Question about Tag Heuer Automatic Chronograph Series Carrera watch
What is the proper watch winder setting for a tag heuer link automatic
SOURCE: Tag Heuer Formula 1 Mens watch
This is not a cheap watch....You should send it to a qualified watchmaker or the manufacturer. This watch has to have a pressure test to insure it's water tight. This may require replacement of some or all of the gaskets in the case.I would never recommend that this is something that you should try to do yourself.You would be amazed at the money I make do to improper replacement of JUST the battery.
Donald McPherson, Certified Watchmaker AWCI
www.finewatchmaking.com
WWW.AWCI.Com
Posted on Oct 25, 2007
SOURCE: Setting date
hello! I am having the same problem. Do you already know how to set the date on that watch? please answer me to phiket@gmail.com
Posted on Apr 30, 2008
SOURCE: adjust links on tag heuer watches
They push out. A tool can be bought from Harbor freight
Posted on Jun 14, 2008
ThaMp3Doctor
  • 8596 Answers
SOURCE: looking for the user manual for Tag Heuer Aquaracer watch
They were just hiding it:
http://ww2.tagheuer.com/_documents/manuals/EI2252_en.pdf
-Tha Mp3 Doctor
Posted on Dec 31, 2008
escapement
  • 2334 Answers
SOURCE: Just want to ask about my new tag heuer watch???
Yes. it's normal to hear that soft noise when winding manually as all the gears gets engaged.
I would recommend watch rotator (winder) by Wolf Designs, Module 1.7, but you can choose for yourself.
Here is a link to Wolf Designs:
http://www.wolfdesigns.com/?a=getp&oid=215&cid=3&scid=11
Don'y forget to rate, please.
Posted on Jan 09, 2009
What kind of watch winder do I need for this watch
You have selected a wonderful watch... Heuer and TAG/Heuer should be gently wound by the motion of the human wrist and the falling of a centrally pivoting weight (there is no ideal direction).
AUTO-WIND function is NOT at all unique to your watch...
After a couple of CHEAPER "winders" failed me... and after I figured about 4 watches was more than enough to keep wound... I found the greatest BASIC watch winder... to run year over year (efficiently and quietly)
MTE watch winder (their very basic WTS-4).
Good luck: I WILL try to include the URL (see page 6)
http://mte-watchwinder.com/fileadmin/PDF-Uhrenbeweger/MTE_Watch_Winder_Brochure_Engl.__09-2015.pdf
Dec 06, 2015 | Tag Heuer Watches
Tip
TAG HEUER automatic watch with turning bezel (GMT) manual.
Follow this link and download original manual for TAG HEUER automatic watch with/without turning bezel and GMT function: http://www.tagheuer.com/the-collection/link/men/automatic-watch/index.lbl?w=WJ201A.BA0591
on Feb 09, 2010 | Watches
Heuer caliber 15 (1975) chronograph second hand resetting.
Try pulling out winder to time setting mode and press your chrono button until it advances to the 12 then push winder back in
Sep 13, 2013 | Tag Heuer Watches
My tag heuer carrera stop watch doesnt reset properly, when u reset the stopwatch it goes one minute behind and doesnt reset to zero. how do i fix this. it never resets to zero and the red hands on the sub...
Try this.
Pull the winder out fully. Then press the top right chronograph button to move the centre seconds hand on. Then push the winder back in.
on some models you should only pull the winder half way out.
good luck
Sep 23, 2010 | Tag Heuer Carrera Tachymetre CV2013.FC6206...
Stop watch not zeroing
Pull out winder 1 step and us the push buttons to adjust hands to 12 o.clock . when you have done this pull winder right out and use push buttons to set other hands then push winder back in.
Jul 06, 2010 | Tag Heuer Aquaracer Quartz Chronograph...
I need to know if I need to purchase a watch winder for my TAGs
Use a winder if you must but I recommend just winding and setting when you want to wear them as most winders I have seen are very cheap and unreliable. Expect up to 50 hours from most watches usually not less than 30, this is if the have recent< 5 years, overhaul.
Jun 11, 2009 | Tag Heuer Link Automatic Chronometer...
Tag Heuer Button Popping Out
If that buttun is pushbutton, then the fixing stopwasher has come off (inside watch).
If you meen the crown (winding and setting button), then setting lever or setting lever spring is damaged or broke.
Find your nearest watchmaker as both need professional repair and parts.
Dec 22, 2008 | Tag Heuer Link Automatic Chronometer...
Help setting the time
Tags have a screw down crown (winder knob) turn the knob counter clock-wise until you feel the crown unscrew (not off) then pull the crown carfully. It will pop once this is for date adjust. Then pull once more and you can now adjust the hands, set accordingly then push crown back in. After you push it back in gently compress the crown and tighten clockwise until it stops. CAUTION!!!!!!! Tags are not waterproof if the crown is not screwed back down. I hope this helps I am actually a car guy (just happen to own a couple)
Nov 06, 2008 | Tag Heuer WAF2110.BA0806 Aquaracer...
Nov 02, 2008 | Tag Heuer WAF2110.BA0806 Aquaracer...
Tag Heuer Automatic Chronograph Series Carrera watch Logo
349 people viewed this question
Top Tag Heuer Watches Experts
Jimmy Accardi
Are you a Tag Heuer Watch Expert? Answer questions, earn points and help others
