Question about Panasonic KX TC1703 Cordless Phone
My phone is dead. the lights are on but no dial tone
5 Suggested Answers
cnavarro
  • 2460 Answers
SOURCE: NO DIAL TONE
Since an Analog Pana phone uses two pairs, swap phones completely with someone else. If the phone you had works somewhere else and the phone you borrowed does not, it's a wiring issue.
The phones light up because the data to make the display and lights travel on the second (black/yellor or orange) pairs of the jack (pins 2&5). The voice is on the first (pins 3&4) pair.
If the phone is bad, it's bad, but I'm guessing your missing a wire on the red or green lead of the phone jack, either from a bad base cord, or a bad jack.
Carl
Posted on Nov 08, 2008
  • 47 Answers
SOURCE: MY KX-T7625 went dead after
use another power and phone outlet in your home.. the jacks that you are using.. sounds like the problem..
Posted on Jan 10, 2009
  • 9 Answers
SOURCE: Unhooked phone jack from back of KX-T7625 Corded Model and when I
Should just fire back up again, are you sure you put lead in correct socket? sorry if it seems a silly thing to say , but it is a common problem. Try resetting the system if the connections are correct.
Posted on Jan 11, 2009
SOURCE: 4 phones on a boat,model # KX-T7030 No Dial Tone
pdf.textfiles.com/manuals/.../Panasonic%20KX-T7030%20Reference%20Manual.pdf -
Above is a user manual, below is your reference manual.
http://www.scribd.com/mobile/documents/8790207
below is the circuit diagrams.
http://www.eserviceinfo.com/downloadsm/4832/Panasonic_KX-T7030.html
These phones all operate across pairs of wires. Usually the phones plug into a main box called a EMSS, (Electronic Modular Switching System) It has to be set up first, sort of "Programmed" before it will all work together. You need to also obtain the information on the EMSS unit, as this is the "Brains" of it all. The EMSS unit has a power connection, the phones generally do not. There must be wiring from the EMSS module out to each phone.
Once you sort that out, the phones should all simply work, when connected.
Posted on Nov 13, 2010
I have a panasonic cordless phone modle # KX-TGDA20. The phone has no dial tone. It is on mute and I can't get it off. I have unpluged the phone but no change.
See itf you can find someone who can try a different phone on that phone cord.
It may be a bad battery, or the phone line may be dead.
That is why I suggested you try another phone to see if a dial tone will come through that one.
If you get that dial tone on another phone, then suspicion a bad battery or battery charger.
God bless your efforts.
Apr 11, 2017 | Panasonic Lands Phones
Hi my canon fax-JX500 displays 'line in use' and has no dial tone. Can you please tell me how to fix the problem?
Unplug your fax from the phone line. Plug in a phone. Dial tone? Yes? then either fax is bad or the phone wire is bad.
No dial tone? Phone line dead.
Aug 30, 2015 | Canon Office Equipment & Supplies
My phone says check Tel Line
Sounds like your telephone line might be dead. If you have a gray or tan telephone box on the outside of your house you can plug your phone in there to test the line. If you get dialtone then thrers a problem in your house wiring, if you don't get dial tone then the line is dead and you need to conact your telco provider.
Apr 14, 2010 | Uniden DECT 6.0 Cordless Telephone...
No dial tone now
When there is no dial tone the problem could be dead batteries in your handsets, or an unplugged base, or a problem with the phone lines outdoors [which only the phone company can fix]. Check your phone first, then make sure the base is plugged in. If all is ok with your phone then call the phone company and tell them you have no dial tone. Regards, Joe
PS please rate my answer. Thank you.
Dec 20, 2009 | Uniden Cordless Phone
No dial tone
If the "handset" beeped then it is already registered. It means that it is recognized by the base and therefore should be working. If you still have no dial tone on the phone there must be an issue with the working condition of the phone. Sorry that my advice didn't solve your problem.
Apr 17, 2009 | GE 25942GE2 Cordless Phone System
Semi Dead Panasonic KX-TGA100N with ''C533'' displayed.
Panasonic KX-TG1050N Cordless Phone. Base handset (No. 1, KX-TGA100N) does not work, no keypad response or dial tone. Green indicator message light ON (should only work with the TG1000N base unit) all the time till battery runs down. Display shows message ?C533?. Can still send and receive calls on extension phones 2 and 3.
Nov 11, 2008 | Panasonic KX TG1000N Cordless Phone
Dead phone
Fix Ya,
The problem is not fixed, my husband bought me e new phone. I would not bother to have it fixed, it's so dead..............
Sep 30, 2008 | GE 27928GE6 Cordless Phone
Bell phone
is your computer hooked up dsl or dial up? unplug all the phones and computer from the phone jacks.plug a corded phone into the jack and check for dial. if you don't have dial tone, call your phone company. if you do have dial tone, plug everything in one at a time and see if the phone line goes dead.if it does, the last thing you plugged in is the problem.
wg
Feb 10, 2008 | Lands Phones
CORDLESS PHONE - NO DIAL TONE
Plug out the power from the main charger and then plug in again. It needs to reset after they have gone dead. Immediately you can lift one of them off the charger and you will hear your dial tone.
Apr 18, 2007 | Uniden DXAI5588-2 Cordless Phone
Panasonic KX TC1703 Cordless Phone Logo
21 people viewed this question
Top Panasonic Lands Phones Experts
guyvstewart
george  peters
george peters
Are you a Panasonic Lands Phone Expert? Answer questions, earn points and help others
