Question about Seagate (ST3120026A-RK) 120 GB Hard Drive
Computer does not find segate st3120026a. My computer was running fine although slowly so I thought a reboot would help. Upon booting up I got the error:corrupt or missing file: rootsystem32hal.dll but actually the system doesn't see the drive.
  • Steven Neff
    Steven Neff May 11, 2010
    What OS are you running?
  • 12,061 Answers
Hmmm well thats not good... usually that error is telling you that there is a file that has become corrupted.. or that part of the hard drive is, to me it sounds like the latter... seems to me as if your drive has gone south. Perhaps that was the reason for it being "Slow" .. You could try to recover it? but first I think it would be best to test the disk. They are pretty easy to replace ... You are going to need your Windows CD/DVD. Run the setup through and windows will test your drive for suitability, it is real "picky" so it will tell if it's OK or not.
Posted on Feb 02, 2010
Compaq presario wont start up
Several things could cause this. First try eliminating a few potentials sources of the problem --unplug external devices from the computer like external hard drives, usb sticks, printers, external speakers, etc. and see if you can boot the computer normally. If you can boot normally, try rebooting into safe mode and then running chkdsk. You may have to tap F10 repeatedly during rebooting to get to option such as safe mode. Allow chkdsk to complete its run; that takes considerable patience. IF you need to know how to run chkdisk, you can look that up in the F1 help screen while in safe mode. Uninstall whatever software you installed just before the crash. Reboot and allow normal booting. BUT BACKUP your critical information immediately if you get a good boot!
IF that does not fix the problem, you might have to look into using the recovery partition. That will likely allow a return to factory defaults, either with an erasure of your data or not, depending upon which option you decide upon. If all is erased, you may have to reinstall a considerable amount of software and reactivate windows via the internet. How do you get to the recovery partition? That is probably an option popping up when you hit F10. "R" for recovery.
Feb 11, 2015 | HP Compaq Presario SR1503wm PC Desktop
I have a gateway ML6720: gets into BIOS OK, but won't BOOT
Upon starting up your computer keep pressing the F8 key. You will see the repair screen come up. Choose the line where you can use the c:/ prompt so you can do the following
When the black DOS screen appears type in chkdsk /f /r
answer Y and reboot
The computer will run a check and repair on your DOS system
When done in a hour or less reboot and see if it will operate correctly.
It is best to have a system reboot disc handy if this happens again. I would create one on a CD if this fixes your problem
Jul 27, 2010 | Gateway Computers & Internet
WD My Book Essential Edition 500 GB Ext Hard Drive is making my computer run very slowly.
First, download AVG antivirus2_bing.gif at file:///C:/Users/Owner/Desktop/AVG%20Free%20-%20Antivirus%20Download%20Best%20Virus%20Protection.URL
then reboot yor machine while holding the F8 key as it boots back up. A menu will apear. Choose -->"start windows in safe mode with networking".
The os will start in safe mode. run an AVG2_bing.gif virus scan, then run Defrag by exploring your computer, right click on the drive letter, click PROPERTIES, then the TOOLS tab, click the "check now" button, and only checkmark the top box 'fix file system errors', then click ok, the computer will then tell you it will scan upon next reboot., Now click the DEFRAG NOW button. the choose defrag. After Defrag runs for about an hour and it is finished, restart the system. If it still won't run normally, go back into Safemode buy pressing F8 on reboot2_bing.gif, then run a registry fixing program such as uniblue registrybooster, then reboot again.
Good luck.
PLEASE RATE THIS ADVICE WITH SOME THUMBS UP!!!
Apr 24, 2010 | Western Digital My Book Essential Edition...
Thanks for the "comeback" buddy. I have tried quite a few things, such as swapping the drive for Primary to Secondary (I have an OS on another drive, and therefore I don't have to use the bad drive as a...
Well Frank I'll try my best , first off XP doesn't like dual OS installed in a comp running 2 OS , an internal slave is a storage HDD having an OS installed on that HDD will cause conflicts to the C; drive the drive that is running through the windows registry if the slave drive use to run through the OS registry then it remembers that it wasn't static and the image that was placed on it by the OS , in short try making sure its set to slave turn on the computer , if you are having problems turning on windows since the slave is corrupt try putting it in a drive enclosure and turn it on after the computer has booted all the way then turn on the external to retrieve your data , the whole problem started when you booted up you computer with 2 HDD running an OS
Feb 02, 2010 | Seagate (ST3120026A-RK) 120 GB Hard Drive
Hard disk upgrade
I faced the same problem i asked to the ibm people they said that non ibm hdd's are not supporting x3400 servers and they are hanging when we work with non ibm hdds. when I use segate 1 TB sata hard disk the server working fine the only problem is little bit slow for booting and programme running, this not a broblem. so pls use 1 TB sata hdds with your x3400 servers.
Jan 15, 2010 | IBM x3400 Server
On boot up laptop states it can't find the operating system
this sounds like you need to repair the boot sector. this usually happens when a hard disks boot sector becomes corrupt or damaged. to fix this you must use the windows install disk to install recovery console. put the disk in the CDROM drive, reboot, (you may need to press F2 upon bootup to enter setup and choose to boot from the CDROM instead of HDD) once computer is configured to boot to the CD drive reboot and choose "repair" when prompted by the cd. once the repair prompt is up you must run the 'fixmbr' command which will copy boot files back to your computer. hope this helps. please rate me and thanks for choosing enterprise computing solutions.
Oct 06, 2009 | E-Machines eMachines Desktop PC
SERVER RESTARTS AT BOOT UP AFTER INSTALLING PCIE GF8600GT DRIVERS
Load the computer in safe mode by pressing F8 before windows loads up. Once in safe mode, uninstall the drivers that you installed, reboot and download the latest ones from the manufacturers website.
May 04, 2009 | AOpen Computers & Internet
When i turn on the computer it doest work i dont get to go to the main screen its show windows loading files
This can be the product of a system files corruption, or possibly a virus that is causing your pc to reinstall itself (in a way at least) Although I haven't seen something like this in quite a while. When you boot up the PC try to get into safe mode by pressing F8 until you get the boot menu, if you can get into safe mode you should be ale to diagnose your problem or use something like system restore to attempt reverting the situation. You can also insert the original Windows CD and do a repair install, although you will need to reload your updates, this can have many benefits performance wise.
Jul 08, 2008 | Computers & Internet
Won't Boot
Take a look at the capacitors on your motherboard. If any of them seem to be bulging on the top then you probably do need to replace the motherboard or the capacitors themselves.
Could also be your power supply failing. Even with a surge protector things do wear out.
Jun 18, 2008 | Gateway GT4022 PC Desktop
Seagate (ST3120026A-RK) 120 GB Hard Drive Logo
Top Seagate Computers & Internet Experts
Arora Singh
Arora Singh
Alun Cox
pankaj rautela
pankaj rautela
Are you a Seagate Computer and Internet Expert? Answer questions, earn points and help others
