I am locked out of about 10 channels by the parental control menu optiopn and need to cancel tne parental control block
  • 4,889 Answers
Please let me know the make and model of the tv and I will look up if there is a reset option available.
Sai.
Posted on Feb 02, 2010
Rca tv stuck on
Locked?
From the main menu choose "Parental Controls;" it's option six.
Choose the first option, V-Chip TV Rating Limit, and using the arrow keys and the OK button on the remote, scroll through until the TV-MA rating appears. Press the right arrow button to move the highlight over to the "Status" field and toggle to "View." Press the OK button. This will set the age-based ratings to Mature.
From the Parental Controls menu, select the second option, V-Chip Movie Ratings Limit and change the rating to TV_MA and the "Status" to "View."
From the Parental Controls menu select the third option, V-Chip Unrated Program Block and select item one, which will be "View."
Select the fourth option, which is "Channel Block." Highlight the Channel field and using the channel up and down buttons, go through and check they are all set to 'View." Any set to "Block" will need to be toggled back to View.
Lock the controls to activate the changes using item six on the "Parental Controls" menu.
Gopakumar Gopalan Google
Feb 25, 2014 | Televison & Video
RCA 2004 24V511T no remote CPA is locked!!! What can I do to unlock??
google.com/+GopakumarGopalan
Dec 20, 2013 | Televison & Video
TV power button on my RCA True Flat 27" screen TV
RCA TVs come with a child lock capability called V-Chip. It's a parental control system which allows you to block programs and films by content, age-based ratings and the ratings which come with the movies. The parental control is a code, sent by the broadcaster to your television. The V-Chip will not work if the broadcaster doesn't send the control, or if the parental controls are switched off or unlocked. The controls are set up in the TV's main menu. The default is off.
Jun 17, 2013 | Televison & Video
No chanels
The TV is locked electronically. To unlock it, you must have its remote control. If you have its remote control,
Lock the controls to activate the changes using item six on the "Parental Controls" menu. If you wish more details abut RCA TV unlock proceedings, check this site.
Jan 23, 2013 | RCA F27665 27" TV
How to unlock childs security?
Instructions
Jun 28, 2012 | Sansui DTV3200 32" TV
How to reset the parental control code - I forgot the code and want to reset with a new one
This is what I found in the instruction manual on this and I posted it here for you. Try using 3355 for the code and everything else listed here. If that doesn't work, try the very last tip which tells you how to do a factory reset and repeat the first step using the 3355 as the code.
Here's the instructions from manual:
Parental Control
Parental Control allows you to block certain channels or programs so children cannot view
programs that are not age appropriate.
To enter the Parental Control menu, you need an
access code. The first time you enter, use access
code 3355. See "Setting an Access Code" on
page 33 for information on creating a new access
code.
You can set the following options to block
content:
• Channel Lock — Blocks selected channels
• Movie Rating — Blocks movies based on their rating (G, PG, PG-13, R, NC-17, and X)
• TV Ratings — Blocks TV shows based on their rating
• Block Options — Turns on or off all your parental control settings
NOTE: You can use Clear All to unblock the channels and programs that you have set.
NOTE: If the Block Control in the Parental Control menu is enabled, all the sub screens in POP (POP1,
POP3 and POP12) mode will be blank
Setting an Access Code m
After you enter the Parental Control menu for the first time, you can set your own four-digit access
code. If for any reason you lose or forget your access code, you can use the default code.
1 In the Parental Control menu, select Change Code.
2 Using the number pad on the remote control, enter a new access code.
3 Select Exit.
Reset the original factory defaults. Press Menu on the remote
control, select Setup, and then select Factory Reset
Jul 28, 2010 | Dell W4201C 42 in. Plasma HDTV
Magnavox child lock help
hello The parental control menu enables
you to limit access to programs that
may contain objectionable material
or are not suitable for viewing by
children. The default access code is
0711
0711.
The following table provides details
about the menu items:
Component Function Range / Options
Lock Enable
Enables the parental control lock. When
enabled, channels with objectionable viewing
content are blocked and can only be
accessed with a password. You can block
channels according to the movie or TV ratings
of the channel’s programs.
Off, On
Movie Rating Helps you block programs based on their
movie ratings. See “Movie Rating” on
page 25 for more details.
TV Rating Helps you block programs based on their TV
ratings. See “TV Rating” on page 26.
Change Code Changes the password for the parental control
lock.
Press the number keys to
change the password.
Reset Resets all channels and programs to their
default factory settings.
regards
shaun
Parental Control Menu
Lock Enable
Change Code
Reset
Back
Main Menu
Sound
Size
PIP/PBP
Parental Control
Channel Setup
Setup
Exit
Press Right to Enter
Press New Code
Off On
TV Rating
Movie
Mar 13, 2010 | Philips Magnavox 50ML8105D 50" HDTV DLP TV
Child lock
  • Step 2 Choose the first option, V-Chip TV Rating Limit, and using the arrow keys and the OK button on the remote, scroll through until the TV-MA rating appears. Press the right arrow button to move the highlight over to the "Status" field and toggle to "View." Press the OK button. This will set the age-based ratings to Mature.
  • Step 3 From the Parental Controls menu, select the second option, V-Chip Movie Ratings Limit and change the rating to TV_MA and the "Status" to "View."
  • Step 4 From the Parental Controls menu select the third option, V-Chip Unrated Program Block and select item one, which will be "View."
  • Step 5 Select the fourth option, which is "Channel Block." Highlight the Channel field and using the channel up and down buttons, go through and check they are all set to 'View." Any set to "Block" will need to be toggled back to View.
  • Step 6 Lock the controls to activate the changes using item six on the "Parental Controls" menu.
  • Nov 30, 2009 | RCA Mikomi 5290925 15 in. LCD TV
    Fpa lock on how do i get this offf
    hello Lock/Unlock Parental Controls
    Selecting this option lets you lock and unlock parental controls settings
    using a password.
    If you do not lock parental controls, none of the settings for V-Chip,
    Channel Block, or Front Panel Block will take effect.
    If you forget your password, press the MENU button, then select Parental
    Control
    (the password entry screen appears). Simultaneously press and
    hold CH+ and VOL+ on the front panel for 8 seconds. Parental Controls
    unlock and the Parental Control menu appears. You can enter a new
    password by locking the Parental Controls again.
    Front Panel Block
    Selecting this option lets you block (disable) or unblock (enable) the TV’s
    front panel. The remote still tunes to any channel. When using this as a
    Parental Control method, remove access to any remote that is capable of
    operating the television while you have the front panel blocked.
    Don’t forget to lock parental controls after you change the status. If you
    don’t, the front panel block will not take effect .if this don't work get back to me i've got manual good luck
    shaun
    Sep 19, 2009 | RCA R52WH73 Projection Television
    Televison & Video Logo
    18 people viewed this question
    Top Televison & Video Experts
