Speaker problem I just bought Phillips 38 watt speaker system for my computer. When I hooked it up it my computer found it and started to load it but it gave me an error code 10 and I don't know what that is. I can't get any sound out of them. Thanks
    Problem Solver:
  • 7 Answers
Restore your computer,then try them again
Posted on Feb 19, 2008
I got 2 10in kicker comps and the rms on them each is 150 watts and can i hook them up to a 1000 watt sony xplod 2 channel amp and do i use both channel or just one or bridge them
1st thing is amps outputs have to be properly "loaded" this value is given in "ohms" if your amp says minimum speaker "loading" impedance is 4 ohms ( I suspect it does) then you may load that 1 channel down to only 4 ohms or amp will be damaged , most speakers are rated in ohm's Impedance (look for Greek symbol for omega) look for its rating somewhere on it doing the electrical formula math if you connect two 4 ohm speakers in parallel to one channel ( +=+ / -/- ) this divides down to 2 ohms (not good) but if you take same speakers and connect in series together (+to-/+to-) this gives you eight ohms (better) , the watts rating is a figure for you to determine the amount of power the speakers will take before failure , hence just because you connect 200 watt speakers to a 2000 watt amp is no indication that speaker will take all 2000 watts ( it will fail long before that point ) watts do ADD together like the above example two 4 ohm 250 watt speakers connected to one channel of amp in series will look like ONE 8 ohm 500 watt speaker to amp of course over 16 ohms load speaker volume will greatly diminish and amps have max impedance loads for them as well although there not often published
this is why I love the old TUBE!!! amps they load all the way down to 2 ohms and go up as far as 32 ohms load with no problems , they sound better as well across the board as well
Sep 10, 2015 | Sony Car Audio & Video
I hooked up 2channel 500 watt amplifer and 1200 watt 300 rms subwoofer now the protection light comes on when i turn up volume
your speakers rating is too low for your amplifier. 300 watts RMS means the speaker can operate on an average of 300 Watts continuously. the 1200 watt rating is peak wattage input and meant for intermittent intervals only, a like a bass drum beat count. also , your speaker impedance must match your amplifier impedance or the speaker must be a higher impedance than the amplifier. Never lower than the amplifier's impedance output rating. If The amplifier is rated into an 8 ohm load, your speaker must be 8 ohms or higher. in other words you cannot use a 4 ohm speaker or you will damage the amplifier .
Mar 14, 2010 | Car Audio & Video
Bought new Denon receiver. Hooked up main speakers to speaker A and 3 sets of small speakers (outside, living room and dining room (in wall) to speaker B. I use a splitter for the 3 speakers on B. The...
Speakers have what they call an ohm rating. Your 570 watt receiver is 570 watts at a certain ohm load. I would imagine there might be a level difference between the 3 different speakers on B too. Anyway, if the speaker pairs have all different ohm ratings, or they are not the optimum rating for your 570 watt receiver, you will not get the full wattage rating to the speakers. Hope this helps.
Jun 23, 2009 | Pioneer VSX-454 Receiver
Can i use panasonic SB-AK57 speaker (6 ohm) with yamaha system RX-V663 (8 ohm) ?
yes only that the current will be less on the load.
no problem you can use .
also consider the watts of the speaker and the amplifier dont forget. the speaker should have more watts rated than amplifier output watts
Apr 25, 2009 | Yamaha NS-A60X Main / Stereo Speaker
Operating with/without the control panel
You could try hooking them up to another speaker that has the input connections. I have done this before with several different speakers and daisy chained the connections with several speaker connections and they worked great. I had surround sound all over the room. You might run into a problem with the main speaker that you plug into not being able to push all of the speakers that you have but you might get lucky. Those speakers say that that carry 550 watts.
I recently bought a set of speakers that stated that they push 100 watts. The sub was putting out 50 watts and the others were only putting out 25 each. I hooked up a 100 watt speaker to it and it worked. You might be able to contact logitech to get the other speaker that you need. That set of speakers looks awesome on the site. This is the specs for the other speakers
I think that this is what you wanted to know. If it was not your solution, let me know. I will help you more. I might not be understanding your question correct. I have referred your question to someone on the site that works with logitech.
Jun 09, 2008 | Logitech Z-5500 5.1 Digital Speaker System...
Center speaker hookup to a MARANTZ mdl 2238
Hi tliguyanadig
You can hook up the speaker "between" left and right outputs. Just connect the center speaker between left +ve and right +ve outputs respectively. It will give a spacial effect that some like and some dont:) Try it and see for yourself. Your marantz amp will handle the load OK. It is rated 38 watts into 8 ohms, but there is not alot of load presented by this sort of setup. Let me know what you think.
regards
Graeme
Apr 03, 2008 | Audio Players & Recorders
Klipsch subwoofer
its all about impedance matching...did you check to see that the new yamahas would drive from the system, before installing them? sounds like you will need to possibly add a matching transformer or other device on this one.
Mar 09, 2008 | Gem Sound SUB-650M Speaker
Klipsch subwoofer
how are you connecting the sub to you amplifier?
Dec 11, 2007 | Gem Sound SUB-650M Speaker
54 people viewed this question
 Grubhead
Grubhead
