Question about Dryers
No heat drum turns no heat blower works no heat
  • Dryers Master
  • 8,220 Answers
It could be the heating element, a safety limit, a control problem, or an electrical problem. A heating coil is used to warm the clothes as they get tossed gently inside the drum. A blower mounted on the motor pulls air through the heating element into the drum and out the exhaust. The element gets old and briitle with use and eventually needs replacement. That is what you check first. On gas dryers vibration and age will cause the igniter to crumble and fail. If it turns out the element is fine then one of the safety's might be blown. These safety's are set to a certain temperature
for the dryer to operate safely. The drum temp control for cotton is 160f. A limit on the heater housing is 250f. If it fails another smaller limit is mounted nearby that blows at 300f. If that temp exceeds 350f a duct fuse mounted on the blower housing opens and kills most dryers. On gas dryers the duct fuse will kill the gas assembly but the dryer will still run. If all of those safetys are good the timer could be the problem. The timer has a terminal on it that runs down to the heating element. If you suspect it is bad you can check it with a meter. That leg of the timer should have continuity with other terminals on the timer at different spots on the timer. Turning the timer and checking for continuity will give a clue. If you cannot get continuity with any other terminal on the timer at any position on the dial then you have a burned contact in the timer. If that turns out to be good, you would need to inspect the electrical outlet for proper power to the machine. On American models the motor runs on 120 volts but the heating element must have 240 volts. If you have more questions just post a comment. Good luck on repairing your machine. I have some repair photos: HERE
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Posted on Feb 01, 2010
Heat is blowing out but the drum is not spining
You broughtke the belt of drum wont turn you might take the dryer apart to make sure the idler pulley is spinning free also. They sometimes get tight and burn the belt up.
Apr 10, 2015 | Avanti D110 Electric Portable Dryer
The drum on our Neptune Dryer has stopped turning. It still heats up, but the drum just won't turn.
If the heater and blower work then th eprblem is with the drum turning system
This includes the motor ( which we will presume works because the blower does),the belt (Item #25 in the Cylinder, heater and bulhead diagram) and a spring and idler pully (Items 20 and 21 in the Base, Motor, and blower diagram)
Most likely problem is the spring broke releasing tension that halds the belt to the motor pully and drum. Second most likely is the belt has stretched.
You need to open the unit to determine where the problem lies.
Here are diagrams and parts listing for that machine.
http://www.searspartsdirect.com/partsdirect/part-model/Maytag-Parts/Dryer-Parts/Model-MCE8000AYQ/3048/0151200?searchedModel=MCE8000AY&blt=
May 24, 2011 | Maytag Neptune MCE8000AY Electric Dryer
Whirlpool Electric dryer type-DWJR-ELE-2406028-FM54. model LER7646JQO the heating element get very hot. the dryer does not turn on. the drum does not turn either.
If the heating element is getting very hot that means there is no air flow across it. If the drum doesn't turn then the blower is not turning causing the element to get very hot. Could be drum belt, drum rollers, or motor.
Mar 17, 2010 | Whirlpool Dryers
Whirlpool Electric Dryer, model LER7648KQ1. The
Check your previous post. I left additional info for you.
Sep 11, 2009 | Dryers
GE Harmony Elec. Dryer Blower Stops working or won't start up
Do this.
press "Home"
press "Help"
press both "My Cycles" and "Back" at the same time and hold them until service mode pops up.
It will tell you what's wrong.
Jul 22, 2009 | GE Profile Harmony DPGT750EC Electric...
Drier turns on, tumbles, no heat
your heating element is out,. very easy to replace
Jul 18, 2009 | Dryers
KENMORE DRYER
Hello ENRIGHT11 Welcome to Fixya
My name is Huum,
You said,
DRYER MAKES VERY LOUD NOISE WHEN RUNNING. ALTHOUGH IT HEATS UP AND BEGINS TO DRY, IT STOPS RUNNING COMPLETELY AFTER ABOUT 5 MINUTES. IF YOU WAIT AN HOUR, YOU CAN START IT AGAIN, BUT IT AGAIN SOUNDS VERY LOUD (ALMOST A RATTLING SOUND) AND THEN SHUTS OFF AFTER 5 MINUTES
Faulty Blower Wheel
If you hear a great deal of noise coming from the blower area of the dryer when it is running, then the blower wheel could be defective.
The are many different designs for blower wheels and just as many unique failure modes. Vanes (fins) can break off the wheel and bounce around in the blower breaking more pieces. The blower can break around the coupler with the shaft. This can cause the blower to spin loosely on the shaft. The blower can form cracks which cause it to vibrate, etc.
You should also not be surprised to find foreign debris in the blower. The occasional bird, rodent or squirrel has been known to bypass the out vent cover. If they crawl into the exhaust tube the first thing they come into contact with is the blower wheel.
If the blower wheel is not spinning, or if it is missing vanes, it is not moving air efficiently. As a result, heat is not removed from the heat source and it can trip the high limit switch or blow the thermal cut-off.
Worn Belt
A worn belt can stretch and/or become brittle with age. The belt can then slip on the drum or motor to cause squeaking. If this is the case, the solution is to replace the worn belt.
The belt is not the only item that can cause squeaking. It can also be caused by a faulty idler pulley, worn drum bearings, worn drum glides or worn drum rollers depending on brand and style.
When replacing the Belt is is a good idea to also change the Drum Support Rollers, Drum Glides, Idler Pulley and Clips. All of these items are economical easily changeable when replacing the belt. The upside is that your dryer will operate like new.
Recent Customer Symptoms:
Dryer makes loud noise when turned on. Dryer works and heats up OK but makes too much noise.
Worn Drum Glides
Some dryer models are equipped with Drum Glides. The front of the dryer rests on these glides. They provide a low friction surface on which the drum spins. After time however, this glides wear down. Much like an automobile brakes, these glides make a load grinding noise when they wear thin. This griding against the drum usually leaves a bare metal stripe that is visible at the point of contact. If the glides are worn, the solution is to replace them.
The drum glides not the only items that can cause squeaking. It can also be caused by a faulty idler pulley, worn drum bearings, a worn belt or worn drum rollers depending on brand and style.
When replacing the Drum Glides it is a good idea to also change the Drum Support Rollers, Drum Belt, Idler Pulley and Clips. All of these items are economical and easily changeable when replacing the glides. The upside is that your dryer will operate like new.
Worn Rear Drum Bearing
Some dryer models are equiped with a Rear Drum Bearing. The rear of the drum rests on this bearing. It provides a low friction surface on which the drum spins. After time however, this bearing will wear down. If the bearing is worn, the solution is to replace it.
The rear drum bearing not the only item that can cause squeaking. It can also be caused by a faulty idler pulley, worn drum glides, a worn belt or worn drum rollers depending on brand and style.
When replacing the rear drum bearing it is a good idea to also change the drum glides, drum support rollers, drum belt, idler pulley and clips depending on make and model. All of these items are economical and easily changeable when replacing the rear drum bearing. The upside is that your dryer will operate like new.
Worn Drum Support Rollers
Some dryers such as Whirlpool/Kenmore brands are equipped with Rear Drum Support Rollers. The weight of the dryer drum rests on these rollers. They provide a low friction surface on which the drum spins when in operation. After time however, these rollers wear down. When they wear, often times they begin to elongate and form a non-round 'cam' shape. The result is that when the dryer is turned on it creates a rumble that sounds as though you are trying to dry a pair of tennis shoes. This sound is usually the drum being forced up and down on the non-round wheels. If the rollers are worn, the solution is to replace them.
When replacing the Drum Rollers it is a good idea to also change the Front Drum Glides, Drum Belt, Idler Pulley and Clips. All of these items are economical and easily changeable when replacing the glides. The upside is that your dryer will operate like new. Whirlpool
Kenmore models have a dryer maintenance kit that contains all of these items in a single kit.
Thank You For trusting us with your question
Please remember to leave a
solved rating before you leave!
Jan 21, 2009 | Kenmore 63942 Dryer
Blower motor does not work, no heat.
If you check for voltage at the blower motor and have zero volts ,change the Control board. If volts are present then change the blower motor. Please Rate This !
Aug 14, 2008 | GE Profile Harmony DPGT750EC Electric...
Drum in dryer not turning but still heat
had the same problem.Found sox stuck in the blower.Try to check that it worked for me.
Apr 02, 2008 | Dryers
Aquarius 1200 wd62 - Dryer not working
Most likely it is some sort of blockage in the vent, although it could be a bad blower. Check the lint filter and vent openings for a blockage.
Jul 27, 2007 | Hotpoint Aquarius WD63 Front Load...
Dryers Logo
120 people viewed this question
Top Dryers Experts
