Question about Car Audio & Video
Looking for a wireing diragam for to wire my pro start car starter into my dodge caravan 2003
  • 6,674 Answers
Try this link, may help.
http://www.the12volt.com/installbay/forum_posts.asp~TID~6929
Posted on Feb 03, 2010
2001Dodge caravan 3.8L engine cranks but won't start, and dash lights and gauges go wacky
05 Dodge Caravan No Start P0688 bad wire - YouTube
? 10:49
www.youtube.com/watch?v=yshodC_crqo
Sep 22, 2012 - Uploaded by Brian Mann 2005 dodge caravan crank no start p0688 asd relay circuit ... butdoing the voltage drop on the back of the connector to the ipm to.... ECM PCM STARTER 2003 DODGE GRAND CARAVAN 3.3L V6 WONT START ... 1996, 97, 98 Dodge Caravan Starter install3.8L V6 - Duration: 8:39. by Gary O 4,364 views.
Sep 12, 2015 | Cars & Trucks
My 2000 Dodge Caravan will not start
Sounds similar to my old 94 dodge ram. Battery died at least I thought, replaced it and truck would not turn over. After about three hours of playing around I start checking all my wires and connections any loose wires I tighten or replaced if they looked worn or bad. And I found a ground wire was not connected to frame it came loose. Tightened it and hooked battery up and it started.
May 04, 2013 | 2000 Dodge Caravan
2003 dodge caravan 2.4 motor will not start has full power going to starter but not when you turn ignition there is no power at small wire at starter
before i can go any further i have seen bad starter kill power to small wire, does not sound correct i know but it happens, remove the small wire from the starter and test it for power with key in the crank position.
if there is power at small wire when removed from starter then starter is bad. let me know the out come. good day
Oct 06, 2012 | 2003 Dodge Caravan
2000 dodge caravan is blowing brake light fuse when pedal is depressed. there is no tow harness and remote starter brake wire has been cut to isolate it. brake switch has been replaced and both tail...
Check all the light "sockets" in the back,look for damaged wires, check the wire harness that goes to your tail end door for wire damage, you could try to reseat each bulb and when doing so look for corrosion in the light sockets. other than that,your center break light in back may have a control unit that may be bad and shorting out. you need to test things 1 by 1. good luck!
Sep 13, 2011 | 2003 Dodge Caravan
Need to replace the starter on a 1997 dodge grand caravan
to remove the starter from motor you need to disconnect the battery negative wire from the battery. then remove the battery wire and start wire from solenoid. remove the bolts holding the starter to the transmission bellhousing. then remove starter. installation is the reverse of removal.
Apr 28, 2010 | 1997 Dodge Caravan
How to jump a starter in a dodge caravan 1997
there are 2 wires on the starter simply connect them together to start the cranking,you will need to make a jumper wire for the smaller wire to connect to its terminal if it wont crank and the battery is good then the starter is no good
Sep 23, 2009 | 2000 Dodge Caravan
2003 Dodge Caravan wont start
if the oil light came on you may have a pinched wire by the starter there is also a sensor behind the starter that sometimes unplugs when the starter comes down
Sep 04, 2009 | 2003 Dodge Caravan
Wont start
resistor.............tell the mehanic
Jun 27, 2008 | 2003 Dodge Caravan
Car Audio & Video Logo
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
