Question about Frigidaire Gallery Series GLHS269ZDB 36" 26.0 Cu. Ft. Side-by-Side Refrigerator w/ 7 Button Dispense...
My frigidaire ice maker is not making ice after loosing its prime. (pipes broke outside) got water to the valve at the bottom but nothing coming out.
  • 619 Answers
Sound as tho some debris has gotten into the valve clogging it. It is safer to replace valve than to try and clean it. Hope this helps
Posted on Feb 02, 2010
I have a frigidaire refrigerator with a top freezer , I put a ice maker in and the water is going to the bottom of the frig but not going up the line to the ice maker , but you can't hear the ice make
if the water is turned on you probably have a bad valve take the line off of the valve
at the back of the refrigerator see if you have water if you do its the valve
Oct 10, 2014 | Frigidaire Refrigerators
Installing frigidaire ice maker
Hello friend, thanks for your post!
Depending on which style Frigidaire refrigerator you have it is different priming each water line. For a top mount refrigerator you would need to install the icemaker and turn it on with the wire arm. The first cubes of ice for 24 hours should be discarded. On a side by side refrigerator and a french door bottom mount you would need to push on the water dispenser for two to four minutes releasing the water into a glass. I hope this information is helpful.
Aug 30, 2014 | Frigidaire Refrigerators
No ice in ice maker, no water in door.
check back to source for crimped or blocked pipes. If you can not see anything try removing the pipe and pass air through it, if you find resistance (when valves are open) you may have a frozen/crimped pipe.
Dec 27, 2013 | Frigidaire Refrigerators
Water not going into ice maker on a Frigidaire Fr526HFA
Check water fill valve at the back bottom-outside of the fridge.
Do you know how to do that? ..If not, get help.
Is the tube that supplies water to the ice tray frozen?
Oct 24, 2013 | Frigidaire Refrigerators
Ice maker is not getting water to make ice
Frequently,the small valve that is tapped into the water supply that feeds the ice maker(usually a water pipe near the unit) becomes clogged.Turn the valve all the way in then out a couple of times.This generally frees the calcium buildup. The water should flow.
Feb 05, 2012 | Frigidaire Refrigerators
Ice maker water line comes loose when water turns on
Sounds like your terminal connections on the water valve have gotten reversed. Try switching them..Also you may need new water valve..
Aug 03, 2017 | Refrigerators
My refrigerator (frigidaire plhs269zdb9) wont make ice.
maybe bad ice maker or water valve. start whit the cheapest. water valve.
Apr 02, 2010 | Refrigerators
Ice maker not working - Frigidiare refridgerator Model number FRS26BH6CB4
take the line off of the solinoid valve and check to see if there's a screen in the valve. that could be plugged with debris.
Dec 20, 2008 | Frigidaire FRS26R4A Side by Side...
Ice maker
The refrigerator has a duel water valve, one for the ice-maker and one for the water dispenser (if equipped). The valve that the ice-maker relies on may be bad, or it could be the ice-maker itself.
Another thing that could cause it would be the temperatures in the freezer. The ice-maker will not call for water until it reaches under 15 degrees. In addition, check the water tube behind the ice-maker to make sure it is not frozen, blocking more water from entering. The water does not go to the ice-maker or thru the filter unless the ice-maker turns on the water valve.
Jul 04, 2008 | Frigidaire PLRS267ZAB Side by Side...
Cant seem to get the Icemaker working
Mungah, There is no valve that needs to be turned on. The water travels through the valve into the filter and up to the ice-maker. Try pressing the water lever and stay on it until the water fills the filter and comes out. You should hear the valve energizing. The ice maker cycles every 2.5 hrs. approx. When it calls for water it may take several cycles to prime the line and fill the ice maker...As far as the leak, something is wrong with that compression connection, re-do it and see if it stops...Catriver..post back.
Oct 21, 2006 | Kenmore 44103 Side by Side Refrigerator
Frigidaire Gallery Series GLHS269ZDB 36" 26.0 Cu. Ft. Side-by-Side Refrigerator w/ 7 Button Dispense... Logo
195 people viewed this question
Top Frigidaire Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
