, or maybe a small crack or something like that. If any of them seem brittle or loose, replace them.
Posted on Apr 25, 2017
    Scholar:
  • 46 Answers
Before you do anything else I would suggest obtaining a couple bottles of "Dishwasher Magic" at your local hardware store or supermarket cleaning products aisle. This will clean the scale and crud from the interior so that it looks like new again, and since the water recycles through the pump and spray jets it also helps clean them too. Start with running the first bottle through on a heavy duty cycle. Then run the second bottle the same way. You should see that the interior looks remarkably cleaner afterwards, but if you don't then see much improvement in the way your dishwasher cleans, it is likely that either the pump is not functioning very well or the spray jets are clogged. If you can remove the spray jet rotors, and have a tray they will fit into, try soaking them in either a 50/50 solution of water and distilled white vinegar, or some CLR (calcium-lime-rust remover) following the product instructions.
  • 4 Answers
Check to make sure dishes don't block the detergent door. I have seen where lids can block it from opening. If you have the knob type, open the door and rotate the knob to see if the detergent door opens.
5 Suggested Answers
  • 114 Answers
SOURCE: dishes not clean
There may be a couple of solutions to your problem. First, if you are not rinsing the dishes thoroughly before loading, your sump area in the bottom of the machine will get clogged, thus preventing enough velocity to reach top rack. Second, and most likely, your water inlet valve (or solenoid valve) is restricting. You have a timed fill mode through the timer and if the valve is not opening fully, you do not get the proper rate of flow into the machine. Replace the valve and your problem will most likely be solved.
Posted on Dec 01, 2008
  • 30 Answers
SOURCE: Dishwasher Issues
I would try using a different soap or less of your current soap.
Posted on May 03, 2009
  • 677 Answers
SOURCE: White film on dishes, glasses and silverware.
white film is actually from the calcium and magnesium found in hard water. your dishwasher is fine. its the water leaving the residue and spots. go to www.dishwasherfilter.com . they have a new product out exactly for this reason. very affordable and works amazing. you will love it.
Posted on Nov 09, 2009
heatman101
  • 43501 Answers
SOURCE: Recent chaulky hardness deposits on dishes and interior of washer
Check your heating element..
Dishwasher2_bing.gif Problems The Heating Element not Working
http://www.fixya.com/support/r4589033-dishwasher_problems_heating_element_not
Dishwasher2_bing.gif Maintenance
http://www.fixya.com/support/r4319937-dishwasher_maintenance
heatman101
Posted on May 17, 2010
Kenmore dishwasher ultrawash debris on glasses
Fill the soap cup with vinagar and run it while its empty.
Mar 09, 2012 | Kenmore Dishwashers
Older dishwasher is leaving a white film on the glasses. Have checked the water (125 at the sink) cut down on detergent, used "dishwasher cleaner" a couple of times. Any Ideas? It is a Kenmore...
If your model has a JETDRY rinse agent dispenser be sure to use it..if it does not have that dispenser and just only the detergent dispenser use the JETDRY in the dry version that is in a little basket and hangs on the upper rack.
GENE
Aug 31, 2011 | Kenmore 24 in. 15689 Built-in Dishwasher
Kenmore elite model 665 17263402 The top rack is not cleaning the dishes. The bottom rack is cleaning fine. What is causing this and how can I fix it? Please help.
I have an older dishwasher also and recently my wife also complained about it not cleaning right... so me being the man I am tried in vain to clean the things... Bought new spray arms online and installed them in minutes...now the thing works like new... However I have also found that if the heating element goes bad then that also can mess things up bad... So I would buy new spray arms, and also check out the heating element to make sure it is working... Here is a tip that will help you with the online buying...
Dishwasher
Spray Arms not Spinning
How to Buy
Appliance Parts Online
A bad heating element causes many problems in dishwashers...
Dishwasher Problems The
Dishwasher Maintenance
Dishwasher Residue and Film on Dishes
heatman101
Jan 16, 2011 | Kenmore Elite Stainless Steel 24" BuiltIn...
My model # 665-16264402, Kenmore Elite. It's not cleaning the dishes on the top rack & barely on the bottom after even running it twice. It has an automatic filter so I know that's not it. Please...
Dishwasher
How to Buy
heatman101
Jan 01, 2011 | Kenmore 24 in. 16269 Built-in Dishwasher
My Kenmore 665 leaves food residue on glasses on the upper rack. What can I do to fix?
Hi, I have an older dishwasher also and recently my wife alsocomplained about it not cleaning right... so me being the man I am tried invain to clean the things... Bought new spray arms online and installed them inminutes...now the thing works like new... However I have also found that if theheating element goes bad then that also can mess things up bad... So I wouldbuy new spray arms, and also check out the heating element to make sure it isworking... Here is a tip that will help you with the online buying...
Dishwasher Spray Arms not Spinning
How to Buy Appliance Parts Online
Dishwasher Problems The Heating Element not Working
heatman101
Sep 25, 2010 | Kenmore Dishwashers
Our Kenmore 665 was leaving white flecks on dishes and glasses
The problem is hard water. There is a new product out called the dishwasher filtration system. It filters the water before it enters your dishwasher. It works amazing and has a money back guarantee. You will love the way your dishes look after the first load. It is also very affordable (like 70 bucks). Go to www.dishwasherfilter.com to find out more info.
May 10, 2010 | Kenmore 24 in. 17482 / 17484 / 17489...
Kenmore 665 15899 dishwasher won't clean
Make sure the filter inside the dishwasher is cleaned out and read about my advice for dishwashers for more tips.
<a href="http://tclaundryrepair.com/">St Paul Appliance Repair</a>
Jan 31, 2009 | Kenmore 15899 Built-in Dishwasher
Upper Rack not cleaning
id try removing hte lower filter plate . 5 torx 15 screws will gain oyou acess to lower sump and 2 more torx screws that will acess you the chopper assy, prhaps filled with debris not allowing good water flow,
Mar 25, 2008 | Dishwashers
Poor/Uneven Wash Quality
there is a new product out that filters the water going into your dishwasher. it works great and my dishes look fantastic. they use to look dirty with a white film on them. after the first load when i hooked up the dishwasher filter my dishes looked brand new. it is affordable and works everytime. you can get it at www.dishwasherfilter.com.
Oct 11, 2007 | Kenmore 15529 Built-in Dishwasher
Dishes not getting clean
brittgee, there has been a number of service flashes on this model. One that has to do with the upper spray arm assy. Complaint is poor washability; gritty glasses, food redeposited on glasses, especially in the corners. They redesigned the upper spray arm to improve water spray to all corners of the upper rack. The new part number is 8269022. They also redesigned the third level spinner for more consistant rotation and better washability. This was also under a service flash. Part number.8193768. Other reasons for poor wash would be; low water temperature, rinse aid disp. not working, loading etc. Catriver...post back.
Nov 25, 2006 | Kenmore 24 in. 15933 Built-in Dishwasher
Dishwashers Logo
558 people viewed this question
Top Dishwashers Experts
