Question about Panasonic Televison & Video
Hourglass picture. Panasonic CT-35G30T The picture is hour glassing from the sides. Starts to flicker back to normal after 1 to 2 hours. Getting progressively worse. Takes longer time to reach normal screen.I slight tap on the side of the box snaps it to full screen, only after tv is warmed up for an hour or so.
  • 1 more comment
  • fladavid Feb 02, 2010
    Thank you. I am capable of doing the repair myself, I just need to be pointed in the right direction. I've fixed loose solder joints on powder transistors before on my vintage Yamaha equipment.
    In case this isn't the problem......Do you have any other suggestions on what to look for?? I have a Fluke 29 dmm to troubleshoot with.
  • fladavid Feb 20, 2010
    I've checked all the solder connection on the bottom of the main board and the add on boards. They all look mint. I'm thinking it's a bad capacitor/component somewhere. But where is the question. I have the service manual I downloaded that I could forward to you if you if you give me you email. If you could show me the correct circuit, I will replace all the components in that area.
    Thank you.
    I wanted to add....The hour-glassing goes away after the set warms up, but sometimes it takes two hours, sometimes ten minutes. Just tapping on the set doesn't work.
    President:
  • 2,992 Answers
This is caused by bad solder connections in what's called the pincushion correction circuit. Some of the transistors get quite hot, and over time the solder connections to the TV circuit board become intermittent. When you tap the set, it causes them to make contact again so the picture is normal, but then it goes funny again. Resoldering the connections would take care of this problem. I would suggest calling a professional in to make the repair, which would cost far less than a replacement TV.
Hope this has been helpful, and thanks for using Fixya!
Posted on Feb 02, 2010
  • Feb 20, 2010
    Sorry to be slow in responding, but I lost track of this. I don't have service literature for this model in my library so I can't point you toward specific parts. The pincushion circuitry is part of the set's horizontal circuit, so the affected parts are on that area of the circuit board. That's where the flyback transformer is located, easily identified by the wire that runs up to the rubber cap near the top of the picture tube. Examine solder connections in that area, particularly on transistors mounted on heat sinks, and resolder any that don't look nice and shiny. Sometimes you'll see visibly broken connections, which makes the job easier.
    Wish I could be more definite, but that's the way I usually solved this problem when I serviced TVs. Just eyeballs and a general idea of where to look.
    Good luck! Since the problem seems to be solder-related, you shouldn't need that meter.
  • Feb 21, 2010
    OK, I'll give it a go if you can email the manual to pgh_pa_guy@hotmail.com
    Does sound like a capacitor that is slow to charge. I guess the part of your original post that said tapping cleared the problem after an hour warmup didn't sink in. I must be getting old after all.
Picture has hourglass look and has split screen picture hourglass comes and goes but split screen is continual
If hour glass on conventional set it is either pincussion circuit or power supply---by split screen if you mean folded over top to bottom in the middle that is in the same areas.
Apr 06, 2012 | ESA EF427E TV
Hourglass Shape
If there is a hour glass shape to the image but convergence is normal, there are 2 possibilities. You either have a pincushion correction problem or if the hour glass seems to be moving, it will be an open filter capacitor in the power supply.
Unless you are electronically inclined troubleshooting this issue will require a factory trained service technician. You can expect to spend $300-$400 to fix this.
Feb 17, 2009 | Philips 60PP9202 60" Rear Projection...
Panasonic 32" CT-32G13W
That's good you have time and patience.
You should have service manual and electronics knowledge to recognize and test / check parts in tv.
Problem is in Pin Out area of tv and you can have new parts from Panasonic Parts.
You can buy service manual from Service Manual net
Good Luck.
Dec 11, 2008 | Panasonic CT-32HXC14 32" TV
Vertical hold
If the picture is in an hourglass shape this has nothing to do with vertical hold. Besides, on all these sets, the hold and parameters are all uPC controled through a firmware routine that is burned in to an EPROM.
It is obvious that there is a failed component somewhere because of the hour glass shape. The area of failure is most likely in the pin amp section. If the hourglass is from the sides, it would be horizontal pin. If it is top and bottom, the fault is in the vertical pin section.
A common cause is from a capacitor that has failed in the mentioned area. Sometimes it can be an IC or other type of component in the pin amp area, but not as often as failed capacitors.
You can take the set in to service the fault. I don't think you can fix this yourself unless you are trained in TV service and have the experience and setup to troubleshoot for the bad parts, and do this type of service.
Jerry G.
Apr 19, 2008 | Panasonic CT-32HX40 32" TV
My Panasonic CT-36SX31 picture has an hour shape
Take a look around (say, within 12 feet of) the TV... anything that can generate an electrical field? Microwave... refridgerator... old school stereo speakers...
Pin cushioned is a term applied to a picture that's doing what you described. Adjustments to correct that are typically found in computer monitors.
I have an identical television to yours and that adjustment isn't available. You could try degausing, but I doubt that works.
Jan 27, 2008 | Panasonic CT-36SX31 36" TV
Hourglass frozen on screen!!
Try and plug it in your computer once again and see if the hour glass budges. Then safely remove it by clicking the "Safely Remove Device" Icon on your PC tray (where the clock is on a PC)...
If not, theres probably a software reset hole at the back or sides of your mp4 player, try pushing it with a toothpick or similar pointed thing.
If all else fails, have it replaced...
Dec 09, 2007 | Audio Players & Recorders
RCA 32V432T picture problem
Sounds like the Filter Cap is shorting.
Sep 08, 2007 | Televison & Video
Tv picture shaped like hour glass
The link you posted has been deleted, so I cannot see the picture you posted. If the sides bow in like an hourglass and the red, green and blue colors are still aligned then there is a horizontal width or pincussion problem, but if the sides bow in and the 3 colors have separated and are no longer anywhere near aligned then you have a convergence problem, both of which should be serviced by someone with experience in servicing projection TV's.
Jul 03, 2007 | Akai PT4298HD Rear Projection Television
Panasonic CT-32hX41 vertical picture problem (hourglass)
this product has a pincushion problem and requires servicing but unfortunatley it is what we call in the business NECO
Dec 05, 2006 | Panasonic CT-27HL14 27" TV
Televison & Video Logo
261 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
