Question about Lexmark P4350 All-In-One InkJet Printer
Error 1102 when i replace coulr cart
Error 1102 when i replace coulor cart ,ihave tried 3 new carts
  • Official Brand Answer
  • 3,344 Answers
Here is a link that tells you what to do to solve this problem. http://bit.ly/dzldNy
Posted on Feb 09, 2010
Displaying error E and 5 (In Blinking) and error code 2,114 while scanning........help me out of this...........thanx
The e2 error os no paper, e5 is improperly or damaged ink carts, as is the e14 error code. Make sure that there is plently of fresh paper, and replace the carts with new canon carts. If you are using refilled carts in this machine, the failure rate of this series of carts is nearly 60%. Last step to try would be to unplug the printer from power and let sit for at least 10 minutes, plug back in and power up.
Sep 29, 2010 | Canon PIXMA MP150 All-In-One InkJet...
Dell Photo 926 printer keeps saying that it cant align and wont print after installing new cartridges. Says tape is still on there but it isnt.
1. cancel the alignment .
2. try one cart at a time and only make a copy of a test document ...(press "select" if u get cart missing error ) ...only of the carts is causing the error
3. possible u have defect cart ..or the internal sensor could have gone bad (rare scenario )
4. get a replacement carts...
Oct 25, 2009 | Dell 962 Photo All-In-One InkJet Printer
Epson C60 - The green power light and middle red error light
-reseat the new cart
-clean the contacts (cart and carriage)
-try a new cart
Sep 04, 2009 | Epson Stylus C60 InkJet Printer
Installed a 75 cart and got 1203 error. Installed a new 70 cart and now i can't align cart or print black.
Ok this some times works.
Error 1203 is an issue that occurs either when a cartridge is bad or the printer cartridge Slot is bad...
1 - try cleaning the copper contacts of the both carts and cart slot in the printer and try again..
or
2 - when error shows up, shut the printers power off; wait one minute and turn it back on press copy.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Aug 12, 2009 | Lexmark X4270 All-In-One InkJet Printer
Error message reads: left cartridge incorrect.
hello there :
this error refers to the black ink cart not being detected .
possible the new cart has a some fault on it ., u can confirm it by checkin for any defetc , leak on the cart itself or test the printer with another black cart , (if u hav one ).
*if the old black cart is still detected by the printer though the ink is low ...then jus call dell tech support ., with the order # for ur purchase and the cart replaced .
each dell cart u buy has 2 yrs warranty on them .so use them
hav a gooday !
Jul 19, 2009 | Dell 924 All-in-One InkJet Printer
Error code 14 "no tuner cart"
14 NO EP CART Message
The printer detects the presence of the Toner Cartridge and the
level of toner present in the cartridge through the condition of the
ANTIN signal. The ANTIN signal becomes part of the serial data
stream used to communicate with the DC Controller (see Figure
7-5 for cartridge components). Troubleshoot the 14 NO EP CART
(or INSTALL TONER CARTRIDGE) message as follows:
1 reseat the Toner Cartridge. Try a new or known good Toner
Cartridge.
2 Check the High Voltage Contacts for damage. If the contacts
are dirty or damaged, clean the contacts after the repair.
3 Replace the High Voltage Power Supply.
4 Check and reseat the HVPS cable.
5 Replace the DC Controller
May 06, 2009 | HP LaserJet 4 plus Printer
Error 1203
Are you using a refilled cartridge1.gif or refilling your cartridge yourself?
Error 1203 is an issue that occurs either when a cartridge is bad or the printer1.gif cartridge Slot is bad... Try to cleaning the copper contacts of the both carts and cart slot in the printer and try again..
If that doesn't work, then you might try a new black cartridge and possibly a color cartridge too.
Hope this helps.
Good luck.
Mac
Please remember to post a feedback and or rating if my suggestion has helped you fix your problem.
Note: Refilling carts may damage the contacts of the carts as well as the printer (From a printer companies website)
(repeating this message again, for some reason this site logged me off and It didn't give me credit for the post)
Mac =)
Feb 13, 2008 | Lexmark X4270 All-In-One InkJet Printer
Printer problem
Try to unplug the printer from power. Wait a minute. Take all carts out. Close ink cover. Replug printer to power. Machine demands carts. Insert carts as demanded.
If you still have this error this could be due to generic ink carts. Ink may have stained the led control and the ink assy has to be replaced!
Nov 10, 2007 | Brother DCP 130C All-In-One InkJet Printer
Inputting new ink cartridges
Error 1102 means cart error. Try cleaning the copper contacts on the cart and the contacts in the printer also. If still fails, then put old carts and check if u still get same error. If u dont get the error then there is a problem with the cart itself. But if you have bought a refilled cart then the print heads on the carts are bad. Needs replacement.
Sep 19, 2007 | Lexmark P4350 All-In-One InkJet Printer
Lexmark P4350 All-In-One InkJet Printer Logo
241 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
