Information regarding controller of sanyo vrv
Can you give the information about controller. there are 3 boards,what is the purpose of each board. how much electrical supply we have to give to these 3 boards.what is the relationship between this 3 boards.suppose any one board burnt out due to sudden power fluctuation,then we have to replace all 3 boards or only one that is burnt.
  • neel7saiba Feb 21, 2008
    dear ,
    i am asking about VARIABLE REFRIDGERANT VELOCITY sanyo airconditioning machine . there is no relation with infrared detector.
It,s ok.
Posted on Feb 21, 2008
  • 21 Answers
Some have separate board for the infared detectior. the wire diagram is what i use to get a hint of the different functions.
  • frank mohr Feb 21, 2008
    sorry, don't know
Sanyo dp52440
The power supply may have failed.
Mar 05, 2018 | Televison & Video
U3 problem for vrv daikin
U3 Is a failure to carry out check operation, transmission error
This is a self diagnosis the unit does before starting to ensure both PC boards are communicating with each other. Check wiring is correct on the units, usually means one PC board has failed
Oct 28, 2013 | Daikin BRC2A71 - Simplified Individual...
Code u 4 - Daikin model Rxymq48mvju
U4 Is a communication error between indoor and outdoor units.
usually means one of the PC boards is faulty. If unit has been freshly installed check wiring between indoor and outdoor 1,2,3 are the same colours on both boards.
May 04, 2013 | Daikin RXYMQ48MVJU, VRV-S Air Cooled Eight...
Sanyo DP46840 won't stay on. Turns off after 2-3 seconds
Look up the chassis version of your Sanyo (it's on the label on the back where the model is) and check in the list below to see if there is a repair service offerred for it:
http://www.coppelltvrepair.com/search?Q=DP46840+&As=false&Pf=&Pt=&Sid=false&btnsearch=Search
Hope this helps!
P.S. There's no quick and easy solution that I can offer based on the information you give and what I know about those boards. This is why I am at least sending you somewhere where you can read what is being treated and under what conditions.
Mar 31, 2013 | Sanyo 42 in. LCD TV
Power Issues with Sanyo DP50749
Main board is most likely but that is an educated guess--problem with all these is you can only check so many things and then have to guess and try a board.
Apr 22, 2012 | Sanyo DP50749 50 in. Plasma TV
Sanyo dp37819 i turn it on green light comes on but no picture or sound and green light goes on and off
You can send your main board to us and we can give it a try.
If it the front LED turns on for a while, then off for 1-2 seconds and then back on...we'll probably be able to help.
See http://www.coppelltvrepair.com for details and shipping instructions.
Jan 14, 2012 | Sanyo DP37647 37 in. LCD TV
The unit either encountered a brown out or a surge which burned up the board for the condenser. It had black marks on the board and the indoor unit was flashing. Replaced the board and the unit is still...
After replacing the burned condenser board, check also the entire condensing unit if still ok ( compressor and fan motor). If the light inside the indoor unit is still flashing, the timer is still not giving signal for the compressor to start. Adjust temperature and wait for 3-5 minutes. It light continue flashing, there is something wrong with the indoor unit control.
Sep 02, 2011 | Sanyo Split System Air Conditioner
TV will come on for about 3 seconds and picture goes out on it but you can still hear it. please help me i love my tv.
Turn set on and press a bright flashlight against the screen. Look around the edge of the flashlight for moving images. The image should still be there. The back light is off so you can not see it.
The problem is most likely in the back light inverter board. Possibly one transformer on the board is causing the unit to switch off after the fault is detected.
You should replace the back light inverter board.
Since you did not give the model of the set I can not give more information.
Mar 04, 2011 | Sanyo 42 in. LCD TV
Heating & Cooling Logo
241 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Tim Whalen
Marvin
Marvin
