Question about Maytag MAV8557 Top Load Washer
Squeals when spining stops, and takes a second spin just to get all the water out
  • 129 Answers
Bearing or transmission
Posted on Feb 02, 2010
Haier washing machine taking water in and taking water out but not spining it gave burning smell once after that stopped spining
From the limited information you provided, I would concentrate on the transmission. Most are a two speed transmission - low for wash cycle and high for spin. If it isn't doing either, you should make sure that it is getting a signal to the transmission from the control board.
Jun 23, 2011 | Washing Machines
My washer fills with water on starting a load but then it does nothing won't start spining to empty water
If the machine loads ups with water and does not stop then the water level sensor is fautly . But if the inlet valve stops on fill up but there is no spin of the motor or thereafter there is no spin/rinse or drain then the program controller / drain valve/pump must be checked.
Jun 14, 2011 | Washing Machines
I have a fisher paykel eco which is spining water on the floor.
You could take the pump out and check it for obstacles
Mar 05, 2010 | Washing Machines
Spin cycle does not work.water not realesing after first wash. the barelle is not spining on spin. can still hear motor runing but sounds different.
there may some kind of foreign object stopping the impellar wheel or blocking the drain pump completly.use a wet dry shop vac and attach it to the end of the drain hose. if the water comes out fairly easily there is somehting stopping the pump.either way once you remove the water take the two hose off the drain pump and you will find what is wrong remember to look in the pump. I hope this helps. i would like toknwo how things turn out
Jan 22, 2010 | Washing Machines
My ge washer starts spining to drain water then stops
Sounds like the belt is loose. The burning smell is the belt heating up. The motor shuts down because it's heating up from spinning on the belt.
Apr 30, 2009 | Washing Machines
Spin cycle will not take all water out of cloths
INSPECT PUMP MAYBE WORN OUT ,, IF STILL DOING SAME REPLACE CLUTCH AND TRANSMISSION
Nov 25, 2008 | Kenmore Washing Machines
Pav2300aww spinning very slow,and not draining
In all these Cases it sounds like a faulty lip seal. These special seals have Sealed bearings inside. Water gets through the seal and into the bearing which causes it to thump (like a helicopter) or squeal very loudly. As far as draining, the machine has to reach a curtain speed before the pump can turn fast enough to work.
Nov 02, 2007 | Maytag Performa PAV2200
Very load noise when tub stops spining
My washer did the same thing. I put some belt dressing on the belt (the belt is on the very bottom, no disassembly rquired). The belt dressing I picked up at the local auto parts, and this seemed to help.
Dec 11, 2006 | Maytag MAV6200 Top Load Washer
Maytag MAV8557 Top Load Washer Logo
Top Maytag Washing Machines Experts
Bill Long
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
